20th September 2011, 03:46 | #10123 | Link | ||
http://littleimg.com/public/view/full/6735 it looks like compression to me maybe when I have time I'll go look at my bd25 encode of this and see if I see the same thing |
20th September 2011, 05:13 | #10124 | Link |
C:\>"C:\Program Files (x86)\Ripbot\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\Ripbot\tools\avs2yuv\avs2yuv.exe" "C:\temp\RipBot264temp\job1\job1.avs" - : "C:\Program Files (x86)\Ripbot\tools\x264\x264_x64.exe" --pass 1 --bitrate 4551 --stats "C:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 199824 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "C:\temp\RipBot264temp\video.264" - : 2
y4m [info]: 1280x720p 1:1 @ 10000000/417083 fps (cfr) x264 [info]: using SAR=1/1 x264 [warning]: VBV bitrate (25000) > level limit (20000) x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT x264 [info]: profile Main, level 4.0 C:\temp\RipBot264temp\job1\job1.avs: 1280x720, 10000000/417083 fps, 199824 frames x264 [info]: frame I:1946 Avg QP:15.85 size:115593 x264 [info]: frame P:102275 Avg QP:18.75 size: 35955 x264 [info]: frame B:95603 Avg QP:21.13 size: 8323 x264 [info]: consecutive B-frames: 21.1% 41.0% 13.4% 24.6% x264 [info]: mb I I16..4: 35.6% 0.0% 64.4% x264 [info]: mb P I16..4: 23.7% 0.0% 0.0% P16..4: 61.4% 0.0% 0.0% 0.0% 0.0% skip:14.8% x264 [info]: mb B I16..4: 2.9% 0.0% 0.0% B16..8: 28.4% 0.0% 0.0% direct:11.8% skip:56.9% L0:30.0% L1:45.1% BI:24.9% x264 [info]: final ratefactor: 18.38 x264 [info]: coded y,uvDC,uvAC intra: 47.9% 53.6% 18.7% inter: 25.9% 20.4% 1.3% x264 [info]: i16 v,h,dc,p: 37% 26% 26% 11% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 18% 21% 19% 4% 10% 6% 7% 6% 9% x264 [info]: i8c dc,h,v,p: 54% 24% 19% 3% x264 [info]: Weighted P-Frames: Y:4.2% UV:1.2% x264 [info]: kb/s:4509.44 encoded 199824 frames, 63.45 fps, 4509.44 kb/s C:\>"C:\Program Files (x86)\Ripbot\tools\avs2yuv\pipebuf.exe" "C:\Program Files (x86)\Ripbot\tools\avs2yuv\avs2yuv.exe" "C:\temp\RipBot264temp\job1\job1.avs" - : "C:\Program Files (x86)\Ripbot\tools\x264\x264_x64.exe" --pass 2 --bitrate 4551 --stats "C:\temp\RipBot264temp\job1\job1.stats" --fps 24000/1001 --force-cfr --min-keyint 24 --keyint 240 --frames 199824 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --filter 0,0 --ref 3 --bframes 3 --b-adapt 1 --b-pyramid none --subme 7 --aq-mode 1 --trellis 1 --partitions all --me umh --stdin y4m --output "C:\temp\RipBot264temp\video.264" - : 2 y4m [info]: 1280x720p 1:1 @ 10000000/417083 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast FastShuffle SSEMisalign LZCNT x264 [info]: profile High, level 4.0 C:\temp\RipBot264temp\job1\job1.avs: 1280x720, 10000000/417083 fps, 199824 frames x264 [info]: frame I:1946 Avg QP:17.41 size: 99923 x264 [info]: frame P:102275 Avg QP:19.11 size: 36101 x264 [info]: frame B:95603 Avg QP:22.11 size: 8918 x264 [info]: consecutive B-frames: 21.1% 41.0% 13.4% 24.6% x264 [info]: mb I I16..4: 15.4% 67.6% 16.9% x264 [info]: mb P I16..4: 3.6% 11.8% 1.6% P16..4: 44.9% 17.8% 4.9% 0.6% 0.7% skip:14.1% x264 [info]: mb B I16..4: 0.3% 0.7% 0.1% B16..8: 42.5% 6.3% 1.4% direct: 3.6% skip:45.1% L0:38.3% L1:49.9% BI:11.8% x264 [info]: 8x8 transform intra:68.9% inter:66.2% x264 [info]: coded y,uvDC,uvAC intra: 65.6% 70.2% 35.0% inter: 28.6% 30.1% 2.2% x264 [info]: i16 v,h,dc,p: 41% 24% 7% 28% x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 16% 15% 25% 6% 8% 8% 8% 7% 8% x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 19% 18% 6% 10% 9% 9% 7% 7% x264 [info]: i8c dc,h,v,p: 54% 22% 18% 5% x264 [info]: Weighted P-Frames: Y:4.7% UV:1.2% x264 [info]: ref P L0: 65.2% 15.3% 12.6% 6.6% 0.2% x264 [info]: ref B L0: 90.1% 9.9% x264 [info]: kb/s:4549.17 encoded 199824 frames, 29.16 fps, 4549.17 kb/s C:\>"C:\Program Files (x86)\Ripbot\tools\tsmuxer\tsmuxer.exe" "C:\temp\RipBot264temp\job1\tsmuxer.meta" "C:\Users\Mike\Desktop\The Tree of Life 2011 720p BluRay x264 DTS-WiKi.AVCHD" SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net Decoding H264 stream (track 1): Profile: High@4.0 Resolution: 1280:720p Frame rate: 23.976 H.264 stream does