Old 2nd October 2017, 07:00   #3641  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
i5-4670k + gtx 1080
88 fps CPU, 430 fps CUDA
But script results do differ.
I need to upgrade my QTGMC...
vivan is offline
Old 2nd October 2017, 07:09   #3642  |  Link
tuanden0
Originally Posted by poisondeathray View Post
@tuanden0 - you have the same card as the developer, but a 3GB model instead of 6GB. He got 83.43fps vs. 27.33fps for QTGMC on "fast" preset
Just try the exact same script for now, to see if there is a speed difference for you
Here you are
Without CUDA: https://i.imgur.com/TuO78nY.png
With CUDA: https://i.imgur.com/TUSWvuO.png
With CUDA 2: https://i.imgur.com/c06mL6c.png
tuanden0 is offline
Old 2nd October 2017, 13:08   #3643  |  Link
real.finder
I hope someone port that to use opencl (maybe Khanattila since he has experience in it)
so many people can use it
See My Avisynth Stuff
real.finder is offline
Old 2nd October 2017, 16:46   #3644  |  Link
poisondeathray
Originally Posted by vivan View Post
i5-4670k + gtx 1080
differ - did you mean qualitatively different results ?
poisondeathray is offline
Old 2nd October 2017, 20:13   #3645  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
They are just different, it's hard to say which one is better.
https://i.imgur.com/JRM9vJb.png
https://i.imgur.com/8AsGgNL.png
134 fps on 1920x1080 video ("Fast" Preset)
vivan is offline
Old 5th October 2017, 14:42   #3646  |  Link
jpsdr
The following line works in standard avisynth but not in avs+ x64.
black = BlankClip(last, width=64, height=32, Color_yuv=color_black)
and probably the next (forgot to test, and i'm under standard avisynth without avs+ access while writing these lines).
white = BlankClip(last, width=64, height=32, Color_yuv=color_white)
jpsdr is offline
Old 5th October 2017, 15:12   #3647  |  Link
LigH
LigH's Avatar
In which way does it "not work"? Do you have any error messages?
I suppose it doesn't know color constants?
VirtualDub Error
Avisynth open failure:
I don't know what 'color_black' means.
(H:\Video\black-white.avs, line 1)
OK
That should be fixable by providing a color names import scriptlet (colors_rgb.avsi in plugins+ / plugins64+).
My former AviSynth 2.56 installation seems to have provided this file in AviSynth 2.5\plugins already.
But the color constants known in legacy AviSynth 2.55+ are RGB colors, not YUV.
__
Actually, nope ... sorry. The file "colors_rgb.avsi" does exist in all my plugin directories for all AviSynth flavours, but is not auto-loaded. I have to Import() it explicitly to make it work.
New German Gleitz board
LigH is offline
Old 5th October 2017, 20:20   #3648  |  Link
Yanak
Already had similar issues with avs+ x64
blankclip(color=color_black) # doesn't work, " I don't know what color_black means "
blankclip(color=$000000) #works
Switched for Hex values when i needed it but did not suspected this could be a bug
Yanak is offline
Old 5th October 2017, 20:39   #3649  |  Link
LigH
LigH's Avatar
Well, if you explicitly
Import("colors_rgb.avsi")
it works as well; it's just strange that auto-importing from the plugins auto-load directory doesn't work ... anymore? I thought it did, once.
LigH is offline
Old 5th October 2017, 21:07   #3650  |  Link
Groucho2004
See here.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 5th October 2017, 21:25   #3651  |  Link
LigH
LigH's Avatar
Oh, that one is quite old (2015).
Of course, "loading plugins" is not the same as "importing scripts". Still, some automation would be appreciated here.
LigH is offline
Old 6th October 2017, 10:48   #3652  |  Link
pinterf
Yes, the autoload issue is registered but not fixed yet.
pinterf is offline
Old 7th October 2017, 08:53   #3653  |  Link
bxyhxyh
Hello
I'm stabilizing shaky video with deshaker.
Converting it to 16-bit so I could reduce rounding errors.
