1st June 2009, 16:06 | #1021 | Link |
HDConvertToX author
first one is nice, added in next update (feel free to redownload hdcoverttox.exe)
BUT the pause.. sorry, users will complain about it. you should add it manually BHH
HDConvertToX: your tool for BD backup MultiX264: The quick gui for x264 AutoMen: The Mencoder GUI AutoWebM: supporting WebM/VP8 |
1st June 2009, 16:27 | #1022 | Link |
first one is really usefull
I use pause too (manualy insert it on queue in HDC), but before pause I colorize text - to visualy see when process is finished example: Code:
prompt $d $t $_$P$G "C:\DVD\HDC\applications\dgindex.exe" -FO=0 -OM=0 -YR=2 -AIF=[c:\dvd\title.mkv] -OF=[C:\DVD\HDC\temp\movie] -exit -minimize "C:\DVD\HDC\applications\eac3to.exe" "c:\dvd\title.mkv" 2: "C:\DVD\HDC\temp\hdencodertox-pid2.ac3" "C:\DVD\HDC\applications\x264.exe" --bitrate 467 --threads auto --thread-input --no-psnr --progress --keyint 250 --bframes 1 --trellis 0 --ref 1 --deblock 0,0 --subme 2 --direct spatial --vbv-bufsize 14000 --vbv-maxrate 25000 --me hex --no-ssim --merange 8 --b-adapt 0 --no-chroma-me --aud --sar 1:1 --output "C:\DVD\HDC\temp\hdconverttox_title.h264" "C:\DVD\HDC\temp\hdconverttox_title.avs" "C:\DVD\HDC\applications\mkvmerge.exe" -o "C:\DVD\title2.mkv" --default-duration 0:25.000fps "C:\DVD\HDC\temp\hdconverttox_title.h264" --language -1:cze "C:\DVD\HDC\temp\hdencodertox-pid2.ac3" --title "Done with HDConvertToX v.1.7.323.2869" color 0a pause I really like this modifiable queue in HDC!! Last edited by feanor12; 1st June 2009 at 16:31. |
1st June 2009, 18:33 | #1023 | Link |
HDConvertToX author
@feanor
the bug of mkv input file with mpeg2 video codec is fixed.. redownload hdc BHH
1st June 2009, 19:48 | #1025 | Link |
HDConvertToX author
i like it too! .. but it's better not to add it, many users don't know what "pause" do...
BHH
1st June 2009, 20:08 | #1026 | Link | |
I was using this before I used multitemp - so I didn't loose temp files if encode wasn't correct (I usually have more videos in queue). |
1st June 2009, 22:04 | #1027 | Link |
MKV to MKV recoding problem
I have MKV (created from DVD by MakeMKV) with 1 video (mpeg2), 2 audio (ac3) and 3 subs streams and want to reencode video to X264. There is some problem with subs: Code:
eac3to v3.16 command line: "C:\DVD\HDC\applications\eac3to.exe" "c:\dvd\title_in.mkv" 4:"C:\DVD\temp\title_in_mkv\hdencodertox__subs_4.sup" ------------------------------------------------------------------------------ MKV, 1 video track, 2 audio tracks, 3 subtitle tracks, 1:46:09, 50i 1: MPEG2, 576i50 (16:9) 2: AC3, Czech, 5.1 channels, 448kbps, 48khz "3/2+1" 3: AC3, 5.1 channels, 448kbps, 48khz "3/2+1" 4: Subtitle (VobSub), Czech 5: Subtitle (VobSub), Czech 6: Subtitle (VobSub), Czech Bitstream parsing for tracks 4-6 failed. <WARNING> Demuxing these tracks may still produce correct results - or not. <WARNING> This subtitle conversion is not supported. <ERROR> |
2nd June 2009, 00:00 | #1028 | Link | |
Rick Definitely, the problem is caused by DSS2.. Every time I use it, the encode never finishes... Reinstall Haali? Maybe there is a newer version, I will check. Reinstalled Haali 1.9.42.1. Upon installation, it disabled the internal version as well as Gabests version, I assume that is the required action. Other than that, not sure what else I can do. Possibly a Vista issue? Who knows.... Last edited by rickhtoo; 2nd June 2009 at 03:48. Reason: Additional info |
2nd June 2009, 07:00 | #1029 | Link | ||
HDConvertToX author
in next full update i have added a mkvextract capability, you will be able to manually extract it Quote:
also make sure you have checked in ffdshow the dvd decoding in mpeg2 also try with libmpeg decoder.. BHH
2nd June 2009, 10:45 | #1030 | Link | |
2nd June 2009, 15:31 | #1031 | Link | |
BTW, mkvextract is able to extract it to .sub and .idx with no problems. |
2nd June 2009, 16:01 | #1032 | Link | |
HDConvertToX author
but i will continue relying on eac3to for demuxing mkv , in the hope that eac3to will continue to be supported BHH
2nd June 2009, 18:58 | #1033 | Link |
Could add the ability to save automatically with the same name as the original when the file is saved in different folder or is not the same extension as the original file.Here he adds the final file, a text before the original name. Thanks.
2nd June 2009, 19:15 | #1034 | Link |
HDConvertToX author
... could you make an example ?
(sorry pal, i haven't understud..) BHH
2nd June 2009, 19:44 | #1035 | Link |
When I open a video, and leave the "output" empty, the filename final gets of hdfullconvert_xxxxxxxxxx.avi, and wanted to know if you can get only xxxxxxx.avi
I use google translator. Sorry for bad english |
2nd June 2009, 19:49 | #1036 | Link |
HDConvertToX author
i add hdconverttox_xxxxxxx because users could reencode the file to the same container. like test.avi to test.avi
and this can't be possible you should name your output file, or take the hdconverttox prefix BHH
2nd June 2009, 20:03 | #1037 | Link |
I know, I referred to cases that were, for example mkv> avi, another conversion between various containers, keeping the prefix where you use the same containter or output was in a different folder than the original. Anyway, thanks for the quick response.
2nd June 2009, 20:04 | #1038 | Link | |
EDIT: Ok, forget my questions. I have searched through eac3to forum and found the answer. VobSub format of subtitles is not supported. Probably they should be in SRT or some other format. Last edited by marklar; 3rd June 2009 at 12:43. |
3rd June 2009, 00:39 | #1039 | Link |
Hey buzz,
I recently switched to Windows 7 RC and when I try to convert a single Vob file via HDC I get the please check meda properties error. I installed K Lite Codec Pack 32 and 64 and used the tool you linked to set everything to ffdshow. |
bluray, hdc, hdconverttox, m2ts, network media tank, playstation, x264 gui |
