Old 29th October 2010, 16:35   #9961  |  Link
Ch3vr0n
The ones that are on the very first post and ONLY THOSE. Do not update them ever unless the ones in the first post get updated too. U never bothered to read & follow the instructions in the first post did you ?
Ch3vr0n is offline   Reply With Quote
Old 29th October 2010, 17:34   #9962  |  Link
buerste3
Now i use windows xp 32 bit and everything went great.
So i can use bd rebuilder with these system carefully.
But i need a new pc and i dont know, if i use windows 7 with 32 or 64 bit. Normaly i would use 64 bit. But i read, there are some problems with avisynth, haali media splitter and ffdshow by 64 bit systems. I think Haali wents fine, for avisynth and ffdshow it gives x64 versiones. The ones in the first post are not specialy x64 versions. But it wents also fine?
buerste3 is offline   Reply With Quote
Old 29th October 2010, 18:00   #9963  |  Link
omegaman7
omegaman7's Avatar
People always cringe when they talk about 64 bit LOL! I've been running Windows 7 64bit since early Beta. Best OS i've used. I've only had one hiccup with BD rebuilder. Not sure how it happened either. All I know is that one day 2 of the softwares were not the recommended versions. So I fixed it, configured them, and I was encoding again. Love the Log Jdobbs I've ran loads of 32bit and 64bit programs without issue. Including the apps in the first post of course.
omegaman7 is offline   Reply With Quote
Old 29th October 2010, 18:22   #9964  |  Link
colinhunt
64-bit Windows 7 + 32-bit Avisynth, FFDShow & Haali funktionert sehr gut. Kein problem, mate!
colinhunt is offline   Reply With Quote
Old 29th October 2010, 18:23   #9965  |  Link
Ch3vr0n
It doesnt matter that the ones in the first post are not x64. 32 bit runs just fine on x64. Don't install any other versions then the ones list in the first page. If you do and BDRB doesnt work, dont come crying to jdobbs as he doesnt accept bug reports with versions that arent the recommended ones. I'm using a 64bit system with the tools from the first page and it runs flawless
Old 29th October 2010, 19:45   #9966  |  Link
steveg32
Is it possible to back up 3D Blu-ray movies?
Originally Posted by RCF View Post
Hello jdobbs,
Is it possible to back up my 3D Blu-ray movies (Alice in Wonderland 3D and Avatar 3D) to a BD25? BD Rebuilder tells me that the destination is too small.
Thanks,
RCF
Originally Posted by Ch3vr0n View Post
3D blu-rays cannot currently be processed by BDRB due to the complex nature of 3D discs. Only a 1:1 backup is possible
I backed up My Bloody Valentine 3D to BD-25 and DVD-9 without any problems (both were full backups) and the playback in 3D (and non-3D) was flawless. Why is that?
steveg32 is offline   Reply With Quote
Old 29th October 2010, 20:07   #9967  |  Link
colinhunt
Which My Bloody Valentine 3D was it? The Anaglyphic red/green glasses version or the new version which requires a Blu-ray 3D player and a HDMI 1.4 3D Display?
Old 29th October 2010, 20:54   #9968  |  Link
Ch3vr0n
The only way that was possible is if it was the anaglyph version. 3D discs like the ones that use 3D tech similar to AVATAR CANNOT be backed up as of yet.
Old 29th October 2010, 21:04   #9969  |  Link
HWK
HWK's Avatar
Can anyone post a link HAALI Splitter which works bd-rebuilder. I can't find it on first post of this thread.
HWK is offline   Reply With Quote
Old 29th October 2010, 21:07   #9970  |  Link
JJB
It's the Matroska Splitter splitter mentioned in the first thread. Same program.
JJB is offline   Reply With Quote
Old 29th October 2010, 21:11   #9971  |  Link
HWK
HWK's Avatar
If that case then when inspect.exe is run why it shows HAALI Splitter not installed in my case. Although other software were already installed from first page of this post.
