Old 26th May 2008, 09:10   #1  |  Link
Velvet Ghost
Issues with ProCoder 3 and DivX / XviD sources
I'm using ProCoder 3 to encode some files encoded in DivX / XviD into MPEG2 so that I can author them to DVD. The content is mainly rare video footage / TV transmission / concert video of a certain music artist. It's not possible for me to get any better quality sources for these, in some cases no better source exists.
The stuff is mainly from 1965 - 1985, although one particular silent clip was recorded in 1928! In accordance with the times, the quality of the video is mainly poor, with lots of noise, etc. The files have bitrates around 1000 - 2000 kbps.
What I want is a relatively faithful conversion to MPEG2, retaining whatever little video clarity there is. I've heard that ProCoder is better than CCE SP for this particular type (bad source) of conversion.
Unfortunately, even when encoding at 8000Kbps in 'Mastering' mode, I have found a significant drop in quality, even with my untrained eye. The image appears blurred and less detailed and the colours are less vibrant and look faded. When encoding at lower bitrates this quality drop obviously persists, but doesn't seem to be getting any worse. What am I doing wrong? I tried TMPGEnc and Nero codecs as well. As expected, results were even worse than ProCoder.
Thanks in advance.
Velvet Ghost is offline   Reply With Quote
Old 26th May 2008, 18:44   #2  |  Link
setarip_old
setarip_old's Avatar
Hi!
You might want to save a step or two and simply use (freeware) DVD Flick to convert your DivX-compressed and XviD-compressed .AVIs DIRECTLY to DVD...
setarip_old is offline   Reply With Quote
Old 26th May 2008, 19:10   #3  |  Link
Velvet Ghost
This should have been clear from my first post, but I have no problems actually performing the conversion - it's just that I'm not satisfied with the quality. I greatly doubt that DVD Flick will provide quality superior to ProCoder 3, which is considered to be one of the best MPEG2 encoders in the market.
Old 26th May 2008, 22:01   #4  |  Link
setarip_old
You won't know for sure, unless you try it, will you? ;>}
Old 27th May 2008, 20:22   #5  |  Link
Velvet Ghost
Here's a snapshot from the original video:
And here's a snapshot from an MPEG2 encoded at 8000Kbps, all settings to highest quality possible, and mastering mode:
Hope that helps in your diagnosis.
Old 27th May 2008, 22:16   #6  |  Link
setarip_old
I'm not the one making any diagnosis. I've suggested that you, on the other hand, try DVD Flick and compare the results...
Old 27th May 2008, 22:18   #7  |  Link
Irakli
Irakli's Avatar
@Velvet Ghost
Well, Procoder is known to cause excessive blurring sometimes IIRC. Have you tried DVD Flick as suggested by setarip_old?
Also, I would suggest trying HCEnc. I use it with 'bad' & extremely difficult sources (home movies) quite often, and so far I had only positive experience with HCEnc.
Irakli is offline   Reply With Quote
Old 27th May 2008, 22:21   #8  |  Link
45tripp
Dolphin Blue
45tripp's Avatar
i think you should provide a sample clip.
well...
fair statement in theory,
but highly unlikley.
as far as encoders go,
i'd pick procoder (2, 3 not tested),
and you don't have all that many choices anyway,
so you could go through them in a day.
try HC,
try ffmpeg, with basics, try tweaking
spin Quenc
the easy access free solutions.
then you're left with payware CCE and Mainconcept
to trial.
injected with feelings; with no final fading
45tripp is offline   Reply With Quote
Old 28th May 2008, 00:20   #9  |  Link
setarip_old
@Irakli
Hi!
If I remember correctly, DVD Flick utilizes HCEnc ;>}
Old 28th May 2008, 10:31   #10  |  Link
45tripp
Dolphin Blue
45tripp's Avatar
@Irakli
Hi!
not unless there've been drastic changes in the latest betas.
dvd flick uses ffmpeg as it's engine.
also forgot to say,
i've seen negative views about mastering mode
in past years, so you might try a lower mode.
Old 28th May 2008, 12:01   #11  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Why don't you give a try to AVStoDVD. It uses both QuEnc or HCenc to generate DVD-compliant streams. You can setup encoding configuration and, if you are able, you can even play with AviSynth script. Ah, it is free (open source).
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
MrC is offline   Reply With Quote
Old 28th May 2008, 18:08   #12  |  Link
setarip_old
@Immersion
Just to set the record straight, DVD Flick did originally use HCEnc up to v.1.2.0 RC1.
Per the "Changelog.txt" file:
Version 1.2.0 RC 1
- Changed: Abandoned DirectShow, HCEnc, AVISynth and Aften in favour of FFMPEG. Hopefully the last big internal makeover.
Old 29th May 2008, 22:33   #13  |  Link
45tripp
Dolphin Blue
45tripp's Avatar
before my time
Old 29th May 2008, 23:56   #14  |  Link
setarip_old
A quotable quote:
To understand the Present, one must study the Past
Old 31st May 2008, 09:21   #15  |  Link
manono
1) The pictures were taken from different frames.
2) The second one has been resized by whatever player you used to take the pic. The resizer used could play a part in this.
