Old 9th December 2019, 23:07   #7241  |  Link
benwaggoner
Originally Posted by markiemarcus View Post
I read somewhere on here a while back that 10-bit playback on 8-bit displays can be a little unpredictable.
Yeah. If a display controller truncates instead of dithers, you might get more banding than if the conversion to 8-bit was done pre-encode.
Sent from my SM-T837V using Tapatalk
Ben Waggoner
My Compression Book
Old 9th December 2019, 23:09   #7242  |  Link
benwaggoner
Originally Posted by _kermit View Post
Tried now:
--vbv-maxrate 15000 --deblock=-2:-2 --amp --selective-sao 1 --rskip --output-depth 10 --aq-mode 3 --qg-size 64 --preset slower --crf 20
and
--vbv-maxrate 15000 --deblock=-2:-2 --amp --selective-sao 1 --rskip --output-depth 10 --aq-mode 1 --qg-size 64 --preset slower --crf 18
yes, 3.2.0.18
still shows. It may be less, but still obvious
Interesting part is that it only is that obvious on that region with black/purple texture
it is grainy, but there is worse.
does it help uploading the original and encoded clip?
Onedrive working?
If it is in black/purple, try --aq-mode 3. It doesn't take much blocking in the very low luma range to show up as an artifact with 8-bit SDR.
Ben Waggoner
My Compression Book
Old 10th December 2019, 08:01   #7243  |  Link
alexantr
alexantr's Avatar
...I'm getting more pleasing and accurate results from RDOQ Level 0, maxing out Psy-rd, and using a lower CRF to arrive at the same file size...
rdoq-level=1 can help to retain small noise looking like dither noise. Keep original psy-rd value and try to tune psy-rdoq from 0.5 to 1.0.
alexantr is offline   Reply With Quote
Old 10th December 2019, 10:18   #7244  |  Link
markiemarcus
Oh definitely, Level 1 I've had better experience with in the past, particularly at lower values of around 0.5. I'm just scratching my head as to why the default is Level 2; I'm struggling to see any positives. It's also slower IIRC.
However, even with Level 1, RDOQ at 1.0 and Psy-rd at 2.0, I'm able to get better grain motion and more consistent results at the same filesize with Level 0 and massively elevated Psy-rd values instead.
It just doesn't seem right. Surely I'm not the only one who's finding this?
markiemarcus is offline   Reply With Quote
Old 11th December 2019, 08:36   #7245  |  Link
RainyDog
Frustratingly there's just no perfect PSY/RDOQ setting with x265 unfortunately
But hours (probably amounting to days...) of testing has led me to conclude that the most balanced for most sources at mid-high bitrates is usually psy-rd 1.0, psy-rdoq 1.0 and rdoq-level 2.
I know what you mean with rdoq-level 0 though... In motion, it can look the most consistent and easiest on the eye. But if you compare encode frames to source frames you'll never get transparency with level 0. There seems to be some high-pass filter that sort of dulls grain and high-frequency detail even with psy-rd turned up to 5.0.
With rdoq-level 2 and psy-rd 1.0 plus psy-rdoq 1.0, you can usually see that it at least tries to replicate the source even if that can lead to ugly and sometimes weird artifacts if your bitrate isn't sufficient enough to support it.
As for rdoq-level 1, I find this to just be a rougher, less refined or accurate level 2.
If you can get your hands on any internal 'haich dee bits' x265 encodes for, ahem, research purposes then you'll find that they all use rdoq-level 2 with psy-rd 1.0 and psy-rdoq 1.0. Give or take anyway... I've seen psy-rd 1.2 + psy-rdoq 1.1 and psy-rd 1.4 + psy-rd 1.0 but always within those boundries.
They always consistently use no-cutree and usually qg-size 8 too. AQ mode 1 or 3 and often lots of zones as well. EDIT: and always CTU 32 and no-rskip.
RainyDog is offline   Reply With Quote
Old 11th December 2019, 09:19   #7246  |  Link
markiemarcus
There is definitely some sort of lpf noticeable with level 0 and I totally agree that achieving transparency is pretty much impossible that way. But I still think that subjectively it often looks better, almost always so if you're trying to preserve dither. I don't mind the slight dulling of grain assuming what is there is uniform, the pitch fine and the resulting encode looks nice. It's so impressive to see the bitrate reduction you can achieve, even on grainy content, at bitrates where x264 completely falls apart.
I'm just seeing a lot of instances where RDOQ looks pretty nasty, regardless of the bit rate or values used.
Will definitely check out your suggestions though. Appreciate it.
Old 11th December 2019, 10:38   #7247  |  Link
Yanak
Hello,
is anyone having issues trying to build with Intel compiler 2019 integrated in Visual studio 2019 ?
