3rd February 2005, 20:50 | #82 | Link | |
Thanks a bunch mpucoder! Jeanl
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. |
3rd February 2005, 21:47 | #83 | Link | |
Just a Member
Well, I've already asked this in other thread, but now we got the support of mpucoder and I'm going to abuse a little more...
I'd like to know how adjust the subs SYNCI pointers (after a strip, i.e.). What I do not know is how to get the End presentation time of the sub. Let say, the PTS is in the PES header, but I'm assuming a sub can be longer than a VOBU so to distinguish between 3fffffff (no sub) and the pointer to the right VOBU, you need to know when the sub start (its PTS) and when it ends (???) Is there other way than decoding the subs?. jsoto Quote:
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ |
3rd February 2005, 22:14 | #84 | Link |
The only way is to decode it. Trace through the DCSQT until you find the last one (points to itself). Duration is the delay * 1024. But if you are not changing vobu_s_ptm or vobu_e_ptm for any vobu all you really need do is adjust the pointers that are there. The timing doesn't change, just the number of sectors in between.
3rd February 2005, 22:35 | #85 | Link | ||
Just a Member
So, thanks again. jsoto
4th February 2005, 07:48 | #86 | Link |
Guys,
I have a beginner's question: In a VOB file, are PTS supposed to be - Continuous (i.e. end PTS from VOBU = begin PTS of next) withing a Cell? - Continuous from Cell to Cell? - None of the above? (can they be non-increasing?????) I have a vob that where the end PTS of 1/2 does not match the begin PTS of 2/1, I'm suspecting this is actually OK, but am I right? If it's OK I need to change things in my code! Jeanl
4th February 2005, 08:55 | #87 | Link | |
Just a Member
What I understand is:
- Continuous (i.e. end PTS from VOBU = begin PTS of next) withing a Cell? Yes. Always in a good authoring - Continuous from Cell to Cell? Yes, if seamless. No, if non-seamless (in a VID change, like yours, for example) EDIT: IIRC, a change in CID (inside the same VID) must be always seamless. Quote:
jsoto
Web sites with my tools http://download.videohelp.com/jsoto http://jsoto.posunplugged.com/ Last edited by jsoto; 4th February 2005 at 10:31. |
4th February 2005, 14:47 | #88 | Link |
Country Member
@jsoto
Because the way cutvob processed, it assumed seamless all the way thru a VOB and this led to crazy times for each VCID, which didn't work. Jean has my menu VOB now - this is what prompted his question. He has changed the code in B0.402 and IMO this works. Regards
Les Only use genuine Verbatim or Taiyo Yuden media. Last edited by blutach; 5th February 2005 at 20:00. |
4th February 2005, 17:15 | #89 | Link |
SCR and pts start at each vob - what you call a vid. They are continuous from vobu to vobu and cell to cell within the vob.
Don't blame me for the confusing names. A VOB is a video object, with a VobID unique to its titleset. VOBs are the video objects comprising one title, usually seamlessly multiplexed, and (I think) is simply the plural of VOB. VOBS are the video objects comprising one titleset (aka VTS) and means "Video OBject Set". Maybe it wasn't so confusing in Japanese, the language of the original specs. |
4th February 2005, 17:44 | #90 | Link |
Thanks a bunch guys, I was on the right track, but not quite there yet!
jsoto, I thought of something yesterday: When srinking a motion to a still, I don't think we need to set the still time in the IFO! How about simply setting the end pts for the first VOBU (the one with the image) to match the end PTS of the original cell? That way, you have a single-frame motion menu, not a still. At the end of playback, the cell command is executed (like in the original) and you go back to the beginning (most likely). No messing with the still time, no messing with the cell playback time (remains the same) no messing with the cell command. Simple, no? Jean
4th February 2005, 17:50 | #91 | Link | |
You got to be kidding man. If they had been trying to confuse us on purpose, they wouldn't have done a better job ! It's all part of a grand scheme of course! Jeanl P.S. Still working on the pic of my hole. Will post over the week end!
4th February 2005, 18:24 | #92 | Link | |
Just a Member
jsoto
4th February 2005, 18:31 | #93 | Link | |
OK, does that mean that if you want to make a slideshow, no audio, you HAVE to use cell still-times? You can't use one VOBU per picture, with an end PTS of however long you want it? Jeanl
4th February 2005, 18:35 | #94 | Link | |
Just a Member
EDIT: I'll look into some examples (menus) I have when I get home. jsoto
4th February 2005, 18:40 | #95 | Link |
Just a Member
Err, the idea I have is to keep all navpacks as they are... Also very simple (although you have to pay the space of the navs)
Even in this case, not sure if a fake VOBU (only a nav) is out of specs or not. jsoto
4th February 2005, 18:45 | #96 | Link | |
But I don't like the idea of keeping all the nav packs, well, you're right, it's not really a big deal if it can fix other issues! Jeanl
4th February 2005, 19:01 | #97 | Link | |
Just a Member
jsoto
4th February 2005, 19:11 | #98 | Link | |
YOu don't have to convince me! It's all the shrink-heads that you have to convince! They're a tough crowd to sell! jeanl P.S. and besides, when everybody has dual-layer burners, the entire question will be mooooot!
4th February 2005, 19:45 | #99 | Link |
PgcEdit daemon
There is a little side effect of keeping the playback as it was instead of converting the cell to a real still frame. When the cell has finished playing, it has to be played again from the beginning (with a LinkTopCell or similar). When this loop back occur, the subtitles are vanishing for one second or two.
Of course, it's not verry important. Note that setting the cell time to 255 will probably fix this problem, even if you keep all Nav Packs. Take care: another scenario exists. If the original cell do not loop back (ie there is no LinkTopCell post or cell command), the playback must continue normally. So, if you decide to set the still time to 255, you must analyse the cell and post commands to be sure that it's safe.
4th February 2005, 19:46 | #100 | Link |
For picture without audio you can use either cell still time (not infinite unless you want user to do something to continue) or empty vobus.
In other words, if, as a result of removing all but an I frame, you end up with nothing in the vobu but the NAV pack, that's OK. A lot of questions could be answered by playing with Muxman Try it with a bmp or 2 and various still times, with and without audio, and VobEdit to see what it all looks like. Last edited by mpucoder; 4th February 2005 at 19:50. |
