29th January 2009, 09:05 | #2581 | Link | |
thx odin24 but again its not working!! lol this is a big mystery ... i put my specs vista home quad core 6600 gc geflorce 8800 gts software used kmplayer powerdvd 8 i have a ps3 i try with a lot of differents movies but nothig.. |
29th January 2009, 10:22 | #2585 | Link |
i just try to make a 1280x720 br/ps3with ts muxer ,so in the resolutionsthat you said upper but nothing appears...
i have checked with powerdvd 8 use also with mkv2avi (hi dean!!) it doesn t work.. Last edited by ericd; 29th January 2009 at 10:41. |
29th January 2009, 12:54 | #2587 | Link | |
Nom complet : L:\alt.binaries.hdtv.x264\sg.mkv Format : Matroska Taille du fichier : 6.56 Gio Durée : 2h 23mn Débit global moyen : 6531 Kbps Date d'encodage : UTC 2007-10-29 22:30:59 Application utilisée : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07 Bibliothèque utilisée : libebml v0.7.7 + libmatroska v0.8.1 Vidéo Format : AVC Format/Info : Advanced Video Codec Profil du format : High@L5.1 Paramètres du format, CABAC : Oui Paramètres du format, RefFrames : 8 images Identifiant du codec : V_MPEG4/ISO/AVC Durée : 2h 23mn Débit : 5623 Kbps Débit nominal : 5888 Kbps Largeur : 1280 pixels Hauteur : 720 pixels Format à l'écran : 16/9 Images par seconde : 23.976 Im/s Colorimétrie : 4:2:0 Type d'image : Progressif Bits/(Pixel*Image) : 0.266 Bibliothèque utilisée : x264 core 56 svn-680 Paramètres d'encodage : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5888 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 Langue : Anglais Audio Format : AC-3 Format/Info : Audio Coding 3 Identifiant du codec : A_AC3 Durée : 2h 23mn Type de débit : Constant Débit : 640 Kbps Canaux : 6 canaux Position des cannaux : Front: L C R, Rear: L R, LFE Echantillonnage : 48.0 KHz here is my file i rename the title and put in level 4.1 yes for the 2 questions deank thx again Last edited by ericd; 30th January 2009 at 08:16. |
29th January 2009, 17:18 | #2590 | Link |
Feature Request!
Option to create AVCHD! The Samsung BDP-2500 declined playback on ALL discs that I tried which played perfectly on Samsung BD-P1400 and Panasonic DMP-BD30! The reason is amost impossible and it took quiet a while to pinpoint that "problem". The unneccesary folders, which only are used for real Blu-Ray. Just deleting the unused foldes out of a "Blu-Ray" makes it playable on the Samsung BD-P1400. Thanks Rodger |
29th January 2009, 18:30 | #2591 | Link | |
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 V_MPEG4/ISO/AVC, "L:\x264\sg.mkv", level=4.1, insertSEI, contSPS, track=1, lang=eng A_AC3, "L:\x264\sg.mkv", track=2, lang=eng S_TEXT/UTF8, "L:\x264\sg.srt",font-name="Times New Roman",font-size=60,font-color=0x00FFFFFF,font-charset=1,bottom-offset=16,font-border=1,text-align=center,video-width=1280,video-height=720,fps=23.976, lang=fre thx ericd Last edited by ericd; 29th January 2009 at 18:50. |
29th January 2009, 22:28 | #2592 | Link | |
30th January 2009, 01:22 | #2593 | Link | ||
from ericd's post...
Just going by the info from all the threads that I have read. Do not have a PS3 myself.
Vista SP1 32-bit w/4GB RAM AMD Athlon 64 X2 4400+ @ 2.23GHz nVidia GeForce 8400GS w/512MB RAM Last edited by smnckl; 30th January 2009 at 01:23. Reason: Added disclaimer |
30th January 2009, 04:10 | #2594 | Link | |
Hey Now!
30th January 2009, 08:14 | #2596 | Link | |
As u can see, with the meta file i have change to level 4.1,and nothing appears!!thx for your help thx jamo and smckl and deank and all others.. MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 V_MPEG4/ISO/AVC, "L:\x264\sg.mkv", level=4.1, insertSEI, contSPS, track=1, lang=eng A_AC3, "L:\x264\sg.mkv", track=2, lang=eng S_TEXT/UTF8, "L:\x264\sg.srt",font-name="Times New Roman",font-size=60,font-color=0x00FFFFFF,font-charset=1,bottom-offset=16,font-border=1,text-align=center,video-width=1280,video-height=720,fps=23.976, lang=fre |
1st February 2009, 07:54 | #2598 | Link | |
Unfortunately, changing the level when remuxing in tsMuxeR will not help since it does not correct the reference frames. From what I have read, you will need to re-encode using x264. @all, please correct me if I am wrong.
Vista SP1 32-bit w/4GB RAM AMD Athlon 64 X2 4400+ @ 2.23GHz nVidia GeForce 8400GS w/512MB RAM |
1st February 2009, 09:07 | #2599 | Link | |
Furthermore, For 1080p content: reference frames should be < 5 (although 5 reportedly seems to work at times). For 720p content: reference frames should be < 10 (haven't confirmed this, btw; I thought it was still at max 4). All content: b-frames should be < 4.
Gorgeous, delicious, deculture! Last edited by asarian; 1st February 2009 at 10:06. |
1st February 2009, 10:26 | #2600 | Link | |
tsmuxer |
