Old 23rd March 2009, 08:35   #3001  |  Link
mrr19121970
I just tried it with a 4gb split and a 1gb source. I had 4 CLPI files instead of 1 and the 00001-00003 had a 0 byte length
mrr19121970 is offline   Reply With Quote
Old 23rd March 2009, 09:30   #3002  |  Link
idbirch2
Roman has assured me that this is just an internal test version and the .split.1, .slpit.2 etc filenames won't be in the next proper release.
idbirch2 is offline   Reply With Quote
Old 23rd March 2009, 15:52   #3003  |  Link
kolak
Originally Posted by setarip_old View Post
@kolak
Although a logical presumption, you are misinterpreting the numbering being used. Version 1.8.8 is an OLDER version than version 1.8.35.
(In the logical world, 1.8.8 would have been named version 1.8.08)
Andrew
Old 23rd March 2009, 16:42   #3004  |  Link
Chumbo
Chumbo's Avatar
Originally Posted by moleyman69 View Post
Is the file corrupt for something? I can't download it via IE or FireFox. Both crap out at the very end when trying to save it. Anyone else having this issue?
Chumbo
Chumbo is offline   Reply With Quote
Old 23rd March 2009, 16:47   #3005  |  Link
Rodger
No Problem here! Everything is fine.
Rodger is offline   Reply With Quote
Old 23rd March 2009, 16:56   #3006  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
Your antiwirus blocks you, disable protection for moment and try again. I haved same issue
ESS log:
22/03/2009 9:38:09 PM
HTTP filter file
http://www.smlabs.net/tsMuxer/tsMuxeR_1.8.35(b).zip
probably a variant of Win32/Statik potentially unwanted application
connection terminated - quarantined
Threat was detected upon access to web by the application: C:\Program Files\Mozilla Firefox\firefox.exe.
shon3i is offline   Reply With Quote
Old 23rd March 2009, 16:58   #3007  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
I'd suggest you to wait for the next release or use 34b- just read few posts up.
Old 23rd March 2009, 17:13   #3008  |  Link
shon3i
BluRay Maniac
shon3i's Avatar
There is no problems in normal Blu-Ray mux, just when split selected.
Old 23rd March 2009, 19:43   #3009  |  Link
phigment
SPS picture order 2 not supported.
If anybody cares, I Just tried 1.8.35 with bistreams from the Canon 5D Mark II and I still get "SPS picture order 2 not supported." errors.
phigment is offline   Reply With Quote
Old 23rd March 2009, 20:12   #3010  |  Link
Chumbo
Chumbo's Avatar
ESS log:
Thans shon3i. I should have checked that first. Just updated to a new virus scanner and it's not configured to show automatically blocked suspect files, but sure enough the file is in quarantine.
I'll submit it to the labs so they can analyze it.
Chumbo
Old 24th March 2009, 10:51   #3011  |  Link
roman76r
Restore cropped video function
Hi all!
Now I begin to implement "restore cropped video" function.
This is hard feature, so I plan to implement it during 1-2 week.
How it will be work:
I plan to modify H.264 stream. 2 new slices will be inserted to the stream: for bottom and top black region. Current slice(s) with video will be changed by modifying the field "first_mb_in_slice".
Black slice are very compact, so the size of the stream rises slightly.
roman76r is offline   Reply With Quote
Old 24th March 2009, 11:21   #3012  |  Link
deank
deank's Avatar
Thanks for this. I was trying to implement the same thing but it is really a though job for me. It would have probably taken much less time if some of the x264 developers or someone with good h264 knowledge had landed a hand... but no.
Old 24th March 2009, 12:39   #3013  |  Link
RobertR
RobertR's Avatar
Hi!
I'm toying with linux binary on amd64 arch. tsMuxerGUI from tsMuxeR_static_1.8.35(b).tar.gz does not work for me (probably could make it running after installing some ia32 libs but i'd rather not do that). In the history on SmartLabs pages there is mention that since 1.8.35 two modes are supported "Create BluRay disc" and "Create AVCHD disc". Second one beeing recommended for so-called BD5/BD9 media.
Can I choose between BluRay and AVCH from either CLI or meta file? If so, could some kind soul tell me how?
TIA
NameLess, the Jedi aka NLJ
RobertR is offline   Reply With Quote
Old 24th March 2009, 12:42   #3014  |  Link
coolalibaba
@Roman,
this is really a fantastic news! I have been waiting this too long...
Originally Posted by roman76r View Post
Hi all!
coolalibaba is offline   Reply With Quote
Old 24th March 2009, 13:55   #3015  |  Link
ultratoto14
Hi all!
Hi Roman, good to see you again !!
ultratoto14 is offline   Reply With Quote
Old 24th March 2009, 14:10   #3016  |  Link
flyingernst
DTS-HD High Resolution
what is the latest version in that DTS-HD High Resolution works without bug? my PCH is able to play/stream HD-Audio in a File made by tsmuxer 1.2.9 (with dts-hd high resolution). With die the newest TSmuxer-versions the PCH tries to play/stream DTS-hD Master instead of DTS-HD HR
Popcorn Hour B-110
Onkyo TX-SR 805
flyingernst is offline   Reply With Quote
Old 24th March 2009, 18:18   #3017  |  Link
nwg
I thought DTS-HD audio was always ok in TsMuxer. It was TsRemux that had problems with it? I never heard of version 1.2.9. All the TsMuxer versions have been 1.8.XX.
nwg is offline   Reply With Quote
Old 24th March 2009, 19:35   #3018  |  Link
mrr19121970
yes, it's in your META file:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr  --auto-chapters=5 --vbv-len=500
MUXOPT --no-pcr-on-video-pid --new-audio-pes --avchd --vbr  --auto-chapters=5 --vbv-len=500
Old 24th March 2009, 21:52   #3019  |  Link
RobertR
RobertR's Avatar
Thanks a lot mrr19121970
Old 25th March 2009, 10:54   #3020  |  Link
G_M_C
Hi all!
He, here's my chance !
I want to thank you for the development of this great tool, it just gets better and better ! Keep up the good work !.
G_M_C is offline   Reply With Quote
tsmuxer
