12th June 2005, 14:59 | #941 | Link | |
btw it seems there is a problem starting an encode right from inside the gui, because it seems that your build seems to assume that x264.exe is in the path c:\ and not in the folder of x264gui edit: it seems this only happens when you load defaults (if you dont do it the encoding process starts fine) btw: can you disable the debug mode by default plz
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 12th June 2005 at 15:08. |
12th June 2005, 16:33 | #942 | Link |
I like the new detailed GUI in rev. 260A!
I'm not sure what exactly you would like to have tested. But at least I was able to successfully encode a video (see the "Terragen" thread). Just one issue I faced: Just for fun, I used 4 threads on a single Duron CPU. At the end of the encoding, I get "possible live-locks" (I/O thread not cycled for 10 seconds, later even the main thread). But one click on "OK", and the Dub window closes and the AVI is fine. |
12th June 2005, 17:18 | #943 | Link |
Pain and suffering
"btw: can you disable the debug mode by default plz"
My thoughts exactly And about the x264.exe dir, i think its best to select where x264.exe is when you first run the gui (and after reset load defaults). Then people know where the x264.exe is, and people know what and where they are working. More knowledge is more test results |
12th June 2005, 17:28 | #944 | Link | |
p.s. The extended vfw dialog is awsome. celtic_druid rocks! Last edited by hpn; 12th June 2005 at 17:49. |
12th June 2005, 17:36 | #945 | Link |
@ hpn:
But the warning list gets longer and longer if I don't close it. It seems to wait for a not correctly terminated thread, in my opinion. But it may be hard to determine the real reason. Unfortunately, if you try a batch encode (or e.g. GordianKnot running n-pass), each pass would halt here until the user presses "OK". |
12th June 2005, 18:06 | #946 | Link | |
Vdub ->Options->Preferences->Process Priority (Norma or High) -> click "SAVE" (not Accept) (OT here, but anyway) |
12th June 2005, 22:42 | #947 | Link |
Life's clearer in 4K UHD
The new GUI in build X264VFW_rev260A_mmx.exe looks okay: -
PAR signalling appears to work fine too.... I will do some more tests tomorrow Many thanks guys
12th June 2005, 23:18 | #948 | Link |
i think that "direct mode" and "weighted biprediction" should be grouped together with "b-frames". i dont think they belong to "analysis"
also i wouldnt enable everything by default, eg p4x4 is disabled in mencoder by default, after all enabling everything also slows things down also i would disable the high profile features by default, cause they will definitely lead to interoperability problems (eg with quicktime). only people who know what they are doing should enable this
Between the weak and the strong one it is the freedom which oppresses and the law that liberates (Jean Jacques Rousseau) I know, that I know nothing (Socrates) MPEG-4 ASP FAQ | AVC/H.264 FAQ | AAC FAQ | MP4 FAQ | MP4Menu stores DVD Menus in MP4 (guide) Ogg Theora | Ogg Vorbis use WM9 today and get Micro$oft controlling the A/V market tomorrow for free Last edited by bond; 12th June 2005 at 23:23. |
12th June 2005, 23:19 | #949 | Link |
clueless n00b
btw, zones are still missing
13th June 2005, 00:50 | #951 | Link |
Mr. Sandman
Rev261 is up and contains all the new stuff. We'll discuss the defaults tomorrow (need to sleep now) and maybe even a new fast first pass...
13th June 2005, 06:09 | #954 | Link |
Derek Prestegard IRL
Gosh I stop paying attention for one freaking day and all of a sudden theres a new GUI and all sorts of nice improvements!
Open Source development is really far too cool.
These are all my personal statements, not those of my employer :) |
13th June 2005, 07:40 | #956 | Link |
Well you can kinda enter 32. You just have to enter say 12, then change the 1 to a 3. Not sure what to do about it. Guess I could just remove the < 4 check.
Moved the < 4 check so that it checks when it reads from the registry and when it parses the param. So you can now enter a value < 4, but you will just get 4. Last edited by celtic_druid; 13th June 2005 at 07:50. |
13th June 2005, 07:44 | #957 | Link |
Depends on the event you use for validity checks. Being a programmer myself, I experienced that quite often. Better don't check values on each and every change, instead do it only when the focus is taken away from the edit field (don't know how the event handler is called in your programming language: OnExit, OnBlur, ...).
13th June 2005, 08:18 | #959 | Link |
Usually, text fields needs only to be checked when pressing the OK button. Alternatively, the OK button can be disabled if a field is incorrect. EN_KILLFOCUS has an issue : it isn't necessary called ( i once stumbled accross a blog from a microsoft dev saying not to use the killfocus notification because of that reason ).
