14th November 2009, 18:25 | #141 | Link |
You could try avs2avi to get your h.264 in an avi-file, and try to demux and remux that in graphedit, or try a vfw version of x264, and try to mux that.
Roelofs Coaching |
14th November 2009, 22:01 | #142 | Link |
i will try that option, however i am wanting to mux the streams into a wmv, would i be able to do that in graphedit?
but either way, why am i getting that error in the muxer? Unless u are suggesting that i mux the two streams into an avi and open it in SolveigMM ASF Muxer to mux it into a wmv? |
15th November 2009, 10:15 | #143 | Link |
Yes, that's more or less the idea.
Roelofs Coaching |
15th November 2009, 23:13 | #145 | Link |
avs2avi and then avimux gui.
Roelofs Coaching Last edited by jmartinr; 15th November 2009 at 23:16. |
16th November 2009, 12:55 | #147 | Link |
Maybe it's not necessary for the Solveig Muxer. It has a checkbox for H264. Just try.
Some years ago I tried what you are doing now, and then changed to MP4, which makes streaming a lot more straight forward. Just had a quick look at my test ASF-files from that time. They play fine in VLC, but not in MPC or WMP. At the time I tried a few options, one of them was VLC, that can do a remux. The test file that plays in VLC is probably done with VLC. Out of curiosity I just tried an avi to ASF remux with the Solveig Muxer. It plays but shows video corruption.
Roelofs Coaching Last edited by jmartinr; 16th November 2009 at 16:19. Reason: correction |
16th November 2009, 23:42 | #148 | Link |
i have also tried that at the first go and i still ran into the same problem.
i am on avimux gui now, and so far i can only input the ac3 stream but i cannot with the h264 stream, is there something that i am missing? |
17th November 2009, 01:04 | #149 | Link |
h264 in avi comes with some pecularities. Use search. But anyways, I tried the avi route, and it didn't work that well. What do you want to do with your muxed files?
Roelofs Coaching |
17th November 2009, 07:02 | #150 | Link |
wma3 to wma2 audio conversion, please help the newbie
I have a media player (two of them actually, one is part of the TV) that does not seem to like wma3 audio in a wmv file (I think you guys call that the container). The video plays fine, but I get an "audio codec unsupported" message on screen.
So I was thinking that I could use this tool to convert the audio stream. I am getting this error: Could not set audio profile, (hresult = 0x80070003) Cause: The system cannot find the path specified. Encoding... Got event: 3 Conversion aborted, (hresult = 0x8000ffff) I thought I had seen a similar error in this thread before, but now I can not find it. Do I have to demux the audio from the video first, so that I have two seperate files, and then reencode the audio and multiplex? Thanks in advance. |
7th December 2009, 13:51 | #152 | Link |
Just retried Solvieg and had some succes without audio (some corruption on seeking, but for the rest functional video's), but not with audio. I've no idea for a solution.
Roelofs Coaching |
4th August 2011, 16:36 | #153 | Link |
Hi folks,
I know this is an Older post ... but can anyone, including the Author of this program - CRYPTO (if he is still around), help me with this problem ... every time I try to run the program on my laptop which has Vista Home PRemium, SP2, 64-Bit ... I get the following Error ... "Cannot continue. This program requires HDTV Dump Filter Version 1.2 or later. Please check, if the filter is installed and registered." BTW, I have already seen the Earlier Post saying to Register the Filter ... and that does NOT help. Also, I have scoured the interent and there is NO "HDTV Dump Filter Version 1.2" ... the latest version I can find is 1.1 and that does Not work. The reason I am after this program ... is because I am looking for a Program that it will simply REMux my existing WMV file ... I do Not want to Reencode ... my WMV video file plays Fine on my "Netgear EVA9100 TV Media Player" (it is a media player like WDTV Media Player) but I can NOT Fast Forward (FF) the file ... every time I try FF the video file ... it goes back to the Beginning of the darn file. Can anyone provide any Help! Thanks, G! |
31st August 2011, 16:41 | #155 | Link |
does transcoding/muxing job until last frame, but then "hangs" and can't finish the file. I tried that with several different input files. Same result. Input conforms to ASF specs, I tested with ASFvalidator. It's a pitty, because the GUI looks clean and promising. Here are the A/V properties: ...any ideas what's going wrong ?
31st August 2011, 17:14 | #156 | Link |
Unavailable
After so many "catastrophic failures" , I had to stop using Crypto's WMV Muxer In most cases, SolveigMM ASF Muxer and/or AsfBin are suffficient, but sometimes, ffmpeg or/and vidtoasf are required too.
31st August 2011, 17:24 | #157 | Link |
Life's clearer in 4K UHD
Indeed...
Crypto's WMV muxer has a friendly enough GUI (much like his MP4 Muxer) but sadly it never seemed to get finished enough to be stable! Real shame
31st August 2011, 17:54 | #158 | Link |
I got a "catastrophic failures", aborted, retried (without touching settings), again, "catastrophic failure", aborted, retried (without touching settings) and this time I didn't get an error (talk about consistency ... :-) ). But although no error is issued, the program still "hangs" on the last frame and doesn't finish.
I need to mux audio track (wma) and video track (wmv), I didn't find a way in AsfBin GUI to do that. Is it possible in GUI? Or only in cmd ln? or not at all? As for SoveigMM ASF muxer, I don't know how to use it. I have registered SMM_ASFMuxer.ax but what now? There is no executable. I also tried vidtoasf, but it doesn't accept wmv as input (pretty weird for a wmv muxer): Code:
vidtoasf -in video.wmv -audiofile audio.wma -out out.asf Error: Invalid input file extension. Last edited by lovelove; 31st August 2011 at 18:15. |
31st August 2011, 17:58 | #159 | Link | |
I only found WmvStreamEditor but it crashes upon startup. Last edited by lovelove; 31st August 2011 at 18:11. |
