Old 17th June 2013, 23:50   #1  |  Link
benwaggoner
xvYCC in x264 or other encoders?
Say,
Is there support for encoding H.264 with xvYCC in x264 or other generally available H.264 encoders?
http://en.wikipedia.org/wiki/XvYCC
It may just be a matter of setting a metadata flag correctly, as long as the encoder doesn't clamp the chroma range or something.
Ben Waggoner
My Compression Book
Old 18th June 2013, 00:10   #2  |  Link
kieranrk
There is some sort of undocumented SEI in AVCHD for setting xvYCC
kieranrk is offline   Reply With Quote
Old 18th June 2013, 02:45   #3  |  Link
drmpeg
Isn't it just a matter of setting transfer characteristics = 11 in the VUI?
Doesn't look like it's supported in the current version of x264.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
drmpeg is offline   Reply With Quote
Old 18th June 2013, 10:50   #4  |  Link
kabelbrand
Compression mode: Lousy
kabelbrand's Avatar
There was a patch adding BT.2020 to the Colour Primaries a few days ago.
One of the newly added Transfer Characteristics was IEC 61966-2-4:
http://mailman.videolan.org/pipermai...ne/010127.html
kabelbrand is offline   Reply With Quote
Old 19th June 2013, 19:23   #5  |  Link
benwaggoner
Nice! I hope it makes it into a release build soon.
Was Rec 2020 included too? A guy can dream ...
http://en.wikipedia.org/wiki/Rec._2020
Ben Waggoner
My Compression Book
Old 19th June 2013, 19:37   #6  |  Link
sneaker_ger
--colormatrix now goes up to 10, --transfer up to 15 and --colorprim up to 9. (dev commit)
Each corresponding to the values in the updated H.264 spec.
Old 19th June 2013, 20:28   #7  |  Link
benwaggoner
So it is! But the 10-bit version without the expanded luma range, of course, which requires 12-bit.
I see xvYCC is in there as well: IEC 61966-2-4.
I look forward to doing some tests in the next few weeks!
Ben Waggoner
My Compression Book
Old 19th June 2013, 21:44   #8  |  Link
drmpeg
All the BT.2020 permutations have been included in the patch.
transfer characteristics = 14, "bt2020-10" /* 10-bit */
transfer characteristics = 15, "bt2020-12" /* 12-bit */
matrix coefficients = 9, "bt2020nc" /* non-constant luminance */
matrix coefficients = 10, "bt2020c" /* constant luminance */
Ron
Old 19th June 2013, 21:49   #9  |  Link
sneaker_ger
So, what is there to test? It's just a flag, isn't it?
Old 19th June 2013, 22:01   #10  |  Link
benwaggoner
End-to-end from source to encode to player to screen, making sure it does what it is supposed to do and I can see the expanded xvYCC gamut colors.
Ben Waggoner
My Compression Book
Old 21st June 2013, 15:49   #11  |  Link
Biggiesized
Biggiesized's Avatar
I never understood why xvYCC couldn't be shoe-horned into Blu-ray when the format was launched coincidentally with the spec.
I think Sony is doing something with xvYCC now, but it's particular to using a Sony Blu-ray player and Sony HDTV.
Biggiesized is offline   Reply With Quote
gamut, hdr, xvycc
