9th December 2009, 00:56 | #201 | Link |
Thanks, i have to re-master "Live at Radio City- Dave Matthews and Tim Reynolds" then. (Yes, it had a 24/48/2 LPCM as secondary audio track, i've just remembered this is the only one i have.)
9th December 2009, 02:50 | #202 | Link |
Awesome, rica. Good luck!
@whurlston, I'll see if I can attach to the graph tomorrow and see what I get on one of my 48/24 LPCM tracks. That one reported 32 bit output.
9th December 2009, 03:17 | #203 | Link |
Yea, i got LPCM bitstream on Vista with PDVD9; even i have some isssues like FF which is up to either pcm2tsmu or tsmuxer but this is not important for the time being and i don't care
24/48/2 btw; you're right guys, thx. The question is here why we need 24 bit for LPCM bitstreaming then? I'll check it with 7/64 and the reasons tomorrow. Here is the most probably non-useless log: http://www.mediafire.com/?nuumijyhntn BTW i got passthrough here.. Last edited by rica; 9th December 2009 at 03:57. |
9th December 2009, 03:58 | #204 | Link | |
9th December 2009, 05:40 | #208 | Link |
It actually works on TMT as well
Also, if you're interested: the code for it can be found at http://code.assembla.com/roatl-utili...FilterGraphSpy |
9th December 2009, 10:57 | #209 | Link |
Media Control author
@Rica : you said earlier that ffdshow bitstream for THD/DTSHD works on Vista & 7. You meant only 7 right ?
Also, you guys are saying that you are able to use filtergraphspy with TMT and PDVD9 ? So this means that you would be able to get the media structures (as for LPCM) on Vista and on (non working) HD audio formats ? |
9th December 2009, 11:35 | #211 | Link |
MPC has a splitter in the standalone filters package.
http://www.xvidvideo.ru/media-player...cinema-x86-x64 |
9th December 2009, 11:46 | #212 | Link |
Thanks for that, I'm trying to get my .ts files playing natively using mediabrowser in Windows 7 so I need to register the splitter for the TS containers.
Cheers for your help. EDIT: it's the MPEGsplitter.ax that I want, isn't it? |
9th December 2009, 12:25 | #213 | Link | ||
9th December 2009, 12:47 | #215 | Link | |
I'll Vista on a machine later today. |
9th December 2009, 14:20 | #217 | Link | |
So you're saying that HD bitstream is working on Vista too (because from your Vista logs I didn't see it working) ? So(2) can we say that HD audio bitstream is okay now for DTS-HD and TrueHD on Vista & 7 ? (for EAC3 it is a driver matter) Ok great. I may have a few ideas to improve the dumper tool if this is not possible |
9th December 2009, 16:48 | #219 | Link |
Yeah! PDVD9 doesn't crash with dumper if function "auto turn-off Aero" disabled! I hear sound, I see lights on avr and I have 60Mb bitstream.txt ))
DTS HD MA (realy working), Vista x86, Auzentech, PDVD9 2320 http://www.mediafire.com/?1zmjrzm3zxz Dolby TrueHD http://www.mediafire.com/?tmwyjj0mytm So, to all, who have problems with PDVD+dumper: Settings -> BluRay disk -> Advanced -> Windows Aero Turn off checkbox. Last edited by Browncoat; 9th December 2009 at 17:38. |
