23rd August 2009, 06:38 | #4742 | Link |
Well, I would like to respond to this with my 2 cents, but will refrain...
My first attempt to using the Batch option, I noticed that the subtitle selections, or deselections, are not kept after starting the Batch job. I normally only keep English subs on a movie only backup, but after starting the batch job, all subs were still present in the Workfiles folder. I appreciate all your effort and time, and just want to say |
23rd August 2009, 06:41 | #4743 | Link | |
When a batch job is started, all current settings are saved, then the batch jobs' settings are loaded as they execute. When you finish (or abort) a set of batch jobs, all the original (before batch) settings are restored. Last edited by jdobbs; 23rd August 2009 at 06:46. |
23rd August 2009, 07:17 | #4744 | Link | |
23rd August 2009, 07:26 | #4745 | Link | |
On a side note: I think BD Rebuilder will take the PS3 community by storm once people figure out how easily you can get a Blu-Ray movie into a single .m2ts file and stream it effortlessly from the PC to the PS3 with PS3MediaServer. No real need for burning to a disc at all! Last edited by GaPony; 23rd August 2009 at 07:30. |
23rd August 2009, 10:42 | #4747 | Link |
Hi JDOBBS,
I am a user of BD Rebuider and have to say that it is very useful. The last version I have used in June 2009 was 0.22.03 and no problem at all. I got some new ripp in July 2009 and trying to open BD Rebuider, I got a message: version has expired. So I have downloaded the last one: 0.28.03 and problem (same with 0.28.02 and 0.26.03): 1) all codecs are ok 2) When I double click on the shorcut BD Rebuilder to open it, I get a window on my screen: WINDOWS INSTALLER with the following message --> the feature you are trying to use is on a network resource that is unavailable. Click OK to try again or enter an alternate path to a folder containing the installation package "Fms.msi" in the box below. I never got that message in the past. If I double click several times "cancel" at the end BD Rebuilder is opening but when I use it on different rips I have a problem of multiplexing (see 3) 3) Error message: - Target BD size: 22.46 GB - MOVIE-ONLY mode enabled [21:51:56] PHASE ONE, Encoding - [21:51:56] Extracting A/V streams [VID_00000] - [22:25:56] Reencoding: VID_00000 (1 of 2) - [00:41:09] Extracting A/V streams [VID_00011] - [00:50:38] Reencoding: VID_00011 (2 of 2) [02:22:16]PHASE ONE complete [02:22:16]PHASE TWO - Rebuild Started - [02:22:16] Rebuilding BD file Structure - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta - Matroska parser: read error at pos 9831448576 [02:37:48] - Failed to REBUILD 4) I have tested 3 different ripps and always the same error and with version 0.28.03, 0.28.02 and 0.26.03 5) I have downloaded BD Rebuider (the 3 noted versions) on the laptop of my wife working with vista and no problem at all. And I don't get that window Windows installer on her laptop when I open BD Rebuilder. So I think that the problem is coming from that message of Windows installer but I don't know what it means (I have windows XP Professional). And again in the past no problem and no window Windows installer opening. So I don't understand Could you help me ? Thank you |
23rd August 2009, 11:59 | #4748 | Link |
Hi again JDOBBS,
I have another question. I can see on your new version, the new encoder setting "High-Speed Option (BD25)". What is it? I have tried it (movie only back up) and wrote a BD 25 but I have the feeling that I have lost in Quality (picture). I am using normally the option High Quality (Default) and movie-back up only and write on BD-25. |
23rd August 2009, 13:36 | #4749 | Link | |
23rd August 2009, 14:01 | #4751 | Link | |
I would uninstall any "codec packs" you've downloaded. I would also reinstall FFDSHOW (to override any changes the other software has modified). |
23rd August 2009, 14:08 | #4752 | Link | |
One other thing I have to look at is selecting audio/subs by MPLS rather than M2TS. Right now someone who is unfamiliar with the structure could set different audio for individual parts of a playlist (individual M2TS files), so it could switch back and forth between languages as it plays. Right now it goes back to what you have configured in SETUP when it loads them for batch processing. I'll have to figure something out. Last edited by jdobbs; 23rd August 2009 at 14:23. |
23rd August 2009, 15:31 | #4753 | Link |
Since subtitles usually take up very little space, this is not a problem, even for BD-5. It was just an observation I made from a first time test of this new feature. It would be a concern if this happened for audio selections though.
23rd August 2009, 15:54 | #4754 | Link | |
Ok I will investigate. Thank you What about ma question on High-Speed Option (BD25)? When do you use that option? No lower quality of picture? |
23rd August 2009, 17:02 | #4758 | Link |
I found a second disc that wasn't able to work.
[11:56:42] BD Rebuilder v0.28.04 (beta) - Source: BSG_S4_AND_A_HALF_D1 - Input BD size: 43.74 GB - Approximate total content: [04:56:21.605] - Target BD size: 22.90 GB - Resuming from previously started job. [11:56:43] PHASE ONE, Encoding - [11:56:43] Reencoding: VID_00050 (3 of 16) - Encode failed. Retrying. - Encode failed. Retrying. I noticed that in cases where the encode failed, the file itself fails to play as a file, for example on Windows Media Player |
23rd August 2009, 17:10 | #4759 | Link | |
If you're using Windows 7... you need to search the thread and find links to the registry patches that have to be done. |
23rd August 2009, 17:11 | #4760 | Link | |
