Old 14th July 2009, 10:39   #1  |  Link
21420
How to convert with Variable Frame Rate? (VFR, H.264)
Hello,
which software is needed to convert movie clips (Quicktime H264) with a constant frame rate (CFR) to clips with a variable frame rate (VFR)?
(I already searched the forums and the internet)
Thanks in advance!
21420 is offline   Reply With Quote
Old 14th July 2009, 12:52   #2  |  Link
tetsuox
Why do you want to convert a CFR source to VFR anyway?
foobar2k ~ MPC-HC ~ ffdshow-tryouts
tetsuox is offline   Reply With Quote
Old 14th July 2009, 13:03   #3  |  Link
21420
I am recording my computer screen. Often there will be no movement in the video while I am explaining something in the audio track.*
Basically I want to end up with a video like this:
http://www.lynda.com/home/Player.aspx?lpk4=51616
edit:
* using a VFR should decrease the file size significantly
Old 14th July 2009, 14:12   #4  |  Link
Ghitulescu
Ghitulescu's Avatar
Originally Posted by 21420 View Post
edit:
* using a VFR should decrease the file size signifiantly
So will a GOP-based algorithm do , since B-frames, which keep the differences, would need less space if no changes in image are present.
Old 14th July 2009, 14:28   #5  |  Link
21420
Great!
...so which program/codecs may I use to convert the files?
I am on Mac OS X / Win XP.
Old 14th July 2009, 14:40   #6  |  Link
Ghitulescu
Ghitulescu's Avatar
Well, one of them is h.264, which seems to be your original codec. Aren't you happy with its size? Reduce then the bitrate and/or the screen size.
I'm not very expert in VFR, the only one I (accidentaly) heard of was RMVB, which belongs to RealMedia (Real Networks) formats.
Old 14th July 2009, 14:59   #7  |  Link
His source is already H.264. The salient point now is does it use B frames already.
21420, post a link to a small unprocessed sample of your source.
Old 14th July 2009, 15:55   #8  |  Link
21420
I just recorded the video I posted in the link above so I can compare the recorded with the original one.
It is currently encoding the video with H.264, 16fps, 30 Kbyte/s*, multipass
* QuickTime indicates that the original video has a bitrate of about 240 Kbit/s
The finished video is about 16.8 MB (235 kbit/s; no audio), while the original file was 16.5 MB (232 kbit/s WITH the audio track (AAC)).
In my video the frame rate never drops. The original file's frame rate often drops to 1 or even 0.14 fps
In my "Compression Settings" I can select
- Key frame every X frames
- Frame reordering
What is a good setting to use for recording applications?
Old 14th July 2009, 19:59   #9  |  Link
I'm checking out as you won't post what I asked for. Bye!
Old 14th July 2009, 20:35   #10  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
How big may a file be for attaching it in this forum?
don't attach to this forum! just cut a small sample, say ~30 MB, and upload it to mediafire or such service, then post link to it here
Old 14th July 2009, 20:47   #11  |  Link
21420
See here:
http://www.mediafire.com/?sharekey=5...4e75f6e8ebb871
edit: about 500 kb
edit2:
16fps, 30 KBytes/s, Multi-pass
I'm not really satisfied with the quality. Also I don't know how to create a clip with VFR instead of CBR (the program's codec does not offer such an option).
cfr, h264, quicktime, vfr
