23rd August 2009, 18:24 | #4764 | Link | |
Another Question. If I rebuild a BD with AVS Movie source and target has AVS codec. But if I rebuild the VC-1 movie source is VC-1 but target is AVS , is this right? |
23rd August 2009, 18:37 | #4765 | Link | |
Are you talking about AVC? All output of BD-RB that has been reencoded is in AVC (H.264, MPEG-4, Part 10), that's the only thing X264 will output. By the way, did you reinstall FFDSHOW and AVISYNTH? If not, do so. I also asked if you had installed codec packs and didn't get an answer... I can't help you if you don't answer my questions and don't do what I ask you to do. Last edited by jdobbs; 23rd August 2009 at 18:41. |
23rd August 2009, 19:58 | #4766 | Link | |
I have all tools from your description in the newest version, without AVISYNTH (my version is 2.57) installed. How can i show with codec are installed? My latest installation was the newest FFDSHOW with AVISYNTH 2.57. and the other Tools from your description. Last edited by FZander; 23rd August 2009 at 20:01. |
23rd August 2009, 20:28 | #4767 | Link | ||
23rd August 2009, 20:37 | #4768 | Link |
Ist was my last software installation on this computer before 10 days, but after this i was in holyday to yesterday. And today i have only update your bd rebuilder from 28.03 to 28.04. The one good BD rebuild and the one with wrong aspect ratio, was with rebuilder 28.03.
23rd August 2009, 21:05 | #4769 | Link |
I realize that this is not a bug but it might have relevance. Using the latest version of BD RB (28.04( I just did a backup of Eagle Eye, movie only, to single layer DVD. The result came out quite satisfactory in that there were no viable or audible flaws. The operating system however makes it noteworthy: I was using Windows 7 64 bit which I thought there was an issue with so I guess jdobbs corrected it, and I'm certain that there are others here also having success with it as well.
"Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep." Scott Adams |
23rd August 2009, 21:35 | #4770 | Link |
Encode Failed
File Plays in TMT3 & PDVD so I'm guessing rip is ok.
Running Vista 32 and no changes since doing lots of other encodes. Puzzled! [11:24:18] BD Rebuilder v0.28.03 (beta) - Source: SURVEILLANCE - Input BD size: 18.90 GB - Approximate total content: [01:37:30.845] - Target BD size: 8.06 GB - MOVIE-ONLY mode enabled [11:24:18] PHASE ONE, Encoding - [11:24:18] Extracting A/V streams [VID_00000] - [11:31:12] Reencoding: VID_00000 (1 of 1) - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [11:34:16] - Failed video encode, aborted Options] RESIZE=0 MODE=1 PRIORITY_CLASS=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=1 AC3_REENCODE=1 AC3_640=1 KEEP_HD_AUDIO=0 AVCHD=1 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=8250 TARGET_SIZE=8200 ENCODE_QUALITY=2 VERBOSE_STATUS=1 [Paths] WORKING_PATH=C:\WORKING\ SOURCE_PATH=B:\BD_FULL_MOVIE_BACKUPS\SURVEILLANCE_BD\SURVEILLANCE\ |
23rd August 2009, 23:08 | #4772 | Link |
BIG OOP's : While I was posting my error on here I was also reinstalling ffdshow, hali & all the tools. Surprise! It is all working again. Don't know what Vista stuff was going on in the background to break BD_Rebuilder but now it's OK. Sorry
24th August 2009, 12:01 | #4774 | Link |
total noob here so sorry if wrong section..
used bd rebuiler a few times now and think its awesome but suddenly when i select full back up i get target size too small ??? probally something really simple but looked everywhere for a answer.. again sorry if this is a stupid fault of my own .. regards |
24th August 2009, 13:34 | #4775 | Link |
I have a new problem. I have a movie with vc-1 codec, but movie only is so small, that recoded is not needed. Also the process works fine, but the disk on my Panasonic BD80 not play. Is there an option that i can force recode to AVC. All my movie with AVC as source and target works fine.
24th August 2009, 13:47 | #4776 | Link | |
24th August 2009, 13:50 | #4777 | Link | |
FORCE_ENCODE=1 That should do it. |
24th August 2009, 14:37 | #4778 | Link | |
Is this not works, I test Force recode. |
24th August 2009, 14:44 | #4779 | Link |
south winners '87
hi
i got a big problem with a movie.it seems this blu-ray movie is splitted in multiple m2ts here are the error i can see 08/24/09 [15:28:35] ScanDirectory() 00052 2601 the selected path exceed curent limits it's an exented cut with added cut and normal cut . an example: 00103.m2ts is the extended cut 00104.m2ts is the normal cut can bd rb works on such an extended cut? bye
24th August 2009, 15:05 | #4780 | Link | |
thxs |