Old 29th October 2010, 21:27   #9972  |  Link
JJB
Try uninstalling it, then delete the left over folder under programs then re-install and run inspect again. Any oddball codec packs installed?
Old 29th October 2010, 22:05   #9973  |  Link
HWK
HWK's Avatar
I think I need to explain little better. I wipe out harddrive and have install programs related to BD-Rebuilder from first post of this thread and inspect.exe they are ok. However I couldn't find halli link on first post in thread. Halli was never install after hard drive was wiped out and still this is the case.
I need to know where I can get the version which will work with Bd-Rebuilder.
Old 29th October 2010, 22:28   #9974  |  Link
setarip_old
setarip_old's Avatar
@HWK
It's referred to as "Matroska Splitter" in Post #1 here...
setarip_old is offline   Reply With Quote
Old 29th October 2010, 22:54   #9975  |  Link
HWK
HWK's Avatar
Originally Posted by setarip_old View Post
@HWK
Ok, in that case I can ignore Halli Splitter being not installed option as shown by screenshot and Bd-Rebulder will continue to work.
Old 30th October 2010, 08:04   #9976  |  Link
buerste3
Thanks guys. Danke Leute
Than i will use Windows 7 64 bit.
But i have another problem.
With my system now, xp and the ones from the first post, i can not convert dts to ac3. I tested everything in ffdshow and everything in bdrebuilder. But everything the same error.
I will show you:
[08:42:51] BD Rebuilder v0.34.09 (beta)
- Source: SAMPLE
- Input BD size: 0,03 GB
- Approximate total content: [00:00:25.275]
- Target BD size: 4,44 GB
- Windows Version: 5.1 [2600]
- Quality: Good (Very Fast), ABR
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=448
[08:42:51] PHASE ONE, Encoding
- [08:42:51] Extracting A/V streams [VID_01900]
- [08:42:52] Reencoding: VID_01900 (1 of 2)
- [08:42:52] Collecting video information
- [08:42:52] Keeping original video (no reencode)
- [08:42:52] Reencoding audio tracks (if req'd)
- [08:42:52] Multiplexing M2TS
- [08:42:53] Extracting A/V streams [VID_00000]
- [08:42:55] Reencoding: VID_00000 (2 of 2)
- [08:42:55] Collecting video information
- [08:42:55] Keeping original video (no reencode)
- [08:42:55] Reencoding audio tracks (if req'd)
- ERROR in attempt to reencode audio (AFTEN) [AUD_00000__4352.AVS]
[08:42:55] - Failed to reencode audio, aborted
[08:44:06] BD Rebuilder v0.34.09 (beta)
- Source: SAMPLE
- Approximate total content: [00:00:24.816]
- Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640
[08:44:08] PHASE ONE, Encoding
- [08:44:08] Extracting A/V streams [VID_00000]
- [08:44:10] Reencoding: VID_00000 (1 of 1)
- [08:44:10] Collecting video information
- [08:44:10] Keeping original video (no reencode)
- [08:44:10] Reencoding audio tracks (if req'd)
[08:44:10] - Failed to reencode audio, aborted
[08:44:48] BD Rebuilder v0.34.09 (beta)
- Source: SAMPLE
- Resuming from previously started job.
[08:44:54] PHASE ONE, Encoding
- [08:44:54] Reencoding audio tracks (if req'd)
[08:44:55] - Failed to reencode audio, aborted
[08:45:47] BD Rebuilder v0.34.09 (beta)
- Source: SAMPLE
- Input BD size: 0,06 GB
[08:45:48] PHASE ONE, Encoding
- [08:45:48] Extracting A/V streams [VID_00000]
- [08:45:50] Reencoding: VID_00000 (1 of 1)
- [08:45:50] Collecting video information
- [08:45:50] Keeping original video (no reencode)
- [08:45:50] Reencoding audio tracks (if req'd)
[08:45:50] - Failed to reencode audio, aborted
[08:46:23] BD Rebuilder v0.34.09 (beta)
- Source: SAMPLE
[08:46:25] PHASE ONE, Encoding
- [08:46:25] Reencoding audio tracks (if req'd)
[08:46:26] - Failed to reencode audio, aborted
Can everything help??