Like this
Function YV12toRGB32(clip c)
  c.convertTo16bit()
  converttorgb64(matrix="Rec709")
  convertto8bit()
Function RGB32toYV24(clip c)
  c.ConvertTo16bit()
  ConvertToYUV444(matrix="Rec709")
  convertto8bit()
s = source()
s.yv12torgb32().dehsaker().RGB32toYV24()
I noticed bit difference on brightness.
It was clear it's caused by color convertion.
So I just typed
s.yv12torgb32().RGB32toYV24().yv12torgb32().RGB32toYV24().yv12torgb32().RGB32toYV24().yv12torgb32().RGB32toYV24()
Then this is the result
source - https://i.imgur.com/V3aioqT.png
converted - https://i.imgur.com/kddpb3i.png
Is it a bug or something? (Pictures are resized since it doesn't matter for what we're talking anyway.)
bxyhxyh is offline
Old 7th October 2017, 11:49   #3654  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
Originally Posted by bxyhxyh View Post
Then this is the result ...is it a bug or something?
It does look like a bug. The problem seems to be in ConvertTo8bit; its output is aprox. 1 step darker after each pass, probably a rounding issue. Using dither seems to fix it:
  c.convertTo16bit()
  convertto8bit(dither=0)
  c.ConvertTo16bit()
however this does add a dither pattern, invisible in normal footage but apparent in Colorbars etc. Adding a fixed offset also seems to work:
  c.convertTo16bit()
  RGBAdjust(rb=127, gb=127, bb=127)
  convertto8bit()
  c.ConvertTo16bit()
  convertto8bit()
Offset set to 127 because 0.5 (8bit) ≈ 127 (16bit).
raffriff42 is offline
Old 7th October 2017, 16:33   #3655  |  Link
bxyhxyh
Ah, so this might be also yet another "256 or 257" thing.
bxyhxyh is offline
Old 8th October 2017, 18:14   #3656  |  Link
Weirdo
Probably trivial but can't find the workaround. My little script gives There is no function named 'SetMTMode' (line 3), while it works with the older Avisynth 2.6 MT from SEt. Using Avisynth+ r2508, QTGMC 3.357s with its updated plugins, W10 x64. Thanks for any tips.
global MeGUI_darx = 143
global MeGUI_dary = 80
SetMTMode(5, 4)
SetMemoryMax(1000)
LoadPlugin("F:\MeGUI\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("G:\source.d2v")
SetMTMode(2)
QTGMC( Preset="Slow", EdiThreads=2 )
Distributor()
crop(14, 4, -10, -4)
Win 10 Pro x64
Weirdo is offline
Old 8th October 2017, 18:25   #3657  |  Link
Reel.Deel
Multi-threading syntax in AviSynth+ is different, see wiki pages for more information: http://avisynth.nl/index.php/AviSynth%2B#MT_Notes
Reel.Deel is offline
Old 8th October 2017, 18:26   #3658  |  Link
LigH
LigH's Avatar
There is indeed no function named "SetMTMode" in AviSynth+.
See AviSynth Wiki: AviSynth+ – 4. MT notes
Furthermore, use Distributor() only when you are really sure you know why. If not, it may multiply threads unexpectedly.
LigH is offline
Old 8th October 2017, 21:48   #3659  |  Link
Weirdo
Thank you both, I made the corrections and it works fine.
Win 10 Pro x64
Weirdo is offline
Old 10th October 2017, 16:08   #3660  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Can someone give me a dumbed-down summary of the different MT modes? I've read this:
http://avisynth.nl/index.php/AviSynt...orrect_MT_mode
But it's not very clear to me. It doesn't really state how the modes work, and especially the bit for MT_NICE_FILTER isn't clear at all on when it should be used, instead focusing on when it shouldn't.
I'm guessing that MT_NICE_FILTER requests multiple frames in multiple threads, but only one instance of the filter, and that MT_MULTI_INSTANCE makes multiple instances, so it's a bit like calling the same plugin multiple times on trimmed/selecteveryed subclips and then joining or interleaving them? Or does it crop frames up into smaller frames then stack them back together, or something? (probably not) And that MT_SERIALIZED is the same as plain old single-threaded AviSynth?
wonkey_monkey is offline
