Old 14th November 2017, 17:14   #3741  |  Link
pinterf
Originally Posted by Myrsloik View Post
About how much faster is avx2 vs sse2 on a modern cpu in your expr version?
I had to do that in blind mode, I have no AVX2, only through SDE emulator. I could test it only two days ago on a 2 yr old i5 notebook and the results show that it was worth to implement.
Other speed tests are welcome, that's why there are optXXX parameters.
results in fps
avx2: set it only in Expr through optAvx2 parameter
bits      i5 sse2 32/64 bit  i5Avx2 32/64 bit
8         17.00 19.30         24.63 28.98
16       15.69 17.59         20.38 23.26
32       12.70 13.59         16.03 17.14
The script was something like this (deleted my debug experimental commented out lines)
lsmashvideosource("13HoursCUT.mp4", format="YUV444P8")
Spline64Resize(486,240) #resize, result is a multistacked image
src=last
# expr
c8 = CalcTest(src,8, False)
c16 = CalcTest(src,16, False)
c32 = CalcTest(src,32, False)
# lutxy
c8e  = CalcTest(src,8, True)
c16e  = CalcTest(src,16, True)
c32e = CalcTest(src,32, True)
res8=Diff(c8,src)
res16=Diff(c16,src)
res32=Diff(c32,src)
res8e=Diff(c8e,src)
res16e=Diff(c16e,src)
res32e=Diff(c32e,src)
col1=StackVertical(c8,c16.convertbits(8),c32.convertbits(8))
col2=StackVertical(res8, res16, res32)
col3=StackVertical(c8e,c16e.convertbits(8),c32e.convertbits(8))
col4=StackVertical(res8e, res16e, res32e)
StackHorizontal(col1, col2, col3, col4)
#used only c8, c16 or c32 output for speed test from the clips above.
# change parameters. e.g. optSSE2=true, optSingleMode=false, optAvx2=false
c8
Function Diff(clip src1, clip src2)
  return Subtract(src1.ConvertBits(8),src2.ConvertBits(8)).Levels(120, 1, 255-120, 0, 255, coring=false)
Function CalcTest(clip src, int bits, bool lut)
src
convertbits(bits)
tmp=last
method=Blur(1)
szrp=16
spwr=4
str=100/100.0
sdmplo=4
sdmphi=48
expr_pow = "x y == x x x y - abs "+string(Szrp) +" scaleb / 1 "+string(Spwr)+" / ^ "+string(Szrp) +" scaleb * "+string(str)+" * x y - 2 ^ x y - 2 ^ "
\+string(SdmpLo)+" scaleb scaleb + / * x y - x y - abs / * 1 "+string(SdmpHi)+" scaleb 0 == 0 x y - abs "+string(SdmpHi)+" scaleb / 4 ^ ? + / + ?"
ret=lut ? mt_lutxy(tmp,method, yexpr=expr_pow, U=1,V=1 ) : Expr(tmp,method,expr_pow,"","", optSSE2=true, optSingleMode=false, optAvx2=false)
return ret
Last edited by pinterf; 14th November 2017 at 17:20. Reason: test env clarification
pinterf is offline   Reply With Quote
Old 14th November 2017, 17:15   #3742  |  Link
pinterf
Originally Posted by real.finder View Post
thanks pinterf
some friend that use vs said that float <- -> int is broken in vs expr, did you note that and fix it?
Yes, fixed and noted.
Old 14th November 2017, 22:04   #3743  |  Link
ryrynz
ryrynz's Avatar
Any idea when your commits going to merge officially? You're the only one spearheading code in right now.
Old 15th November 2017, 10:03   #3744  |  Link
davidhorman
I'm the Doctor
sxr, syr (relative x and y coordinates, from 0 to 1.0)
Aren't those normalised, rather than relative?
davidhorman is offline   Reply With Quote
Old 15th November 2017, 10:25   #3745  |  Link
pinterf
Yes, normalized but I took the terminology from here:
http://avisynth.nl/index.php/MaskTools2/mt_lutspa
Old 15th November 2017, 12:29   #3746  |  Link
edcrfv94
I change mt_lutxy to Expr then limit function no work any more.