not contain fps field. Muxing fps=23.976 Decoding DTS stream (track 2): Bitrate: 1536Kbps Sample Rate: 48KHz Channels: 5.1 Processed 199825 video frames Creation of AVCHD playlist Creation of AVCHD stream info and seek index Muxing time: 1 min 45 sec C:\>rd "C:\Users\Mike\Desktop\The Tree of Life 2011 720p BluRay x264 DTS-WiKi.AVCHD\CERTIFICATE\BACKUP" C:\>rd "C:\Users\Mike\Desktop\The Tree of Life 2011 720p BluRay x264 DTS-WiKi.AVCHD\CERTIFICATE" C:\>rd "C:\Users\Mike\Desktop\The Tree of Life 2011 720p BluRay x264 DTS-WiKi.AVCHD\BDMV\AUXDATA" C:\>rd "C:\Users\Mike\Desktop\The Tree of Life 2011 720p BluRay x264 DTS-WiKi.AVCHD\BDMV\BDJO" C:\>rd "C:\Users\Mike\Desktop\The Tree of Life 2011 720p BluRay x264 DTS-WiKi.AVCHD\BDMV\JAR" C:\>rd "C:\Users\Mike\Desktop\The Tree of Life 2011 720p BluRay x264 DTS-WiKi.AVCHD\BDMV\META" ------------------------- Elapsed Time: 02h:48m:52s Can no one figure it out my issue through this log I have provided? Last edited by mrpitman; 20th September 2011 at 19:27. |
21st September 2011, 01:16 | #10125 | Link | |
Especially, since I found this thread on Videohelp that seems to discuss the exact problem I brought up starting at post #7. From the thread and my own experience, it seems like the problem is one of two things: either there is some type of decode and/or encode problem with VC1 sources, or it's working as intended and your monitor black levels need to be at a certain setting. I would lean towards the former as non-VC1 sources seem to come out ok. |
21st September 2011, 01:50 | #10126 | Link | |
http://littleimg.com/public/view/full/6739 |
21st September 2011, 02:29 | #10127 | Link | |
21st September 2011, 03:35 | #10130 | Link |
So what is this suppose to help me? I'm just trying to figure out why it's pausing (video), and audio keeps going, audio and video out of sync (periodic pausing). That site is just jibberish to me and don't understand any of it. |
21st September 2011, 10:23 | #10131 | Link |
21st September 2011, 12:46 | #10132 | Link |
Hey Atak ,
Can you tell us where do we find parameters like that one shown above ( keyint 24 ) ???? Reading this site I saw that are much more such "extra" parameters .... I'm interested in them . Are these new parameters made by you or we can find them on a list or smth like that ?? Default Ripbot has few parameters ; where do we find the other ones ??? Thanks for replay !! PS : I've already tried few times to put some extra parameteres within code box but most of them gave errors....It must be sort of special syntax .... If you agree I can send to you those few extra parameters I need , to show me their syntax for Ripbot . Last edited by benjyv; 21st September 2011 at 12:59. |
21st September 2011, 12:53 | #10133 | Link |
x264.exe --longhelp
22nd September 2011, 18:29 | #10137 | Link |
YIPPPY. I found a solution, work around, to my audio sync issues. There is this program called Reclock that deals with the PAL 25fps issue, but it does other FPS's and it keeps things at the correct fps. Well Reclock makes x264, avs2avi and Bepipe stay at the proper fps. Success. In sync file.
@Atak So with this info, what do you think I have a bad .Net install, driver, ripbot, or what? I uninstalled everything and reinstalled only the required ripbot software + MPC and I still had sync issues. Any guesses? Last edited by rc71; 22nd September 2011 at 19:29. |
23rd September 2011, 21:42 | #10138 | Link |
Hi, quick question. Is there any way to get Ripbot to send the computer to sleep rather than shutdown when finished jobs? Its not a major issue but i like my PC to sleep when not in use, but i have to get it to shutdown every time i leave a batch running if i know im going to be out or busy when the queue is finished.
24th September 2011, 02:12 | #10139 | Link | |
24th September 2011, 15:25 | #10140 | Link |
Sorry but i dont always want my PC to sleep when its idle, sometimes i do though and that is why i asked this question. If ripbot has the ability to turn off the PC when it is finished, surely adding sleep, lock, hibernate functions is possible, and wont hurt it.
