6th October 2005, 02:55 | #61 | Link |
I followed the guide up to the point where I put the sst into MuxMan. MuxMan showed a "Free" at the sub-pic file name. I saved the project and edit the mxp. I found that there is no "Duration" under "Item=Sub-Picture Stream". So I add "Duration=Default". Reopen it in MuxMan and start. MuxMan stopped with message "cannot reopen Free". My sst is the same as the NTSC version posted in this thread and I am sure I put a space after the bmp file name. I've tried "." and the exact path in the "Directory", both upper and lower case, but still the same. It must be my sst, but I don't know what. Please help.
6th October 2005, 07:50 | #62 | Link |
I was having some funny issues with my .sst file so to be on the safe side i made sure that there were no spaces in directory/file names, as well as the space i used a carriage return. The space is important as the last character on the line is stripped.I havent back tracked to see if having spaces in the directory/file name causes issues. Maybe mpucoder can verify this?
My .sst file now works fine. To check i have a space at the end of a line i always get cursor to front of line in question and then press the "end" key. |
6th October 2005, 14:49 | #64 | Link |
There have been some fixes to sst file parsing in 0.15, but spaces in the file names was fixed a long time ago.
You can see how an sst file was interpretted by looking at the mxp file, as it expands the sst into mxp. Also there is no duration to a stream, only each play item. |
6th October 2005, 15:58 | #65 | Link |
I don't have any play item in my mxp. Here is my sst
st_format 2 Display_Start forced TV_Type NTSC Tape_Type NON_DROP Pixel_Area (2 478) Display_Area (0 2 719 478) E2 (255 255 255 = = =) E1 (0 0 255 = = =) PA (0 0 0 = = =) BG (255 0 0 = = =) Directory e:\project\demuxed_menu Color (1 1 1 1) Contrast (0 0 0 0) 1 00:00:00:00 00:01:00:00 sub2.bmp and here is the relevant part of mxp Item=Sub-Picture Stream { Stream Number=1 Language Extension=1 Display Mode=unspecified } Item=Sub-Picture Stream { Stream Number=2 Language Extension=1 Display Mode=unspecified File=E:\project\demuxed_menu\[1]_VTS_01_1.21.sup } here is the MuxMan log MuxMan version 0.14g Opened script file E:\project\demuxed_menu\sub.mxp Accepted image E:\project\demuxed_menu\language2.bmp Opened sub 2 file E:\project\demuxed_menu\[1]_VTS_01_1.21.sup. 22:57:19 Begin multiplex. Maximum audio duration 0 fields. unable to reopen free. Please help. |
6th October 2005, 16:56 | #66 | Link |
Looks to me like you are using a project file you created using a differnet sub filename...
the file name your .sst file is using is sub2.bmp but the .mpx file is using something totaly different. It must match the file name used in the .sst file |
7th October 2005, 15:06 | #67 | Link |
No. The demuxed vob gave me 2 sup files: 20.sup and 21.sup. I use the sst and 21.sup in MuxMan. You can see two sub-pic stream in the mxp file. But the problem is MuxMan didn't seem to able to open the sst (I mean it can open the sst but not the sub2.bmp). PLease read my problem in my previous post.
7th October 2005, 17:49 | #68 | Link |
I'm sorry but if you have followed the instructions then you should be dealing with 2 bmp files, The first the main bmp refered to as bg.bmp and the second which is stripped from the VOB using subrip called sub.bmp.
