19th February 2013, 23:26 | #14202 | Link |
In graph edit. I tried stopping the graph, breaking all the connections, and reconnecting the pins, but it refuses to use DXVA. The only way seems to be to remove the decoder, then render the pin (which brings back LAV) and it works.
21st February 2013, 11:32 | #14205 | Link |
@Nev I just saw that XBMC claims to support "DTS-HD MA" now (ffmpeg AFAIK) does this mean that LAV will do too (without the DLL ) ?
Intel UHD Graphics 750; Win 10 22H2 |
21st February 2013, 11:34 | #14206 | Link |
The only thing they finally support is bitstreaming, years too late.
21st February 2013, 11:51 | #14207 | Link |
nev, is that technically possible to "bitstream" AC3 core in case of EAC3 audio?
i have an old AV receiver connected to my HTPC via optical SPDIF. Receiver supports only AC3, so if i want to watch TV with AC3+ (e.g. Servus TV HD) i get only stereo, because SPDIF is capable to transfer AC3-encoded 5.1, and for EAC3 LAV decodes it completely, and SPDIF gets only stereo PCM |
21st February 2013, 11:52 | #14208 | Link |
EAC3 has no "AC3 core", so its not possible.
21st February 2013, 12:02 | #14210 | Link |
He inquired about broadcast TV primarily
Primary Blu-ray EAC3 tracks are in a rather special position there, and can't be compared with anything else.
21st February 2013, 12:07 | #14211 | Link |
So for me the only chance is to disable support in LAV and use FFDShow with enabled AC3 encoder for those formats that do not pass in SPDIF bandwidht and can't be understood by my receiver.
Thanks for explanation! |
21st February 2013, 20:16 | #14213 | Link |
Hey nev, a user of my guide asked the following question: "What's the reason for AYUV being disabled in the LAV video decoder?" I'm not really sure myself so I'm asking you that directly.
I did a search before in the forum and around the net but never found any details.
madVR scaling algorithms chart - based on performance x quality | KCP - A (cute) quality-oriented codec pack |
21st February 2013, 20:42 | #14214 | Link | |
もこたんインしたお!
But then it was found out that the renderer(s) accept AYUV with the main pin as well, and... that leads to the fact that converting to RGB in the decoder and then rendering that is much more faster than trying to play 4:4:4 YCbCr content by saying that an AYUV connection is available. In other words, feeding AYUV to the MS renderers as the main pin's content pretty much means a slideshow. Also, EVR-CP (MPC-HC's customized EVR renderer, also their default), if I recall correctly, is not capable of switching types on the fly, so I guess it was just found out to be simpler to just block it altogether unless the user specifically wants 8bit 4:4:4 YCbCr output.
[I'm human, no debug]
21st February 2013, 21:23 | #14215 | Link | |
21st February 2013, 22:11 | #14217 | Link |
Broadband Junkie
At the moment, using xy-VSFilter with madVR would be the primary reason to enable AYUV in LAV Video.
Note: Adding YV24 support to xy-VSFilter is something on our to-do list. AYUV was just an easier first target since it was already supported internally. |
21st February 2013, 23:03 | #14218 | Link |
As it was already explained, EVR/hardware support for AYUV is just so bad that it was better to disable it. madVR also accepts YV24, so no reason to active it for madVR alone.
22nd February 2013, 20:19 | #14219 | Link |
What are the recommended mix levels for 5.1 audio output? Also, if the number of source channels matches the output channels then no mixing occurs correct?
I wish there was a table listing all the recommended mix levels for all output speaker configurations. |
