5th September 2009, 15:21 | #9541 | Link | |
5th September 2009, 15:40 | #9542 | Link |
Anime Otaku
BUG:
Using rev. 1265 VSFilter will not load regardless if "Autoload subtitles" is checked or not. Only if I set it as prefered in the external filters it will load but I do not want it to load everytime! Interesting observation: It will load if I set "System default" as video renderer, anything else and it doesn't work, seems like it is blocked somehow, doesn't even load with overlay mixer!
AMD FX8350 on Gigabyte GA-970A-D3 / 8192 MB DDR3-1600 SDRAM / AMD R9 285 with Catalyst 1.5.9.1/ Asus Xonar D2X / Windows 10 pro 64bit |
5th September 2009, 16:07 | #9543 | Link | |
it seems that you have a strong system, but you are not really using your GPU for decoding your videos. DXVA is probably not in use because usually the CPU load would be less than 10 % with DXVA. You can check that while your videos are loaded into MPC-HC with the right-click sub-menu "Filter" when you open the "MPC Video Decoder" properties and have a look at "DXVA Mode". If you find something there like "H.264 bitstream decoder..." then DXVA is use. If not, please read one of the following tutorials: http://nunnally.ahmygoddess.net/watc...os-using-dxva/ http://forums.techarena.in/guides-tutorials/1192826.htm http://www.guru3d.com/article/accele...he-gpu-guide/1 Btw, your sample is an interlaced video with 1080i and not 1080p where p stands for progressive (not pixel). |
5th September 2009, 16:09 | #9544 | Link |
契約者
cca
Are you sure this is a bug? I mean afaik "autoload subtitles" is for internal subtitle renderer and not vsfilter. Internal subtitles works only with video renderers like haali, EVR-CP, VMR7/9 renderless. Maybe if you set to default - one of them is loaded? |
5th September 2009, 16:25 | #9545 | Link | |
Anime Otaku
I'm obviously referring to the case when the checkbox is unchecked. VSFilter will not load, but loads fine in Graphedit using the same decoders and renderers.
5th September 2009, 16:48 | #9546 | Link | |
5th September 2009, 16:55 | #9547 | Link |
Anime Otaku
I'm obviously using Windows 7, my system specs are my signature. Well then, I guess it is a known issue, but still a bug.
5th September 2009, 18:18 | #9548 | Link | |
And re-encoding every video to make it DXVA compatible isn't what I want. |
5th September 2009, 18:54 | #9549 | Link | |
http://www.alice-dsl.net/pkeunecke/H...thout_DXVA.jpg You can also try to enable the H.264 level 5 support which I can use successfully with up to 9 reference frames on my HD 3450. It just needs a little trick, but no guarantee that this hack works on other systems too: http://forum.eeeuser.com/viewtopic.php?id=75704 Last edited by peek; 5th September 2009 at 19:06. |
5th September 2009, 19:35 | #9550 | Link |
Installing DivX7 doesn't help neither does setting the input buffer size to a higher value do.
I really don't think the decoders are the problem. 2 days ago. I could playback 15 mbps 1080p24 fine with ffmpeg-mt with Overlay Mixer, I don't know what I did, but for some reason I can't playback those anymore. |
5th September 2009, 19:46 | #9551 | Link |
Have a look at the "Filter" submenu during playback to see what's really loaded by MPC-HC. Or load the same video into graphstudio to find out what's going wrong. Third method: Use Process Explorer and open the properties page of MPC-HC there to watch the threads. Maybe you can upload a sample of one of these clips.
5th September 2009, 20:39 | #9552 | Link | |
One person asked for a screenshot. That person is not a developer, and the things they asked for indicate that they do not understand the problem. Currently, the number of developers replying or commenting about sync-related issues is zero. The number of developers available to work on sync-related issues is zero. Somehow, people decided that they want to blame me for not wanting to provide the wrong data, when there is no one interested or available to work on the issues. This after a number of other people pointed out that they were clueless when they kept asking me to get a different graphics card. It is interesting that people are siding with the attackers, even after the attackers are proved clueless. Perhaps you are desperate to attack someone, anyone ??
s/w: Vista Home Basic 32bit (no Aero), MPC-HC, EVR Custom Presenter, CoreAVC Pro, ffdshow, SPDIFer h/w: Antec 2480 case, Gigabyte GA-MA69GM-S2H, 4200+, 2.5gb+512mb, ATI x1250 IGP, MS MCE remote |
5th September 2009, 20:57 | #9553 | Link |
MPC-HC Project Manager
Adude, i'm not sure what your problem is, but as you know very well i am the program manager (which boils down to vice-president).