If you havent ended up with 2 .bmp files you are doing something slightly different |
7th October 2005, 23:23 | #69 | Link |
@senderj
You only need a .SST file if you want to mux a BMP as subpicture. The .sup files are the raw subpicture frame data of the VOB file plus a header. You can't edit them with a graphic editor, but if you only want to change the background picture, it is'nt necessary of course. You can load .sup files directly into MuxMan as subpicture stream. goonix |
8th October 2005, 08:08 | #70 | Link |
I use sst and a sup file because I want to try modifying one sub first. My problem is on MuxMan (seems) not able to read the sst file correctly. Anyway, I have tried to use sst only. I note down what I did (relevant part only) and repeat my question here:
Let me start at after I got the menu background bmp and extracted the menu vob. 1. I then use SubRip to output sub00.bmp and sub01.bmp which correspond to ID 20 and 21. 20 is for 4:3, wide, and LB. 21 is for PS. I got my first problem here since after I click verify, SubRip shows "00-????" and "01-????" in the pull down, instead of 20 and 21. Don't know why. 2. I edit both the background bmp, sub00.bmp and sub01.bmp. What I did was to change the word "Espanol" to "Chinese" on both background and highlight (sub). 3. I copy the sst in this thread, modify it to become sub00.sst and sub01.sst. This is the sub00.sst Code:
st_format 2 Display_Start forced TV_Type NTSC Tape_Type NON_DROP Pixel_Area (2 479) Display_Area (0 2 719 479) E2 (255 255 255 = = =) E1 (0 0 255 = = =) PA (0 0 0 = = =) BG (255 0 0 = = =) Directory E:\project\demuxed_menu Color (1 1 1 1) Contrast (0 0 0 0) 1 00:00:00:00 00:01:00:00 sub00.bmp 4. I open MuxMan, use the background as video. I don't have audio so I skip it. I use sub00.sst in Sub1. MuxMan showed "20" against "Track 1". But MuxMan showed "Free" in the sub file name and the "PS" "LB" "WIDE" buttons were disabled. I ignore it and use sub01.sst in Sub2. MuxMan put "21" in "Track 2" and again showed "Free" in filename. The instruction said I am suppose to select the buttons according to Step A (PgcEdit), but they are not available to me. What's wrong? 5. I save the project. The mxp is this: Code:
Item=Sub-Picture Stream { Stream Number=1 Language Extension=1 Display Mode=unspecified } Item=Sub-Picture Stream { Stream Number=2 Language Extension=1 Display Mode=unspecified } Code:
Item=Sub-Picture Stream { Stream Number=1 Language Extension=1 Display Mode=Only Letterbox Item=Sub-Picture Play { File=e:\project\demuxed_menu\sub00.bmp Start=00:00:00:00 (0) Forced Start=Yes Time Code=NTSC drop Duration=Default Origin=0,2 Display Area=0,2,719,479 Color 1(Pa)=0000ff = & & Color 2(E1)=000000 = & & Color 3(E2)=ff0000 = & & Color=1 1 1 1 Contr=0 0 0 0 } } Item=Sub-Picture Stream { Stream Number=2 Language Extension=1 Display Mode=Only Panscan Item=Sub-Picture Play { File=e:\project\demuxed_menu\sub01.bmp Start=00:00:00:00 (0) Forced Start=Yes Time Code=NTSC drop Duration=Default Origin=0,2 Display Area=0,2,719,479 Color 1(Pa)=0000ff = & & Color 2(E1)=000000 = & & Color 3(E2)=ff0000 = & & Color=1 1 1 1 Contr=0 0 0 0 } } 8. I click Start to generate the DVD files. But it halted with a line at the end of the MuxMan.log: "SPU error, , encoded line exceeds 1440 bits." Can anybody help me on this? |
8th October 2005, 08:58 | #71 | Link |
@goonix
I didn't know you could use .sup directly with muxman, i learn something new every time i come to this site! With regard to changing just the BG.bmp i still find it quicker to use the relevant part of this guide BUT for doing sub.bmp this guide is way Kewl |
8th October 2005, 13:32 | #72 | Link | |||||
@senderj
Don't care about the question marks in SubRip. Quote:
If you follow the mini-guide step by step and the explanations above, you should master this challenge. You are on the right way... goonix |
8th October 2005, 17:10 | #73 | Link |
The log (c:\muxman.log) might give you and me some more information (especially version number and file reject messages). But if it says "unable to reopen free" it means it was unable to open the bmp. Make sure there is a cr/lf after the bmp name (check in notepad or wordpad by opening the file and hitting crtl end, the cursor should be at the left below the last line).
9th October 2005, 09:26 | #74 | Link |
I finally find out the reason of the "free" problem in my sst. There is a space at the end of the "Directory" line. I delete it and MuxMan is able to show the file name after I choose the sst. However, the "WIDE" "LB" "PS" buttons are still disabled. I've checked my sst over and over again but didn't find anything wrong. I did some more test on my case and sum up my observations here hoping that you can help me.