Building the multilib with VS 2019 works,
building the multilib with LLVM Clang integrated inside Visual Studio 2019 works too, ( either the clang 9.0.0.0 version from the VS2019 installer or the last 10.0.0 version of LLVM installed separately and integrated in VS2019 with the LLVM2019 extension from the VS Marketplace. )
But trying to use the Intel compiler brings loads of errors and the build fails, tried also to make the single 10Bits build and it fails too.
Was able to use ICC 2019 inside VS2017 some months ago and it was building correctly so I'm not sure if it's a problem on my side only or more general issue on the code, but after dozen of tries i can't find out what is wrong with Intel compiler so i ask here in case anyone have an idea.
Thank you .
Yanak is offline   Reply With Quote
Old 11th December 2019, 18:24   #7248  |  Link
_kermit
can you provide the complete command line you prefer?
_kermit is offline   Reply With Quote
Old 12th December 2019, 14:29   #7249  |  Link
RainyDog
Sure, the below is always my starting point then I tweak from there if necessary with a dial or two down on --aq-strength and/or a notch or two up on --psy-rd. This is for a broad range of film sources at 1080p resolution.
--preset slow --output-depth 10 --rd 3 --ctu 32 --limit-refs 1 --limit-tu 4 --tu-intra-depth 4 --tu-inter-depth 4 --no-rect --b-intra --aq-mode 1 --aq-strength 0.9 --ipratio 1.3 --pbratio 1.2 --no-cutree --subme 4 --merange 40 --max-merge 4 --weightb --bframes 10 --rc-lookahead 60 --lookahead-slices 0 --deblock -3:-3 --selective-sao 0 --no-sao --psy-rd 1.0
Old 12th December 2019, 15:41   #7250  |  Link
redbtn
redbtn's Avatar
I often see this also. But I don't understand why they use it. I did tests and noticed that CTU 32 and qg-size 8 is not better than CTU 64 qg-size 32 (and sometimes even worse). And also it seems to me that aq-mode 2 is better than 1. I'm not a professional, it's only my humble opinion.
Ps: I looked at your settings, do you sure that ctu 32 merange 40 is better for 1080p than ctu 64 merange 57?
redbtn is offline   Reply With Quote
Old 12th December 2019, 19:42   #7251  |  Link
markiemarcus
Found the same thing. I even find CTU 32 worse for grain retention, though it does make it look less boxy if using RDOQ Level 2. No-cutree I've seen cause issues in animation.
Aq mode 1 I find more consistent than 2 if the source has intermittent low luma. Aq mode 3 obviously works well, though in my experience not always better than Aq-mode 1. Metrics don't tell the whole story.
Old 12th December 2019, 19:48   #7252  |  Link
markiemarcus
I see I'm not the only one who disables rect! The difference is so fractional on most content I've tested.
Old 12th December 2019, 20:45   #7253  |  Link
redbtn
redbtn's Avatar
Aq mode 1 I find more consistent than 2 if the source has intermittent low luma. Aq mode 3 obviously works well there, though in my experience not always better than Aq-mode 1. Metrics don't tell the whole story.
I use aq-mode 2 for HDR 10bit encodes. For SDR maybe better 1, I didn't much tests with SDR.
Any thoughts about using no-rskip? Does it make sense?
I use no-rect too.
Old 12th December 2019, 22:23   #7254  |  Link
markiemarcus
I use no-rect too.
I have zero experience with HDR I'm afraid, but at least a few hundred hours with SDR. I've heard a number of people say that too, though.
I never bother with no-rskip. Rskip works very well. Some other preferences:
I use rdLevel 4 and almost exclusively --limit-refs 1. If the performance impact weren't so dramatic, I'd use rdLevel 6. It's just better, there's no getting around that, but it is awfully slow.
Considering the performance boost, early-skip isn't half bad either. You seem to be able to overcome most of its shortcomings with a 0.1 to 0.2 drop in CRF, which is not the case with some of the other settings.
I've seen animated content that benefits from Sub-me 7 (yes, really), RC lookahead 80 and lookahead slices 1. It really doesn't hurt performance all that much either, but otherwise, the slower preset values for those are spot on.
I've seen reproducible grain freezing and other blocking craziness with tu-intra 4, tu-inter 4 so I'm weary of anything other than 1. Limit-tu I don't know what to make of. I don't fully understand it either, or its relation to intra/inter. If the content is super flat animation and clean as a whistle, values of 4, 4 and 4 seem to work well enough.
--cbqpoffs -1 --crqpoffs -2 works well for animation. x265 seems to struggle with deep reds without this.
-tskip is nice. t-skip-fast causes problems in animation.
--aq-motion is decent with Aq-mode 1 and generally allows a 0.5 drop in CRF for the same filesize, for which there is a noticeable benefit. I don't understand the dislike or distrust of the feature.
--weightb I think is a must, along with b-intra.
