25th December 2005, 21:05 | #181 | Link |
Does anybody know what's the deal with syswow64, I'm using this code to determine the sys dir:
Environment.SystemDirectory
25th December 2005, 21:58 | #182 | Link |
I'm not sure, but I'm guessing the lack of feedback means that people have very little trouble with using your app. I've started to use it instead of MeGUI for converting .avi to a format the iPod likes. Both apps work quite similarly, but I like the greater flexibility StaxRip offers. The iPod is extremely picky with encoder settings and your app allows a completely custom command line. The greater flexibility does make it a bit more difficult to figure out how it works, but only a bit.
I have only two small problems. I store a default target resolution and bitrate in the default project, but every time I open a new file these values are changed. There seems to be some logic behind it, but I'm not sure what that logic is. It's easy enough to reset the values to how I want them, but it is an extra step away from just "open file and press 'next' to encode" after having setup all the profiles. Another problems doesn't seem to come from your app, but from avi2wav. It doesn't extract the VBR mp3 tracks from the avi files I have been transcoding. Extracting with virtualdub before opening the file in staxrip does make staxrip autoselect the mp3 file, but it would be nice to have it working without the extra step of virtualdub. Apart from that, thank you for a very nice app |
25th December 2005, 23:19 | #183 | Link |
I'm guessing the problem is that when Environment.SystemDirectory is called, it returns system32, since that is the correct system folder for 64-bit apps, and since StaxRip is using .NET 2, it in effect is a 64-bit app.
25th December 2005, 23:43 | #184 | Link | ||||
Bitrate depend on the target lenght and size so the reason why it changes is the target length changes, the size stays. This might be a limitation, if you like we can examine it further, normally people aim for a file size while other (e.g. me) use quality mode (fixed quant), doesn't the iPod fit in traditional encoding methods? Quote:
I'm much interseted in sample clips other than PAL DVD/DVB btw. so if anybody has something that is not handled well please send it. I plan a auto deinterlace feature and could use some samples for that as well. http://www.yousendit.com/ Quote:
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 25th December 2005 at 23:49. |
25th December 2005, 23:56 | #185 | Link | |
On my first attempts with x264 i couldnt figure it out how to do it with MEGUI and with StaxRip it worked the first time(even i was surprised with it) every function was where it was supposed to be. i think the lack of feedback means that users arent having problems with it! In my opinion the new Encoder and Muxer selection menu are just right Good Job Stax |
26th December 2005, 00:08 | #186 | Link | |
26th December 2005, 02:58 | #187 | Link |
Well this is my first venture into stax-encodings.. and i couldnt get my little HD-Mpeg2-ts --> HD.x264 project to work.. it ends at :
System.NullReferenceException: Object reference not set to an instance of an object. at StaxRip.MP4BoxMuxer.Mux() at StaxRip.MainForm.Encode() at StaxRip.MainForm.bSkip_Click(Object sender, EventArgs e) (it does all the ts demuxing and audio transcoding, and when its supposed to start encoding with x264 it blinks and goes back to the gui and says an error) any idea? And another thing: How does one really set a new target directory for the encodes, demuxing and so on? I click on the target directory option but i just get the current one up and i cannot select anything.. Last edited by TEB; 26th December 2005 at 12:51. |
26th December 2005, 12:44 | #188 | Link | |||
26th December 2005, 13:40 | #189 | Link |
@TEB
I would need a bug report generated from StaxRip to find out why the x264 encoding failed. Didn't StaxRip offer to generate a bug report after the crash? @Franky I'll upload a hotfix later today. @Aladdin I'll look for a additional avi demuxer. Your source is a AVI file containing MP3 VBR and DivX/XviD?
26th December 2005, 16:32 | #190 | Link | |
26th December 2005, 18:35 | #192 | Link | |
The scripting doc contains something which could be the thing we need:
void SaveWAV(string filename); (VirtualDub 1.4d or later) Runs the processing engine to produce an output file in WAV format. Quote:
27th December 2005, 00:01 | #194 | Link | ||
27th December 2005, 00:46 | #195 | Link | ||
VirtualDub with MP3 VBR support |
27th December 2005, 01:07 | #196 | Link |
@TEB
You've selected Pass 3 in All Pass mode and this changed all passes to use pass 3. I've should disabled this option in All Pass mode.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 27th December 2005 at 01:14. |
27th December 2005, 09:33 | #198 | Link |
Excelent app ! Great ... exactly what a TS (DVB) to Format XXX needs ...8)
Thank you 4 this great app ! -EDIT- found the command line syntax for encoding ac3-> HE-AAC 5.1 (-core( -input "%input%" -output "%output%" ) -azid( -c normal -L -3db ) -ota( -hybridgain ) -bsn( -6chnew -vbr_normal ) tnx Is there a chance to do Cutting in Project X (GUI ?) as first step and then do the complete encoding process ? DVB Streams are not exactly recorded so i have to cut off leading commercials etc ... Would be a nice feature .... 8) Last edited by fogbav; 27th December 2005 at 11:43. |
27th December 2005, 11:43 | #199 | Link | |
27th December 2005, 14:01 | #200 | Link |
Jup ... ok ... seems logical ...8)
First Rips are running ... perfect ... thank you very much again for this "heavy duty" App ! Go and sell it to Ahead so they know how "recode" can look like when its nearly perfect ..8) |
gui, h.264, h.265, hevc, mkv, x264, x265 |