a. Muxman can now open my sst and find the bmp file name to display. But the "WIDE" "LB" "PS" buttons are still disabled. b. Nevertheless, I save the muxman project and edit the mxp as in mpucoder's post. c. But anytime I use two sub-pic, Muxman is halted with "SPU error, , encoded line exceeds 1440 bits." I am using 0.14g. d. If I only use one sub-pic, Muxman can produce the files. e. Then I proceed to complete the rest of the steps with Muxman's output: replace vob, put back the menu stuff etc. The final DVD works well, except the highlight of the modified menu (which is a language selection menu). The highlight shows up as if some horizontal lines are filtered off. And the most interesting thing is, the remaining lines is showing the characters of the main menu rather then those in the language menu. f. I want to check what has been muxed into Muxman's ouptput. So with Mxuman's output (as in Point d above), I extract the vob in the same way as I extract the menu vob from the original DVD. Then I use SubRip to rip the sub to bmp. But SubRip stopped at 70% then nothing happen. It didn't complete, didn't show the sub on screen and didn't produce the bmp. g. Without success in f). I do the same using the final DVD files instead. This time I can produce the bmp. But it is not the same as the one I put into sst. It looks as if some bits have been shifted. Here is the link http://home.netvigator.com/~zarino/abc.bmp and here is the edited sub I put in MuxMan http://home.netvigator.com/~zarino/sub00.bmp My sst and mxp can be found here http://home.netvigator.com/~zarino/sub.mxp http://home.netvigator.com/~zarino/sub00.sst Can somebody please let me know what's wrong with my files? Oh! forgot about the Muxman log, which is the one successful (with one sub) http://home.netvigator.com/~zarino/muxman.log Last edited by senderj; 9th October 2005 at 09:29. |
9th October 2005, 13:53 | #75 | Link | ||||
@senderj
Conclusion: All your problems seems to come from a wrong subpicture format. If you have managed this issue, then you will have success. Good luck and let us stay informed! goonix |
10th October 2005, 21:25 | #76 | Link |
@goonix
I got "encoded line exceeds 1440bits" error when i first tried to use your guide. I saw it once and corrected somehow but cannot remeber what i did. I have tried now everything works for me to recreate the problem but cant. I was using 0.14g only mux'ing one sub pic and bg bmp no audio, i suspect it was something to do with the .mpx file as am sure when i stopped using it .mxp file. The problems with senderj abc.bmp are to do with the way the bmp file is saved. That is excatly the issue i was getting before using photoshop and save as os/2 bmp |
13th October 2005, 00:29 | #78 | Link |
idk guys i just can't get this to work, i follow it to a T (or atleast i think i do) and all i get is a still menu with music.
I am trying to add audio to an edited background pic, i extract the vob than i use subrip to rip the subpics than i use muxman to add it all back together and yes i followed those instructions to a T aswell. Finally i copy it back to my VIDEO_TS folder and it has the music but isn't a menu anymore, even PGCEDIT shows it not as a menu, i can't click on anything, no highlights etc. I DO know that i would have to use PGCEDIT in order to get the hotspots back but thats not my prob right now, any help would be great, thanks. Last edited by qwik3r2; 13th October 2005 at 06:46. |
13th October 2005, 02:03 | #79 | Link |
@qwik3r2
If you don't set the hotspot rectangles in PgcEdit it is'nt a menu. It is only a still picture with a subpicture and audio. PgcEdit writes the button info to the navpacks when you define a hotspot and the button command. Only now you have a real button and a menu. goonix |
13th October 2005, 02:59 | #80 | Link |
I guess you dont' quite understand, after i do everything and use vobblanker to replace the menu cell i load up PGCEDIT and where there was perviously a menu there is no more, so i am doing something wrong between the process here.
This is what i do: I open up VTS_02_0.VOB which contains my menus. I than demux with cell id's using vobedit. The menu i want is a special features menu in which i want to blank out part of it where i deleted buttons and add music. The menu is located in: VTS_02_007.VOB I use subrip to rip the bmp out of it, i do not edit the highlight. I than use muxman and load up the bg image, save the project and edit the mxp so that it says Only Panscan. Load up muxman again and load my bg audio and my .SST file which corrently points to the right dir and right BMP filename. (which is sub.sst and sub.bmp, all files are in the same DIR btw) I than click on the PS button and save the project. I than open up the mxp in notepad again and change the duration to DEFAULT. Open it up again click start and than get my extracted VOB and load up VOBblanker, replace the menu cell with the new one, load up PGC and its not there, all the other menus are there, but not that one, WHAT am i doing wrong? P.S. I DO have preserve menu's ticked in vobblanker and i do have skip all on everything else and i DO have process on the menu. |
