Old 12th September 2009, 21:45   #8041  |  Link
Porsche_fan
I have noticed that postprocessing doesn’t work when using ffdshow to decode a Windows Media Advanced Profile (VC-1) file. However, if I use MPC’s built in codec VC1 (FFmpeg) codec to decode and then use ffdshow set to Raw Support, I can utilize ffdshow’s postprocessing.
I’ve tried other players and had the same experience where postprocessing doesn’t work if ffdshow decodes. Also tried several of the recent builds too.
Is there a reason for ffdshow’s codec to disable ffdshow’s postprocessing for this file format?
Porsche_fan is offline   Reply With Quote
Old 12th September 2009, 23:00   #8042  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Not sure, but AFAIK the WMV9/VC-1 format has a "built-in" deblock filter that is always enabled, because it's an inherent part of the encoding/decoding process.
That's similar (but not identical) to H.264's Inloop-Deblocking. Therefore it would make sense to disable additional Post-processing for those formats...
Old 12th September 2009, 23:28   #8043  |  Link
Px
>>^^__^^<<
Px's Avatar
BatKnight
Mercury_22
Use Process Monitor utility to see registry and file activity on your system while hang, maybe that helps to track down the problem
Px is offline   Reply With Quote
Old 13th September 2009, 02:39   #8044  |  Link
BatKnight
BatKnight's Avatar
Originally Posted by Px View Post
BatKnight
Mercury_22
OK, I've done it.
I used Process Monitor to isolate the REGSVR32.EXE process during ffdshow installation and found out that it hangs with full CPU when registering ffdshow.ax
Here is a file with 2 logs in PML format (Process Monitor) showing everything. One is during the ffdshow installation and the other one is just a "regsvr32 /s ffdshow.ax"
http://stashbox.org/629584/logfiles.rar
Both give the same problem: the process hangs forever eating all CPU.
I have other information: I've tested the ICL 11.1.038 ffdshow on my notebook which is a C2D T4200 with Intel chipset and Windows 7 x64 and it gave the same exact problem. So I can reproduce this problem on both Win 7 x64 and Win 7 32bits.
On x64 I've noticed that it uses the 32bit regsvr32.exe, if this is of any importance.
If any ffdshow developer needs further testing, just let me know.
Bat
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers
MPC Home-Cinema
madVR
LAV Filters
BatKnight is offline   Reply With Quote
Old 13th September 2009, 02:47   #8045  |  Link
Snowknight26
That's normal when you're using the 32-bit version of ffdshow.
Snowknight26 is offline   Reply With Quote
Old 13th September 2009, 03:13   #8046  |  Link
GrofLuigi
Member of a Library
BatKnight,
From a quick glance on your procmon log I can guess what could have interfered:
Eset
PunkBuster
DEP
Prefetch (if corrupt?)
For more, I think you'd need to disable "drop filtered events" if used, and not restrict logging to regsvr32 only...
GL
GrofLuigi is offline   Reply With Quote
Old 13th September 2009, 03:29   #8047  |  Link
Porsche_fan
@ LoRd_MuldeR.
That makes sense. However, it was exactly that built in deblocking feature of wmv9 that I was hoping to take advantage of and couple it with ffdshow’s postprocessing deblocker.
Additionally, it would be helpful to use the postprocessing deblocking when decoding wmv videos with libavcodec. Within ffdshow it appears that for wmv decoding, deblocking occurs with wmv9 selected as the codec. However, the internal deblocking function doesn’t appear to occur, or is extremely minimal, with libavcodec. MPC’s FFmpeg decoding for wmv also appears to be missing the internal deblocking function too.
If it is possible, I think it would be beneficial to enable within ffdshow postprocessing with wmv decoding, allowing the flexibility to mix and match deblocking methods with different wmv decoders. As sometimes some deblocking is required but the wmv9 codec is a little too aggressive, resulting in significant loss of detail. In those instances it would be nice to be able to use libavcodec combined with ffdshow's postprocessing deblockers.
Old 13th September 2009, 09:57   #8048  |  Link
FoLLgoTT
And so it begins...
FoLLgoTT's Avatar
Very helpful links. Do you have similar streams for 5.1 or 6.1?
FoLLgoTT is offline   Reply With Quote
Old 13th September 2009, 11:36   #8049  |  Link
nm
What do you mean by "internal deblocking"? Libavcodec does in-loop deblocking, but it doesn't do postprocess (out-loop) deblocking that Microsoft's wmv decoder does by default. For postprocess deblocking you are supposed to use ffdshow's filters, which should satisfy all your requirements. So are you suggesting that one of those filters should be enabled automatically for wmv decoding?
Old 13th September 2009, 14:04   #8050  |  Link
Px
>>^^__^^<<
Px's Avatar
OK, I've done it.
In addition to GrofLuigi answer:
Last event with regsvr32 in your logs is querying HKCU\Software\GNU\ffdshow\allowDPRINTF key, I've installed same version on my system to see, what regsvr32 doing next. In my case, it was querying keys HKCU\Software\GNU\ffdshow\isBlacklist and HKCU\Software\GNU\ffdshow\blacklist. Try to delete this keys and reinstall ffdshow again
Old 13th September 2009, 14:08   #8051  |  Link
LoRd_MuldeR
Software Developer
VC-1/WMV9's deblocking is an inherent part of the encoding and decoding process. It's technically impossible to use that for anything other than WMV9/VC-1!