Both Rect and Amp are of extremely limited use IMO. Perhaps it's just the content I've been testing. I've seen comparable results with both disabled, to having both enabled along with limit-modes. With --no-limit-modes, yes, the difference I could spot, but it's dog slow. This was on animated content though; I haven't tested that on live action.
6 bframes I think is a good compromise for most content, though I've seen some small benefits to using double that on animated content.
--selective-sao 1 is nice and now my go-to.
qg-size 64 works well, even at 1080p. It's great on animated content.
I don't go higher than max-merge 3. I've seen 4 and 5 produce worse results than 3 during fast motion in animated content. I don't know why.
As I'd mentioned previously, I'm really not a fan of RDOQ Level 1 or 2. I much prefer Level 0 with much higher Psy-rd values instead. I understand why people like it, I just think it's ugly.
--deblock -4:-1 on grainy or dithered stuff, --deblock -3:0 or -2:0 otherwise.
--fades seems to work well.
Default Me range and Star. UMH is better, but it's fractional.
refs 4 is generally speaking adequate IMO.
I keep strong-intra-smoothing on.
Aq strength is difficult. Generally the default or 0.9 is fine, but if the content is super, super grainy, I've gone as low as 0.6 and put the difference into a lower CRF for better results.
So my settings are a bit weird. I've arrived at them from probably thousands of 2 pass tests over a few years, aiming for 2:1 over x264 and no more.
Old 12th December 2019, 23:27   #7255  |  Link
redbtn
redbtn's Avatar
Thank you for very useful information! I'll try selective-sao 1 and tu intra inter 1 (if I recall correctly, it's gives 8-10% more bitrate but 10% faster).
I didn't find on my tests that --strong-intra-smoothing is giving better results, but maybe I was wrong. My target bitrate is 16-18mbps for 1080p, so maybe it's a reason?
Old 13th December 2019, 01:35   #7256  |  Link
markiemarcus
No sweat. I'm only guessing the CRF you're going to need. The results are very sensitive to it; very fine noise requires a low CRF. I'd say that the useful range is CRF 16 to 19. Bear in mind that there's no RDOQ level 2, which immediately knocks around 0.6 off the CRF of any corresponding preset that uses it and another 0.6 from aq-motion. CRF 16 here is more like CRF 17.5 by default.
--crf 16 --preset slow --output-depth 10 --limit-refs 1 --limit-tu 4 --tu-intra-depth 3 --tu-inter-depth 3 --rdoq-level 0 --no-rect --tskip --early-skip --b-intra --qg-size 64 --aq-strength 0.7 --cbqpoffs -1 --crqpoffs -2 --aq-motion --subme 7 --weightb --bframes 6 --rc-lookahead 80 --lookahead-slices 1 --deblock -4:-1 --psy-rd 5 --fades --selective-sao 1 --aq-mode 1
Everybody seems to have their own way of doing these things, this just happens to be mine. It's fast also. There's no reason why Aq-mode 2 wouldn't work if that's what you want, but it is a little less detailed on SDR sources from what I've tested, especially with regards to dither preservation. --qg-size 32 also works, but I prefer the look of 64 and I'd swear it's more detailed in low luma and holds together the deep reds better. --aq-mode 3 also works well if you prefer.
It's worth tuning aq strength. The value depends on the source obviously, but 0.7 is a good a place to start.
RainyDog's suggestion looks really nice and is far better than the default IMO. CRF 19.5 there is about the same size as CRF 16 here. Most of my testing was done on grainy animation, or animation with a lot of dither. They're quite different looking.
Old 13th December 2019, 09:08   #7257  |  Link
RainyDog
I've just done another test of CTU 32 vs 64 on my current encode and it's really just splitting hairs at the bitrates I aim for at least. Some parts of the frame might appear slightly better on extreme scrutiny with one then the other but it's generally a wash other than CTU 32 is slighty faster.
Me-range 40 is about the cut off point where you just get diminishing returns for 1080p content at least.
Qg-size is still a bit of ahead scratcher for me. In theory, 8 should yield bigger size encodes with the most detail retention but at the expense of more artifacting. Yet everytime I've tested at the same settings and CRF, qg-size 16 comes out the biggest, size 8 by far the smallest with 32 sat somewhere in between! So I usually just leave it at the default of 32.
Old 13th December 2019, 09:14   #7258  |  Link
LigH
LigH's Avatar
@redbtn: Thank you for considering not to quote a several pages long post to reply only briefly. Often a @name is sufficient. Or trim the quote to a relevant part.
New German Gleitz board
Old 13th December 2019, 09:15   #7259  |  Link
RainyDog
You do realise that all selective sao 1 does is apply SAO to I-frames which are less than 1% of your encode, right?
SAO really needs a strength setting more than anything else. I feel it could be highly useful for all content if it could be tuned.
Old 13th December 2019, 10:29   #7260  |  Link
markiemarcus
Yup! But I agree.