Function kf_limit_dif8_expr(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
	sCSP = filtered.kf_GetCSP()
	IsY8 = sCSP == "Y8"
	smooth   = Default(smooth, True    )
	thr      = Default(thr,    1.0     )
	elast    = Default(elast,  smooth ? 3.0 : 255./thr)
	darkthr  = Default(darkthr,thr     )
	Y        = Default(Y,      3       )
	U        = Default(U,      3       )
	V        = Default(V,      3       )
	Y        = min(Y,     4)
	U        = min(U,     4)
	V        = min(V,     4)
	thr      = max(min(    thr, 255.0), 0.0)
	darkthr  = max(min(darkthr, 255.0), 0.0)
	elast    = max(elast, 1.0)
	mode     = thr == 0 && darkthr == 0 ? 4 : thr == 255 && darkthr == 255 ? 2 : 3
	smooth   = elast==1 ? False : smooth
	diffstr  = " x y - "
	elaststr = " "+string(elast)+" "
	thrstr   = diffstr+" 0 > "+string(darkthr)+" scalef "+string(thr)+" scalef ? "
	alphastr = elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstr+" * / ? "
	betastr  = thrstr+elaststr+" * "
	sexpr    = smooth   ? alphastr+diffstr+" * "+betastr+diffstr+" abs - * y + "
	\                   : thrstr+diffstr+diffstr+" abs / * y + "
	expr     = diffstr+" abs "+thrstr+" <= x "+diffstr+" abs "+betastr+" >= y "+sexpr+" ? ? "
	thrstrc  = " "+string(thr)+" scalef "
	alphastrc= elaststr+" 1 <= 0 1 "+elaststr+" 1 - "+thrstrc+" * / ? "
	betastrc = thrstrc+elaststr+" * "
	sexprc   = smooth   ? alphastrc+diffstr+" * "+betastrc+diffstr+" abs - * y + "
	\                   : thrstrc+diffstr+diffstr+" abs / * y + "
	exprc    = diffstr+" abs "+thrstrc+" <= x "+diffstr+" abs "+betastrc+" >= y "+sexprc+" ? ? "
	# diff   = filtered - original
	# alpha  = 1 / (thr * (elast - 1))
	# beta   = elast * thr
	# When smooth=True  :
	# output = diff <= thr  ? filtered : \
	#          diff >= beta ? original : \
	#                         original + alpha * diff * (beta - abs(diff))
	# When smooth=False :
	#                         original + thr * (diff / abs(diff))
	expry = (Y == 3) ? expr : ""
	expru = (U == 3) ? exprc : ""
	exprv = (V == 3) ? exprc : ""
	return   (mode == 4)    ? original
	\      : (mode == 2)    ? filtered
	\      : IsY8           ? Expr(filtered, original, expry, optSSE2=true, optSingleMode=false, optAvx2=true)
	\      :                  Expr(filtered, original, expry, expru, exprv, optSSE2=true, optSingleMode=false, optAvx2=true)
Function kf_limit_dif8_mt(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
	Y        = Default(Y,      3       )
	U        = Default(U,      3       )
	V        = Default(V,      3       )
	Y        = min(Y,     4)
	U        = min(U,     4)
	V        = min(V,     4)
	diffstr  = " x y - "
	return   mode == 4    ? original
	\      : mode == 2    ? filtered
	\      :                mt_lutxy(filtered, original, yExpr=expr, uExpr=exprc, vExpr=exprc, Y=Y, U=U, V=V)
edcrfv94 is offline   Reply With Quote
Old 15th November 2017, 12:48   #3747  |  Link
pinterf
Could you specify your calling parameters and what should I look for in the results?
Old 15th November 2017, 13:05   #3748  |  Link
edcrfv94
The result is very different.
	SetMemoryMax(3000)
	#colorbars(width=1920, height=1080, pixel_type="yv12").killaudio().assumefps(25, 1)
	ImageSource("1.png", end=0).Dither_convert_rgb_to_yuv(lsb=true,output="YV12").DitherPost(mode=6)
	ConvertToY8()
	trim(0, 5000)
	#Limiter()
	#InvertNeg()
	#VToY()
	src = last.ConvertBits(bits=16)
	sharp = src.Sharpen(1.0).Sharpen(1.0)
	kf_limit_dif8_mt_test(sharp, src, thr=1, elast=42, y=3, u=1, v=1)
	#kf_limit_dif8_expr_test(sharp, src, thr=1, elast=42, y=3, u=1, v=1)
	ConvertToStacked().DitherPost(mode=6, ampo=1)
	Function kf_limit_dif8_expr_test(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
		IsY8 = sCSP == "Y8"
		Y        = Default(Y,      3       )
		U        = Default(U,      3       )
		V        = Default(V,      3       )
		Y        = min(Y,     4)
		U        = min(U,     4)
		V        = min(V,     4)
		diffstr  = " x y - "
	Function kf_limit_dif8_mt_test(clip filtered, clip original, bool "smooth", float "thr", float "elast", float "darkthr", int "Y", int "U", int "V")
		Y        = Default(Y,      3       )
		U        = Default(U,      3       )
		V        = Default(V,      3       )
		Y        = min(Y,     4)
		U        = min(U,     4)
		V        = min(V,     4)
		diffstr  = " x y - "
	Function kf_GetCSP(clip c)
		try {
			csp = c.kf_GetCSP_avsPlus()
		} catch (error_msg) {
			csp = c.kf_GetCSP_avs()
		return csp
	Function kf_GetCSP_avs(clip c)
		return c.IsPlanar ? c.IsYV12 ? "YV12" :
		\                   c.IsYV16 ? "YV16" :
		\                   c.IsYV24 ? "YV24" : c.kf_GetCSP_Y8_YV411() :
		\      c.IsYUY2   ? "YUY2"   :
		\      c.IsRGB32  ? "RGB32"  :
		\      c.IsRGB24  ? "RGB24"  : "Unknown"
		Function kf_GetCSP_Y8_YV411(clip c) {
		    try {
			c.UtoY
			csp = "YV411"
			csp = "Y8"
		    return csp
	Function kf_GetCSP_avsPlus(clip c)
		return c.Is420   ? "YV12"  :
		\      c.IsY     ? "Y8"    :
		\      c.Is422   ? "YV16"  :
		\      c.Is444   ? "YV24"  :
		\      c.IsYUVA  ? "YUVA"  :
		\      c.IsYV411 ? "YV411" :
		\      c.IsPackedRGB  ? "RGB32/RGB24" :
		\      c.IsPlanarRGB  ? "RGB48"       :
		\      c.IsPlanarRGBA ? "RGB64"       : "Unknown"
Old 15th November 2017, 13:39   #3749  |  Link
pinterf
...code...