And VC-1/WMV9 cannot be decoded (properly) without its "built-in" deblocking.
You miss the point: We are NOT talking about "different deblocking methods" here! The buit-in deblocking is part of the WMV9/VC-1 specifications. Any WMV9 decoder does apply it and all WMV9 decoders must do it in the exactly same way! At the same time the "post-processing" filter in ffdshow is 100% format-independent and it's optional. It is applied after the video is returned from the decoder. Since the video returned from the VC-1/WMV9 decoder already has been deblocked (same goes for H.264 video!), there is no need for additional post-processing. Applying additional post-processing to WMV9 or H.264 wouldn't be beneficial in 99% of all cases. Therefore it is a good idea to skip the "post-processing" for VC-1 and H.264, in order to protect the user from deblocking the video twice and thus getting bad quality...
(I remember that back at the time when I experimented with H.264 for the very first stime, I wasn't satisfied at all. Until I turned of the additional post-processing and got great results ^^)
Old 14th September 2009, 09:34   #8052  |  Link
Mercury_22
Sorry NO
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 14th September 2009, 18:06   #8053  |  Link
Porsche_fan
No I wasn’t suggesting anything should be automatic. What I have observed is that ffdshow’s postprocessing filter is nonfunctional when ffdshow decodes wmv video using either the wmv9 codec or the libavcodec. It appears that ffdshow deactivates the postprocessing filters for wmv files.
My suggestion is that ffdshow users be given the ability to engage ffdshow’s postprocessing filters, if they so chose, when using either wmv9 or libavcodec to decode a wmv file.
LoRd_MuldeR I apologize if I misunderstand what you are saying, however, there is a deblocking difference between decoding using ffdshow’s wmv9 filter alone verses ffdshow’s libavcodec filter alone. Maybe not the best example but here are two scene shots demonstrating this point with ffdshow decoding both...no other filters applied.
Libavcodec
wmv9
As I mentioned within ffdshow the wmv format prevents access to ffdshow's postprocessing. I can understand your point that many times it may be detrimental to allow the user to deblock twice unknowingly. However, especially in the case of using libavcodec, I believe allowing the user to select from customizable deblocking methods available within ffdshow’s postprocessing would be beneficial.
Old 14th September 2009, 18:19   #8054  |  Link
LoRd_MuldeR
Software Developer
That definitely shouldn't be the case. Two standard-compliant decoders should always give identical output for identical input.
Given that libavcodec isn't broken, I suspect that M$'s WMV9 decoder has some additional filtering that goes beyond the standard VC-1 deblocking
(BTW: Cannot see your screenshots)
Well, maybe a "Skip additional post-processing" option (enabled by default!) could be added to "WMV9" and "VC-1" on the "Codecs" page.
Let's wait for the ffdshow developers to comment on this...
Old 15th September 2009, 21:38   #8055  |  Link
XhmikosR
@devs: 64bit compilation is broken in rev3075.
EDIT: It seems the changes in makefile_c.inc break 64bit compilation.
XhmikosR is offline   Reply With Quote
Old 15th September 2009, 23:04   #8056  |  Link
clsid
Use this MinGW64 build:
http://sourceforge.net/projects/ming...1.zip/download
MPC-HC 2.2.1
Old 15th September 2009, 23:38   #8057  |  Link
BatKnight
BatKnight's Avatar
Libavcodec
wmv9
Well, there is indeed a very noticeable difference between the two decoders. Could a ffdshow developer take a look on this?
If you can't see the screenshots let me know and I'll post a copy on different server if Porsche_fan allows me.
Bat
MPC Home-Cinema
madVR
LAV Filters
Old 16th September 2009, 00:57   #8058  |  Link
Porsche_fan
I've always thought it was intentional as wmv9's deblocking is either too aggressive or nonselective. The result is decoding with wmv9 almost always produces a softer (slightly blurred) image compared to libavcodec.
So I hope that libavcodec will remain as it is...I'd just like the ability to apply postprocessing deblocking to both wmv9 and libavcodec for all types of wmv files.
Normally, I don't like to use deblocking or NR filters as I feel they tend to destroy too much detail. However, in the case of HD content, frequently they are created with low bits/pixel to keep the file size down. The end result however, is an increased tendency towards blocking.
I like your idea for a solution. Hopefully, it is easy to implement.
@BatKnight
I have no objection to anyone rehosting the pics. Thanks
Old 16th September 2009, 01:23   #8059  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Yes, libavcodec doesn't implement WMV9's optional postprocessing deblockers.
Old 16th September 2009, 01:23   #8060  |  Link
alexins
MPC-BE DEV
alexins's Avatar
In the file "makefile_c.inc" the error is made:
ifeq ($(64BIT),yes)
    TARGET_OS=x86_64-pc-mingw32
    CFLAGS+=-DWIN64 -D_WIN64 -D__MINGW64__
    OPTFLAGS+=-O2 -m64
else
Given the changes in revision 3075, should be so:
ifeq ($(64BIT),yes)
    TARGET_OS=x86_64-w64-mingw32
    OPTFLAGS+=-O2 -m64
else
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR
Media Player Classic - BE x86/x64. Team of developers.
alexins is offline   Reply With Quote