Old 30th October 2010, 08:04   #9977  |  Link
Sharc
3 minor issues:
1. Movie only. When I resize to 720p and set in TWEAK_PASS_ --ref 6 it seems not to be accepted by BD RB although up to 6 ref frames are compliant for 720p as far as I know. Is the current limitation to 4 refs intentional?
2. I get the message "TSMUXER could not resize, adjusting" and the ErrLog.txt "ExtractAudioSubs() 00075 1605".
Does this happen when TSMUXER cannot reduce the sups to 720?
What does '...adjusting' do?
(It seems that the feature is reduced to 720, encode is still running ....)
3. This has possibly been asked before: It would be helpful for selecting the desired audio if one could for example play the audio by right clicking on the audio stream (similar to the video preview feature).
Old 30th October 2010, 11:22   #9978  |  Link
gg72
Hallo!
I have a problem ("failed video encode") with the full disc rebuild of Universal BD's: Changeling and U2 - 360° At The Rose Bowl. The movie only encode works fine. Here the changelog:
[23:24:13] BD Rebuilder v0.35.01 (beta)
- Source: CHANGELING
- Input BD size: 36,14 GB
- Approximate total content: [02:42:21.106]
- Target BD size: 23,93 GB
- Windows Version: 6.1 [7600]
- SHUTDOWN at completion enabled
- Auto Quality: Good (Very Fast), ABR
- Audio Settings: AC3=0 DTS=1 HD=0 Kbs=640
[23:24:13] PHASE ONE, Encoding
- [23:24:13] Extracting A/V streams [VID_00009]
- [23:31:45] Reencoding: VID_00009 (1 of 6)
- [23:31:45] Reencoding secondary video [TRK_02]
- [23:39:41] Reencoding secondary video [TRK_03]
- [23:46:47] Collecting video information
- Source Video: VC-1, 1920x1080
- Rate/Length: 23,976fps, 204*144 frames
- Bitrate: 18*585 Kbs
- [23:46:47] Reencoding: VID_00009, Pass 1 of 1
- [01:18:17] Video Encode complete
- [01:18:17] Reencoding audio tracks (if req'd)
- [01:23:12] Multiplexing M2TS
- [01:32:23] Extracting A/V streams [VID_00010]
- [01:32:43] Reencoding: VID_00010 (2 of 6)
- [01:32:43] Collecting video information
- Rate/Length: 29,970fps, 8*934 frames
- Bitrate: 11*701 Kbs
- [01:32:43] Reencoding: VID_00010, Pass 1 of 1
- Encode failed. Retrying.
- Reached retry limit. Aborting.
- BD-Rebuilder v0.35.01 (beta)
- AVISYNTH Version: 2.5.8.0, Ok
- HAALI Splitter: Not installed
- FFDSHOW: , not recommended version
- WIN7 preferred AVC CODEC: Ok
- WIN7 preferred VC-1 CODEC: Ok
- WIN7 preferred MPEG2 CODEC: Ok
- FFDSHOW VC-1 set to "wmv9", Ok
- FFDSHOW MPEG2 set to "libavcodec": Ok
- FFDSHOW AVC set to "libavcodec": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[01:32:44] - Failed video encode, aborted
Other full disc rebuilds are fine, I have this problem only with Universal BD's...
gg72 is offline   Reply With Quote
Old 30th October 2010, 11:54   #9979  |  Link
steveg32
The Anaglyphic red/green glasses version. Mahalo for the clarification.
Old 30th October 2010, 13:05   #9980  |  Link
colinhunt
Those might have something to do with your problems.
