Old 17th January 2020, 15:05   #1  |  Link
syrist
Does FFMPEG convert 5.1 to 2.0 properly by default??
Hi, I normally use ffmpeg+neroaacenc to downmix AC3 and DTS surround to 2 channel AAC using the following command line:
ffmpeg.exe -y -i SOURCE.MKV -ac 2 -acodec pcm_s16le -f wav - | neroAacEnc.exe -ignorelength -if - -of DESTINATION.AAC
I was reading on this forum that some people like to tweak the volume levels of some channels (ie. increase center and decrease surround, etc.) so the dialog doesn't get overpowered/
So I was just wondering if when ffmpeg downmixes multichannel to 2 channel if it just blindly merges all the channels together or if it makes level adjustments to some of the channels before downmixing.
syrist is offline   Reply With Quote
Old 17th January 2020, 21:50   #2  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Yeah, it will downmix properly, according to standards. Remember the standards omit the LFE channel.
https://trac.ffmpeg.org/wiki/AudioCh...ion#a5.1stereo
You can use the pan audio filter to customize the downmix how you want.
https://ffmpeg.org/ffmpeg-filters.html#pan-1
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
Old 18th January 2020, 11:56   #3  |  Link
tebasuna51
tebasuna51's Avatar
It is not exact. The standards showed in section 7.8 of .pdf related in ffmpeg docs are:
For a standard mix:
Prior to the scaling needed to prevent overflow, the general 3/2 downmix equations for an LoRo stereo signal are
Lo = 1.0 * L + clev * C + slev * Ls ;
Ro = 1.0 * R + clev * C + slev * Rs ;
or for a DPL mix:
Prior to the scaling needed to prevent overflow, the 3/2 downmix equations for an LtRt stereo signal are
Lt = 1.0 * L + 0.707 * C – 0.707 * Ls – 0.707 * Rs ;
Rt = 1.0 * R + 0.707 * C + 0.707 * Ls + 0.707 * Rs ;
But ffmpeg do:
L = 0.4142 * L + 0.2929 * C + 0.2929 * Ls
R = 0.4142 * R + 0.2929 * C + 0.2929 * Rs
From a un-normalized mix of:
L = 1.0 * L + 0.707 * C + 0.707 * Ls
R = 1.0 * R + 0.707 * C + 0.707 * Rs
Is a standard mix (not DPL) but ignoring the 'clev' and 'slev' parameters included in AC3 headers.
clev can be:
0.707 (my recommendation when encode: -center_mixlev 0.707)
0.595 (the default when encode with ffmpeg)
0.500 (never recommended)
slev can be:
0.707 (not recommended)
0.500 (the default and recommended with ffmpeg)
My recommended un-normalizad mix standard is:
L = 1.0 * L + 0.707 * C + 0.500 * Ls
R = 1.0 * R + 0.707 * C + 0.500 * Rs
and normalized:
L = 0.453 * L + 0.320 * C + 0.227 * Ls
R = 0.453 * R + 0.320 * C + 0.227 * Rs
But for users than experiment low dialog volume we can modify the coeficients.
Old 27th January 2020, 20:45   #4  |  Link
syrist
For a standard mix:
or for a DPL mix:
But ffmpeg do:
clev can be:
slev can be:
and normalized:
Great info... thanks for the reply. I'll adjust my batch file command line settings.
downmix, ffmpeg, multichannel, stereo, surround
