12th June 2014, 12:28 | #17601 | Link |
Forgot to push the ffmpeg repo, apparently. All fixed.
12th June 2014, 18:02 | #17602 | Link |
LAV Filters 0.62.0
LAV Splitter - Fixed: The filtered Forced Subtitles stream did not properly send all related subtitle data in some cases LAV Video - NEW: Implemented a WMV9 MFT decoder to replace the old DMO decoder for VC-1/WMV3 on Windows 7 and above - NEW: Support for VP7 video - Fixed: Multi-threaded video decoding could result in a handle leak on some systems - Fixed: Video processing was slow on Windows XP due to inefficient memcpy use - Fixed: DVD subtitles could overlap on some discs LAV Audio - Fixed: Dynamic format switching to an audio stream with a different sample rate did not work in some cases Mostly pushing this release to get updated ffmpeg libraries out, as well as not cause the new things to rot too long. WMV9 MFT As it appears, the WMV9 DMO decoder is kinda broken on Windows 8.1, it doesn't properly identify interlaced videos anymore, which causes them to never engage deinterlacing. To solve this problem, I've implement a new wrapper around Microsofts decoder, using the MFT (Media Foundation Transform), instead of the DMO. DMOs are a tech from Windows XP and before, and are really old and deprecated, while MFTs are new and clearly better supported - plus getting the information I need out of it was actually quite a bit easier than with the DMO before. Note that this has no influence on anything DirectShow, LAV is not a Media Foundation filter all of the sudden, it just happens to use the WMV9 MFT, nothing else changes. Anyway, have fun, and as always report any regressions you find.
14th June 2014, 09:46 | #17607 | Link |
LAV Video decoder Properties -> Formats , still say "Use Microsoft WMV9 DMO decoder ....".
Also, having installed both versions (x86 & x64), I realized that whatever change I do to one version properties (for example x86 from DXVA native to DXVA copy-back), it happens also to the other version (x64) and the opposite. Is it normal ?
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all Last edited by NikosD; 14th June 2014 at 10:25. |
14th June 2014, 22:30 | #17608 | Link | |
15th June 2014, 11:53 | #17609 | Link |
4:2:0 hater
Nev, it seems I have some MPEG-1 videos that LAV Video doesn't decode. Windows MPEG's decoder is used instead.
Here's one that does decode with LAV Video: http://www.mediafire.com/watch/ajj0mc8z4874kf4 And here one that doesn't: http://www.mediafire.com/watch/s867ud5hbond1a8 |
15th June 2014, 13:27 | #17610 | Link | ||
SuperVirus
BTW, you should already have learned how to use MediaFire in the RIGHT way Quote:
15th June 2014, 15:10 | #17611 | Link |
4:2:0 hater
Funny, only happens when playing in MPC-HC, LAV Video is used for both in GraphStudioNext. No idea what could be causing it, settings are the same of course.
I know how to use MediaFire, it's just that I consider the people on this forum smart enough to press the "Download" button right by the video preview I purposedly used. Guess I'll have to make an exception with you from now on |
16th June 2014, 19:27 | #17614 | Link | |
SuperVirus
it is in the most recent builds of MPC-HC (which I don't use BTW ~~ I tested the sample with MPC-HC Lite 1.6.8.7391 and MPC-BE 1.4.3.4793). |
17th June 2014, 02:49 | #17617 | Link | |
In any case, a file showing the problem would be good.
18th June 2014, 04:11 | #17619 | Link |
Hello, I am trying to do some complex stream selection rules in the advanced section but its not working. Here is what I got going:
jpn|d:eng|d;jpn|!d:eng|!d so if jpn audio is default then load english subtitle that is default and if jpn audio is not default then load english subtitle that is not default. However what ends up happening is that it loads the jpn audio but it doesn't load any subtitles at all. I guess its only looking at that I set preferred audio in the dialog above to jpn,eng. I am doing this because some anime I have are english audio default and the default subtitle track is for signs/songs. However everything else I have is japanese audio default with default full english subs. If there is an easier way to do this that I am overlooking let me know. The main problem I am having is the usual jpn:eng chooses the first track which on this particular anime is the english signs rather than full subs. My guess is that the code doesn't look at whether the audio track has been flagged default or not so its simply not working there because it is expecting a three letter value and doesn't know what jpn|d means. Last edited by Nachbar; 18th June 2014 at 04:47. |
18th June 2014, 05:30 | #17620 | Link | |
Nev can we get this requested feature of selecting subtitles by substring match added in LAV? Last edited by ryrynz; 18th June 2014 at 05:32. |
