27th March 2009, 19:57 | #7001 | Link |
@mark0077
Just drag&drop a file into it. The graph gets build automatically. @ikarad http://gitorious.org/users/astrange
MPC-HC 2.2.1 |
27th March 2009, 20:20 | #7002 | Link |
Media Control author
There is a problem since version 2787
Revision 2786 is fine Revision 2790 is not. It corresponds to an update of libmplayer Problem : ffdshow crashes in Media Center I have checked, this problem is different from the one I saw earlier. The crash is located here : Twscale.cpp void Tswscale::done(void) { if (swsc) libmplayer->sws_freeContext(swsc);swsc=NULL; } and the message of VS is "This may be due to a corruption of the heap". I have no idea of how to analyze it Thank you for any help |
27th March 2009, 20:32 | #7003 | Link |
In which revision things go wrong? 2788, 2789, or 2790?
MPC-HC 2.2.1 |
28th March 2009, 07:56 | #7005 | Link | |
I'm writing about preset settings. Does it help? You need a preset settings named ffdscaler. |
28th March 2009, 10:56 | #7007 | Link | |
However, I will soon post a big translation patch.
Mystérieuse Amour |
28th March 2009, 13:27 | #7008 | Link | |
In 2788 I have cleaned up the config.h file, removing malloc and free defines. Same functions are defined in mem.c/h and those are now used instead. Only difference is their names: av_free, av_malloc. Maybe a wrong name is still being used somewhere in the code. See if adding the two defines back to config.h solves the crash. edit: I have spotted a few uses of malloc in yuv2rgb.c. I will replace them with av_malloc. That might fix it.
MPC-HC 2.2.1 Last edited by clsid; 28th March 2009 at 13:31. |
28th March 2009, 14:07 | #7009 | Link | |
However, it's a small function. There are many similar "getVersion" in other dlls. If you are interested in C/C++, it's a good place to start. And good news, translations are welcome. |
28th March 2009, 14:32 | #7010 | Link | |
Otherwise if I play the video with wmp it works fine. I will test your fixes when available |
28th March 2009, 14:36 | #7011 | Link |
I have committed the changes. Hopefully this will fix it.
MPC-HC 2.2.1 |
28th March 2009, 17:03 | #7013 | Link |
Here is my translation update:
https://sourceforge.net/tracker/?fun...41&atid=867362 It also fixes some English phrases, so I had to edit other translations as well. This explains the number of modified files in this patch.
Mystérieuse Amour |
28th March 2009, 20:27 | #7014 | Link |
I found a problem with ffdshow and MPC HOMEcinema
If I want to see DVD movie with separated subtitles (which doesn't on the dvd), subtitle aren't display if I use open dvd fuinction of MPC Homecinema and subtitle function of FFDSHOW. I use mpc homecinema 1018 and ffdshow 2812 |
28th March 2009, 21:37 | #7015 | Link |
How did you name the subtitle files? If ffdshow doesn't find them, it can't display them. You can also load a subtitle file manually in ffdshow settings if needed.
MPC-HC 2.2.1 |
28th March 2009, 22:42 | #7016 | Link | |
Subtitle can't be displayed by ffdshow only if I use opendvd function in mpc-homecinema (function to see dvd movie). Even manually it doens't work if I use open dvd function of mpc homecinema. To see subtitle I must not use opendvd function and load manually .vob file. subtitle file http://www.zshare.net/info.html?5783...5f87aba3c1024a dvd sample http://www.zshare.net/info.html?5783...800c653aafc20f subtitle file doesn't belong to this dvd but It allow to show the problem. If I use opendvd function to open dvd and load subtitle function of Mpc homecinema subtitle are displayed. But If i use subtile function of ffdshow instead of load subtitle function of mpc homecinema subtitles are not displayed. Last edited by ikarad; 28th March 2009 at 23:13. |
28th March 2009, 23:57 | #7017 | Link |
I don't think this has anything to do with how MPC operates. It is more likely related to the "DVD Navigator" source filter. For example the DirectVobSub subtitle filter only loads when a compatible source filter is in the graph. I suspect something similar applies to ffdshow. Autoloading the correct subtitle file is certainly not going to work when playing a DVD, because when ffdshow asks the source filter for the filename it will just get an empty string (unlike when you play a separate .vob file). So you would have to manually specify the sub file in ffdshow configuration. Although that does not seem to work with DVDs either.
I suggest you use the internal subtitle renderer of MPC instead for manually loading the external subs with DVDs. Or wait for Haruhiko to comment on this. Do you also get an "Integer division by zero" error in MPC when seeking in your sample DVD?
MPC-HC 2.2.1 Last edited by clsid; 29th March 2009 at 00:00. |
29th March 2009, 01:58 | #7018 | Link | |
29th March 2009, 02:56 | #7019 | Link | |