Among other things, its my job to decide which bugs get fixed, most bugs get fixed at random voluntairily by our developers, however most bugs are not "fun to work on" getting these bugs fixed means focusing on something. The problem you claim to have is one of the most important bugs being dealt with at the moment, several dev's are working on it. However no-one is working on the exact symptoms you describe (because it works on 20+ dev systems and an unknown amount of beta tester systems) All bugs related to your problems can only be dealt with through CTRL+J screenshots I have instructed all developers to ignore your reports until you post the screenshots asked for. I have also reported your trolling to the site moderators.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 5th September 2009 at 21:02. |
5th September 2009, 21:28 | #9554 | Link |
Angel of Night
Adude: Shut up. Everyone else: Stop replying to him.
Sorry, Adude, that things aren't working right. That doesn't give you the right to rant and harass the developers and the rest of the forum to make up for the fact that they don't know how to fix it, particularly given your repeated refusals to cooperate with them. When no developer and no other tester sees the issue, you have to cooperate as much as possible if you want to see it fixed, otherwise you just have to accept that it won't be fixed. It's much easier when one of them can reproduce it. Further posts on this issue will result in a rule 4 strike. |
5th September 2009, 23:44 | #9555 | Link | |
http://img269.imageshack.us/img269/9586/problem2p.png And this is the filters + process explorer: http://img267.imageshack.us/img267/651/problemj.png The sample is http://dl.getdropbox.com/u/1907430/Q...080_VFR%29.mp4 The thing is, I could play that video file using DXVA with svn 1265 first, but then I switched to 1271 and it wouldn't use DXVA, then I went back to 1265, but the video wouldn't even start. |
6th September 2009, 00:02 | #9556 | Link | |
Would be nice to get the option to downmix PCM audio (when FLAC is used for the audio, for example). There's the option to downmix audio for AAC, AC3, and DTS to stereo, but not PCM (which could supersede all settings, too..). Should be a piece of cake to do, any I'm sure everyone that uses FLAC and other formats that decode to PCM would appreciate the effort.
6th September 2009, 00:46 | #9557 | Link |
forgive me if this is in the previous 480 pages of this tread.... Does MPC Cinema install any codecs? I'm looking to take advantage of built in codecs but I don't want the KLite codec pack installed.
Does the install of just MPC Cinema install codecs? Thank you. |
6th September 2009, 01:09 | #9558 | Link |
too much lurking
Nope. In fact if you only have the .exe it installs nothing at all. The xvidvideo.ru builds are available in an installer. I'm not sure what they do as I've never tried one. Probably only put the folder with the .exe and other stuff in program files and created a start menu entry.
BTW. What do you mean by " install codecs"? Something like registering filters? |
6th September 2009, 14:52 | #9559 | Link |
Some results testing X1250 IGP on a TA690G mobo:
Setup: MPC-HC Build 1271, XPSP3, FFDshow 3063, RGB HQ 32bit output, no dithering, AMD X2@2.8Ghz, dual-monitor, LG HDTV 1080P as playback monitor (24Hz, secondary, HDMI), ReClock 1.8.4.8, all vsync turned off. Just have MKVs with MPEG2 and AVC video, DVD SD rez (will test HD stuff when I get it to this machine) Using VMR9 Renderless, letting FFDshow do the resize to 1080, I get perfect playback, no tearing. If I tell MPC-HC to resize using Bicubic, I get bad tearing and choppy playback. Changing to Bilinear, again, brings back perfect playback. Using EVR-CP, same results as above except if I use FFdshow to resize, I get some minor tearing. Using Bilinear resize provides for perfect playback. I'll try to do some HD content next..... |
6th September 2009, 16:17 | #9560 | Link |
Resizing with pixelshaders (PS) unfortunately requires a powerful graphics processor. Your problem is thus not really fixable.
MPC-HC 2.2.1 |