3) Therefore the pics were taken from 2 different players, making the comparison apples to oranges. Maybe one used the overlay and the other didn't.
4) It's hard to tell, but it looks to me like the second pic was deinterlaced, either by the player or in the script or the encoder. Was the source interlaced and the output made progressive one way or another?
5) What script did you use?
Old 3rd June 2008, 15:52   #16  |  Link
Velvet Ghost
Sorry I've been away for so long. Thanks for responding, manono. The pictures were taken on the same frame, both using Windows Media Player Classic, using the 'go to frame' feature directly! And the second picture is not resized, just letterboxed. Here's all the information you should need about the source and the output:
Source:
General #0
Complete name : C:\Users\Atriya\Videos\1.avi
Format : AVI
Format/Info : Audio Video Interleave
Format/Family : RIFF
File size : 1.22 GiB
PlayTime : 1h 43mn
Bit rate : 1691 Kbps
StreamSize/String : 8.75 MiB
Video #0
Codec : DivX 5
Codec/Family : MPEG-4V
Codec settings, Packet bitst : No
Codec settings, BVOP : Yes
Codec settings, QPel : No
Codec settings, GMC : 0
Codec settings, Matrix : Default
PlayTime : 1h 43mn
Bit rate : 1519 Kbps
Width : 720 pixels
Height : 480 pixels
Display Aspect ratio : 1.500
Frame rate : 29.970 fps
Standard : NTSC
Resolution : 8 bits
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.147
StreamSize/String : 1.10 GiB
Writing library : DivX 5.0.2
Writing library/Date : UTC 2002-05-16
Audio #0
Codec : MPEG-1 Audio layer 3
Codec profile : Joint stereo
Bit rate mode : CBR
Bit rate : 160 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Resolution : 16 bits
StreamSize/String : 118 MiB
Writing library : LAME3.92
Encoding settings : CBR
Coherency/PlayTime : 9287
Result:
General #0
Complete name : C:\Users\Atriya\Videos\1.m2v
Format : MPEG-2 Video
Format/Family : MPEG-2
File size : 25.0 MiB
PlayTime : 25s 1ms
Bit rate : 8391 Kbps
Video #0
Codec : MPEG-2 Video
Codec/Family : MPEG-V
Codec profile : Main@Main
Codec settings, Matrix : Standard
PlayTime : 25s 1ms
Bit rate mode : CBR
Bit rate : 8052 Kbps
Nominal bit rate : 9800 Kbps
Width : 720 pixels
Height : 480 pixels
Display Aspect ratio : 4/3
Standard : NTSC
Chroma : 4:2:0
Interlacement : Top Field First
Bits/(Pixel*Frame) : 0.946
In the meantime, I encoded the same thing with QuEnc, using the highest possible settings, though that took 15 mins to encode 40 seconds, even on my Core 2 Duo. Here's the result:
Here are the specs of the output file:
General #0
Complete name : C:\Users\Atriya\Videos\clip.m2v
File size : 25.5 MiB
PlayTime : 39s 767ms
Bit rate : 5386 Kbps
Video #0
Bit rate mode : CBR
Bit rate : 5166 Kbps
Width : 720 pixels
Height : 480 pixels
Standard : NTSC
Chroma : 4:2:0
Interlacement : Bottom Field First
I'd say it's much better than ProCoder 3, but keep in mind that it took about 20 times more time to encode. However, its quality is still noticeably inferior to the original.
I also, uploaded a little clip of the source. Here's the link:
http://www.savefile.com/files/1577732
Old 3rd June 2008, 19:49   #17  |  Link
hank315
HCenc author
Encoded with HCenc: VlHor
HCenc at: http://hank315.nl
hank315 is offline   Reply With Quote
Old 3rd June 2008, 21:20   #18  |  Link
45tripp
Dolphin Blue
45tripp's Avatar
:>) not much quality in the original.
we all seem to have diff levels,
so i post original and processed of frame 775
original
procoder2 (8000)
Old 4th June 2008, 03:50   #19  |  Link
Velvet Ghost
hank315, that HCEnc encode is extremely faded-looking. I think you're using some faulty settings there, the encoder can't be THAT bad. Anyway, thanks for giving it a try.
Immersion, excellent!!! That's by far the best one I've seen so far. Apart from a barely-noticeable loss in colour 'vibrance' it's virtually 'transparent' to the eye. In running video I'm sure nobody will be able to make out a difference. Problem is, I have ProCoder 3 as well, and I'm getting terrible results! What settings are you using? Are you tweaking a lot?
Old 4th June 2008, 10:38   #20  |  Link
45tripp
Dolphin Blue
45tripp's Avatar
HC (8000)
the HC encoder is superb actually.
like i said, i've not tried procoder3. I used proc2.
yeah default settings,
what i like and dislike about procoder,
a.you don't have to mess with things cause quality is great with a click of a button,
b.you can';t mess with settings, which is not good for people with tweak fever.
all i did was set source and target to interlaced tff really.
probably didn't even need the 8000 bitrate,
just selected it cause it's what you were using.
in other words it's an easy encode, and more than one encoder will suit.
divx, mpeg, procoder, xvid
