16th March 2008, 10:12 | #601 | Link | |
use 'r'
16th March 2008, 10:36 | #602 | Link |
use 'r'
bug report v1.4.5(b)
I've found sync problem with H.264 video:
when muxing video stream with 29,97 fps with 2:3 pulldown flag: - when NOT changing fps then audio goes out of sync (like video is playing at 29.97 fps, but audio is playing at 23.976 fps) - when changing fps to 23.976 (in TsMuxer GUI) then audio stay in sync and playing fine on PC, but when playing on PS3 then video is stattering (like drops every second frame) Then I passed video stream through H264INFO removing 2:3 pulldown. After that muxing with "tsmuxer" gives perfect result. |
16th March 2008, 10:43 | #603 | Link | |
Caped Crusader
16th March 2008, 13:02 | #604 | Link |
hi
i have a little prob with the hd dvd subs i have the hd dvd the kingdom i will use the german subs in evo are 3 subtype in it all in german language 1.FEATURE_1_MERGED.8bitRLC.s04.German.sup 2.FEATURE_1_MERGED.8bitRLC.s24.German PIP.sup 3.FEATURE_1_MERGED.8bitRLC.s30.German Forced.sup what subtype i must use for muxxing with tsmuxxer i will only german language subs when the arabian people talk in arabian what must i doo? many thx |
16th March 2008, 14:10 | #605 | Link | |
16th March 2008, 16:32 | #607 | Link |
hi
ok i have make with supread from hd dvd an bd compatible subtitle forced german subs i muxx video audio and the sub with tsmuxxer plays fine but without subtitels in powerdvd in mpc or zoomplayer i can enable the subs but i cant see the subs where is here the prob? while playing the file with mpc homcinema and laod external subs as srt then i see the subs thx Last edited by napalm-187; 16th March 2008 at 16:40. |
16th March 2008, 17:16 | #608 | Link | |
16th March 2008, 18:44 | #611 | Link | |
That's what I was wishing for. Thanks for your response. |
16th March 2008, 18:45 | #612 | Link | |
16th March 2008, 19:22 | #613 | Link |
you can use TSMuxer to demux just the TrueHD track, just right click over the THD track and select demux to elementary stream, you should also be able to demux the THD track with tsMuxeR by unselecting all the tracks with the exception of the THD track, then pick the demux option below, don't forget to provide a filename for the demuxed track... both ways work, I typically convert the THD track to DTS and remux back with the video stream into an m2ts container, works well...
16th March 2008, 20:44 | #614 | Link | |
In that case, the file hiccups at every intersection. No problem with MPEG2. Anyone can confirm ? Thank you. |
17th March 2008, 01:44 | #615 | Link | |
copy /b all the segments to one main m2ts, then used TSRemux as the previous (pre 1.5.0) of tsMuxeR would not accept LPCM, I removed un-needed tracks and ended up with VC-1, LPCM, AC3 (640Kps) and a PGS stream, as I said works perfectly on the PCH... |
17th March 2008, 03:32 | #617 | Link |
Bug Report
Edit:
Never mind... it ended up being a bug in the H264 analysis tool. I still think it would be a good idea to add an option which does not modify the elementary stream in any way. It just makes no sense for a muxer to modify the input data unless the user requested a change in format, fps, etc. -Mark Last edited by wizziwig; 17th March 2008 at 04:08. |
17th March 2008, 03:54 | #618 | Link | |
17th March 2008, 10:18 | #619 | Link |
problems transmuxing from .evo to transport
Hi. Im trying to transmux a HD-DVD source from a 12GB evo file to .ts and im getting this error ca. 15% out in the process:
Reading buffer overflow. Possible container streams are not syncronized? Try to increase read buffer size or demux selected streams to single files. File name: C:\movie.EVO Any idea? Where can i increase the buffersize? |
17th March 2008, 13:51 | #620 | Link |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 17th March 2008 at 14:04. |
tsmuxer |
