27th October 2014, 10:51 | #1121 | Link | |
However, after working normally with it and closing it, it will not open again and crash. I delete the file(s) again and it works, but only once. Even if I just open and close it without working on any files, it will not open a second time unless a delete DVDSubEdit.ini. (leaving DVDSubEditLastFile0 there is not causing problems). Code:
[DVDSubEdit] MainWindowPos=324 101 1110 849 ScanWindowPos=87 63 560 125 LastPPMDir= LastSUPDir= LastSaveSUPDir= LastVOBDir= LastSRTDir= Border4_3S_N=48 Border4_3S_P=58 Border4_3LB_N=60 Border4_3LB_P=72 Border4_3LBS_N=89 Border4_3LBS_P=106 Border1_85_N=10 Border1_85_P=12 Border2_39_N=62 Border2_39_P=74 ForceEvenMoves=0 BitmapSaveType=0 AutoForceDisplayVideo=1 WarnIfOnly4_3=0 NumMRU=1 ZoomWindowPos=87 63 1004 155 OCRRecenter=1 OCRAlignBottom=1 OCRBracketSquare=1 OCRBracketParen=1 OCRBracketNotes=0 OCRItalics=1 OCRRemoveColumns=0 OCRSpaceSelect=0 OCRCaseSensitive=0 CropBackgroundBorderX=1 FrameDownSampling=0 CropBackgroundBorderY=1 WarnOnBitmapImport=1 DropFrame=0 AutoDisplayMode=1 AlertIfClosedCaptions=0 AskForIFOs=1 RetimingSliderRange=10.000000000000 EditBitmapAs24BitBMP=0 UseTruePTS=1 DefaultBackgdColor=3289650 DefaultAutoPixColor=8421504 DefaultAutoBkgColor=16777215 DefaultAutoAA1Color=0 DefaultAutoAA2Color=12632256 BMPEditPath= BMPEditPathArgs=
Win 10 Pro x64 Last edited by Weirdo; 27th October 2014 at 10:53. |
27th October 2014, 15:49 | #1122 | Link | |
It's possible that the mere presence of this file is what causes the issue (even empty) as it's possible that the functgion call used to read it is no longer supported... Jeanl
A few PgcEdit guides. DVDSubEdit a free tool to edit subtitles directly inside the vob. |
27th October 2014, 16:17 | #1123 | Link | |
This worked though: I deleted MainWindowPos and ScanWindowPos and set the .ini file as read-only. Now DVDSubEdit always works. Settings are not saved of course but it's not a major problem and can be easily bypassed.
Win 10 Pro x64 |
27th October 2014, 18:35 | #1124 | Link |
OK then there must be a problem with the call. At the very least, I can put a try/catch around the corresponding calls so it won't crash the app if they fail, but I'm puzzled as to what's causing the crash... These are pretty standard calls...
27th November 2014, 14:57 | #1125 | Link |
I had the same issue as Weirdo yesterday. DVDSubEdit worked a few months ago and it just stopped working. Only thing that I could think of that changed was I did a system restore 2 weeks ago. I also am a Windows 8.1 user. I did the same "fix" as Weirdo where I deleted the DVDSubEdit.ini and it worked. Then the second time I opened DVDSubEdit, it just wouldn't open. Event Viewer didn't show any good information.
I did a windows update and that fixed the issue. The update was KB3000850 which is an optional update. Not really sure what was in it, but it worked. |
27th November 2014, 19:47 | #1126 | Link | |
Jeanl
3rd February 2015, 00:54 | #1127 | Link |
I'm adding subtitles (srt converted to sup) to a letterboxed dvd video. I want the subs visible when dvd zoomed in for widescreen, but would also like them bottom-justified, meaning a single line subtitle will be at the same height as the bottom line of a two-line subtitle. Is there a setting for this in Dvdsubedit? I seem to have adjusted the single-line height accidentally for another subtitle file.
edit: never mind, figured it out. Click "flush" and adjust the borders rather than just the subtitles. Last edited by sadsack; 3rd February 2015 at 15:48. Reason: correct typo |
3rd February 2015, 06:36 | #1128 | Link | |
27th March 2016, 22:19 | #1129 | Link |
I use DVDSubEdit just for detecting "forced subtitles" when backing up my DVDs (i.e. load ripped VOB into DVDSubEdit). It's very useful for the purpose. I recently upgraded to Windows 10, and one feature which doesn't seem to work for me now is that when I load a VOB into DVDSubEdit, the dropdown in the "Subpic selection" section never seems to have any options in it except for "All Streams". Previously I used to be able to select an individual subtitle stream/language here and then tick the "Only show forced subpics" checkbox in order to see which streams contained forced subtitles, if any.
Is there something I'm overlooking? Or is it related to Windows 10? Or is it just something peculiar to the last several VOBs that I've loaded? Thanks for your insight. |
27th March 2016, 23:45 | #1130 | Link | |
- There's no IFO file in the dir of the VOB - DVDSE is not able to locate the IFO for some reason that's related to windows10... I don't have windows10 so I can't reproduce your problem.... I would check whether opening the main IFO (VIDEO_TS.ifo) instead of the VOB helps... Jeanl
28th March 2016, 02:15 | #1131 | Link |
Thanks for the prompt reply, which has allowed me to solve my problem. The problem was not to do with Windows 10, but rather the fact that (coinciding with my move to Windows 10) I've been using a slightly different naming scheme for my VOB files recently - I've started including the PGC number in the filename, for my own reference (like this: VTS_01_PGC_06_1.VOB), but this seems to interfere with DVDSubEdit's ability to autodetect the IFO file in the same folder - I suppose that DVDSubEdit looks for an IFO file with the same name as the VOB file (the same, that is, other than the final number in the filename), but since my IFO filename doesn't include the PGC number, DVDSubEdit isn't making the association between the VOB and the IFO. I've just retried it without the PGC number in the VOB filename, and DVDSubEdit successfully detects the individual subtitle streams as before.
Thanks again. |
28th March 2016, 02:24 | #1132 | Link |
Yes, that's the problem...