Thanks, scalef bug in 10-16 bits. scaleb was o.k.
I'll wait a bit before make the new version with the fix.
Old 15th November 2017, 17:32   #3750  |  Link
pinterf
New build with a hotfix
Download Avisynth+ r2544
20171115 r2544
  - Expr: fix "scalef" for 10-16 bits
  - Expr optimization: eliminate ^1 +0 -0 *1 /1
Old 15th November 2017, 23:43   #3751  |  Link
ryrynz
ryrynz's Avatar
Gave the sizetmod a try but have it crash every time. Tried a simple script through ffdshow raw.
SetFilterMTMode("DEFAULT_MT_MODE", 2)
ffdshow_source()
aWarp4(Spline36Resize(width*4, height*4, 0.375, 0.375), aSobel.aBlur(), depth=2)
Prefetch(4)
MadVR ends up crashing, no issues with the normal build.
Old 16th November 2017, 09:24   #3752  |  Link
pinterf
ffdshow_source()
Prefetch(4)
Thanks. Do you know if anything in this chain is using CPP 2.5 or C interface?
For me they (x64 plugins with CPP 2.5 interface) are crashing with the sizetmod build. No wonder, 2.5 is the "baked" code interface.
I don't like them. For example supporting 2.5 prevented me last year to introduce the array type. Now this.
They badly need at least a recompile for 2.6.
Old 16th November 2017, 12:08   #3753  |  Link
tormento
Acid fr0g
tormento's Avatar
Experimental x64 crashing here.
PHP Code:
SetMemoryMax(8000)
SetFilterMTMode("DEFAULT_MT_MODE"2)
SetFilterMTMode("ChangeFPS"3)
SetFilterMTMode("DGSource"3)
LoadPlugin("D:\eseguibili\media\DGDecNV\x64\DGDecodeNV.dll")
DGSource("E:\in\1_37 Swiss Army man  Un amico multiuso\swiss.dgi")
#CompTest(1)
ChangeFPS(last,last,true)
SMDegrain (tr=4,PreFilter=4,thSAD=400,contrasharp=false,refinemotion=false,truemotion=true,plane=4,chroma=true,lsb=true,mode=0)
Prefetch(6
@turment on Telegram
Old 16th November 2017, 12:10   #3754  |  Link
ryrynz
ryrynz's Avatar
Shouldn't be. Awarp4, asobel and a blur are all part of the x64 build of Awarpsharp you compiled and is the latest version you released, it should be compatible.
Old 16th November 2017, 12:32   #3755  |  Link
pinterf
Perhaps the source filter?
For example LSmashSource (CPP v2.5 as Avsmeter64 reports) is crashing for me. ffms2 is OK.
Old 16th November 2017, 12:54   #3756  |  Link
pinterf
PHP Code:
SetMemoryMax(8000)
DGSource("E:\in\1_37 Swiss Army man — Un amico multiuso\swiss.dgi")
#CompTest(1)
Prefetch(6
I don't know about the source filter, I have replaced it with ffms2.
The script still crashed with lsb=true.
Unfortunately dither.dll is a 2.5 style plugin.
With lsb=false the script is working properly with the given parameters.
Edit: rebuilt dither.dll, replaced the 2.5-style avisynth.h with the 2.6-style avs+ header (not even the size_t mod version) and no more crash with lsb=true.
Old 16th November 2017, 16:37   #3757  |  Link
tormento
Acid fr0g
tormento's Avatar
Ahem... post new dither here
Old 16th November 2017, 16:49   #3758  |  Link
pinterf
It does not help at the moment.
LSmashSource, dither, AddGrainC, x264_64, and a lot more cpp 2.5 plugins and 2.5 c interface user apps are out there.
Just have a look at the CPP 2.5 list of avsmeter -avsinfo.
Old 16th November 2017, 17:01   #3759  |  Link
tormento
Acid fr0g
tormento's Avatar
[CPP 2.5 / 64 Bit Plugins]
D:\Programmi\Media\AviSynth+\plugins64\Dither-1.27.2.dll
D:\Programmi\Media\AviSynth+\plugins64\f3kdb-2.020140721-SAPikachu.dll
To me is more than enough! It's the only filter I use still 2.5!
Old 17th November 2017, 11:17   #3760  |  Link
Yanak
Not sure if my used plugins are all up to date and /or if some others could be replaced by something else tho but things like LSmashSource, Avsinpaint, MP_Pipeline are essential for me and i don't think there is any alternative to those :/
Yanak is offline   Reply With Quote
