31st August 2009, 15:29 | #2241 | Link |
The error message that appeared was saying it was missing those same dlls, so I went on the official mkvtoolnix and downloaded the version 7z. Anyway, so I finish the conversion here, I put the log here.
Ah, the conversion of the audio worked this time, but I have doubts about the final size of the file, but is completing the conversion of the video. I just saw the problem again of mkvtoolnix, the error message that appears is not the StaxRip, but Windows, saying that lack the dlls mentioned. In this version, the StaxRip is consuming more resources on my pc is slow and sometimes gives an error message. Net framework is so heavy that the program is, I mean the beginning of conversion, especially in relation to the previous version. My pc is Semprom 1.8 GHz, 1 GB ram, ATI Radeon 9250, in Windows XP SP3. last time I edit this post. Last edited by Havokdan; 31st August 2009 at 16:02. Reason: Many edits in post |
31st August 2009, 19:30 | #2242 | Link |
I made it, ran the conversion now But I have two questions: 1 - Sampling rate of audio aac was 48 when I convert to mp3 it stays with 24.0 KHz,does not leave the same as the original?; 2 - As mentioned in the post above, the program is very slow and cumbersome the system, I realized that the peak and when the log starts to display the settings of the video codec, in my case Xvid, example:
------------------------------------------------------------ First Pass Codec Parameters ------------------------------------------------------------ ar_mode: 0 ar_x: 4 ar_y: 3 aspect_ratio: 0 audio_mode: 0 audio_rate: 128 audio_size: 0 audio_type: 0 bitrate: 931 bquant_offset: 100 bquant_ratio: 162 Brightness: 0 chromame: 1 container_type: 1 curve_compression_high: 0 curve_compression_low: 0 Deblock_UV: 0 Deblock_Y: 0 debug: 0 Dering_UV: 0 Dering_Y: 0 desired_quant: 200 desired_size: 155081 discard1pass: 1 display_status: 0 FilmEffect: 0 fourcc_used: 2 fps: 2 frame_drop_ratio: 0 full1pass: 0 gmc: 0 hours: 1 interlacing: 0 keyframe_boost: 10 kfreduction: 20 kfthreshold: 1 lum_masking: 0 max_bframes: 1 max_bquant: 31 max_iquant: 31 max_key_interval: 300 max_pquant: 31 min_bquant: 1 min_iquant: 1 min_pquant: 1 minutes: 30 mode: 1 motion_search: 6 num_threads: 0 num_zones: 1 overflow_control_strength: 5 packed: 1 par_x: 1 par_y: 1 profile: Xvid Home Theatre NTSC qpel: 0 quality: Real-time quant_type: 0 rc_averaging_period: 100 rc_buffer: 100 rc_reaction_delay_factor: 16 seconds: 0 stats: E:\Documents and Settings\Daniel\Meus documentos\The KMPlayer\Higashi no Eden 04 temp files\Higashi no Eden 04.pass subtitle_size: 0 target_size: 665600 tff: 0 trellis_quant: 1 turbo: 0 twopass_max_overflow_degradation: 5 twopass_max_overflow_improvement: 5 use_2pass_bitrate: 0 use_bvop: 1 vhq_bframe: 0 vhq_mode: 1 vop_debug: 0 zone0_bvop_threshold: 0 zone0_cartoon_mode: 0 zone0_chroma_opt: 0 zone0_frame: 0 zone0_greyscale: 0 zone0_mode: 0 zone0_quant: 500 zone0_type: 0 zone0_weight: 100 |
31st August 2009, 19:35 | #2243 | Link | ||
@Havokdan
Is the error triggered by mkvmerge, mkvinfo or mkvextract, demuxing uses mkvinfo and mkvextract and muxing uses mkvmerge. I hope you post log files, you can also mail me, there is a mail menu item in the main menu. Quote:
31st August 2009, 19:39 | #2244 | Link | |
@ stax76
ill try the new stax and return in this thread and as you say about the avchd....not many people knows mutch about the format here in europe we are stuck with it thu thx for your help so far |
31st August 2009, 19:42 | #2245 | Link | |
ffmpeg -i <source.m4a> -ac 2 <target.wav> We need a audio expert to find out how to deal with this. @cbsjanten If you want to use DGAVCDec you could try the new option 'Decode and downmix to stereo' where you can define to decode using BeSweet or ffmpeg. As soon as there are more free HD channels in germany which is hopefully soon I'll try to convert things myself. Afaik some people demux with txmuxer, I don't know if there are people having StaxRip configured to use tsmuxer.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 31st August 2009 at 19:53. |
31st August 2009, 20:47 | #2246 | Link | |
ill be more than happy to provide it to u in private for testing purpose ofc the downmix would ba a shame....i use the encodings on my mediacenter and i just love the 5.1 sound my mediacenter cant handle the 1080i h264 thu..its an old machine but u did manage to get it in sync with ffdshow? ill test coreavc and ffdshow then |
31st August 2009, 21:07 | #2247 | Link |
@cbsjanten
What are your preferred target formats?
31st August 2009, 21:10 | #2249 | Link |
audio?
31st August 2009, 21:42 | #2251 | Link |
StaxRip uses VirtualDubMod to cut AC3 and this fails with your stream as there are different channels and maybe also stream errors since it's a capture. I don't know which cutter would work. You could start a dedicated thread to find out if there is a tool that can handle the job. Maybe AAC or Vorbis 5.1 would also be acceptable. In this case decoding it to 5.1 wav could be tried. This would create a rather large wav file. If here nobody knows a solution maybe people at the DVBViewer forum know more.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 31st August 2009 at 21:45. |
31st August 2009, 21:50 | #2252 | Link |
ye....but before when the source was 720p....i did cut it right....there was the same changes in audio at that time...i did use stax 1.1.1.0 at that time but i guess its not because its a new vdmod that causes the troubles?
ill try look into the way i record it and proceed thx many times for taking the time to help me....i really appreciate it |
31st August 2009, 22:11 | #2253 | Link | |
31st August 2009, 22:45 | #2254 | Link |
@cbsjanten
I guess it's because it was MPEG-2 and that was processed with ProjectX and to my knowledge ProjectX don't support AVC sources. @Havokdan Thanks providing the log file, I'll investigate the encoding failed issue, did you notice the ffmpeg writing SBR not supported to the log file, I assume this is the reason for the downmixing, I'll try to find a newer ffmpeg versions with SBR support. Edit: The performance issue you noticed was due to ffdshow writing a few thousand times 'SBR not implemented' to the log output. I can block it but that don't solve the problem SBR not being supported by ffdshow.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 31st August 2009 at 23:19. |
31st August 2009, 23:32 | #2255 | Link |
Thanks for help. Unable to decode the aac mkv home via directshowsource, or add this option? For before used the Avisinth (DirectShowSource) + Virtualdub (to encode the audio and video).
1st September 2009, 00:10 | #2256 | Link |
You mean you want StaxRip to decode aac using DirectShow since ffdshow can't handle SBR? I can help with this (tomorrow).
1st September 2009, 08:52 | #2258 | Link | |
1st September 2009, 15:07 | #2259 | Link |
audio missing
Hi all,
I have problem with latest StaxRip. I use it to convert TV-recordings (Topfield 5100PVRc .rec's) into mkv's with AC sound. I demux files first with ProjectX (OoZooN.TV Edition) and StaxRip handles rest. The problem is that with this new temp directory feature my finished mkv files do not have audio at all. It seems that when temp directory is created the program does not check is there separate audio file. The program does not notice anymore the original mp2 audiofile --> no sound. So far I have used Staxrip to convert hundreds of files into mkv's so I was one happy jack before this new 'feature'. Please can you fix this? The queque is piling up |
1st September 2009, 15:17 | #2260 | Link |
@PeteP
Hi and welcome at Doom9, please try the following: download the latest test build, I've posted the link to it a couple of posts before, convert a file, if there is no audio, go to Main Menu -> Help -> Make Bug Report, this creates some diagnostic files and tells you to mail these files to me.
gui, h.264, h.265, hevc, mkv, x264, x265 |
