22nd August 2010, 13:04 | #4281 | Link |
@ robpdotcom & iaTa:
In CCC if you have added 1080p24 to the display manager and then choose 23hz for your refresh rate, when you click apply it will show 24hz - BUT it is actually 23.976hz. At least that's how it works for me. |
22nd August 2010, 19:22 | #4282 | Link |
Suddenly no automatic exclusive Mode anymore
Hi !
For some reason madvr does not go to automatic exclusive mode anymore even if no GUI is shown. I have attached the logfile. Can you see anything in there ? This is with ZoomPlayer on ATI 4770 with Powerstrip, latest 10.7 drivers, Windows 7 x64 on second monitor. Thanks, Alex |
22nd August 2010, 19:33 | #4283 | Link | |
Thanks, Santino A quick update. I was able to come up with a workaround, but it is not ideal. I set up a profile in CCC and set up a hot key to call the profile. Once in exclusive mode I can call that profile and it will change the output to 23.976, but if I go out of exclusive and back, the renderer goes back to 24.001. For now I think I can setup event ghost to do it automatically, but a "force 24p" would be a nice added feature "hint hint". Last edited by SantinoSan; 22nd August 2010 at 19:45. |
22nd August 2010, 20:17 | #4284 | Link | |
Did you read the post I mentioned above?
If not, here's the important part: Quote:
ATI 5670, Cat. 11.3, Win 7/32 (Aero on), 1920x1080x23.976, madVR 0.61 w/ Reclock (bitstream mode), MPC-HC, CoreAVC 2.51 |
22nd August 2010, 22:48 | #4285 | Link |
I did read that, and it does work, but when madVR goes to exclusive mode, it changes the output to 24.001. My desktop is now set to 23.976.
Please disregard. I installed SAF for Media portal, and now magically exclusive mode is now at 23.976. Go figure. Thanks, Santino |
23rd August 2010, 07:18 | #4286 | Link | |
Activate FFDshow's deinterlacing, Yadif preferably, when watching 29.97fps content. |
24th August 2010, 10:02 | #4290 | Link |
madshi,
I'm sure now that 0.27 cause "black screen" & freeze while 0.26 doesn't. Note that it happened more but not exclusive to my dual monitor setup. On the other hand, I think the BSOD is not because of madVR.
Spec: Intel Core i5-3570K, 8g ram, Intel HD4000, Samsung U28D590 4k monitor+1080p Projector, Windows 10. |
24th August 2010, 19:04 | #4291 | Link | |
Still have interlaced videos constantly dropping frames in 0.27 as well. Going back to 0.26 for now. |
25th August 2010, 07:38 | #4292 | Link |
I always get the black screen first time I try with 027. It seems to only happen once and hangs the player, I need task manager to end process, then every time after that its fine until I reboot the machine then it will happen again. This situation is very simular to what happened originally with many nvidia card owners with madVR not working at all due to some slow scan line reporting issue I think madshi said it was.
I also get the random dropped frames with 027 what were not happening at all before and have gone back to previous version. |
25th August 2010, 18:16 | #4293 | Link |
Does madVR output RGB signals? I am trying to set this up so that there is no additional processing done by my video card, so I guess my question is what should my video card output be set to in order to save all the PQ imporvements from madVR? My options are RGB full, RGB limited, 4:2:2, and 4:4:4.
Thanks, Santino |
25th August 2010, 18:22 | #4294 | Link |
Kid for Today
I also seem to get random dropped(not delayed) frames 10/20 secs after seeking from time to time, this didn't occur w/ 0.26 AFAIK.
But seamless playback is very smooth in PotPlayer when seeking between files w/ different AR, it used to stutter a bit in older versions. "RGB full" so your graphic card outputs unmolested 0-255 RGB Last edited by leeperry; 28th August 2010 at 01:28. |
25th August 2010, 18:56 | #4295 | Link |
Thank you for that. I'll have to play around with the rest of the filters in the chain to get them set right. What should madVR be set at? I assume video levels to pass BTB and WTW...is this the case or should I have it set to PC levels?
Thanks, SAntino |
25th August 2010, 19:06 | #4296 | Link |
I'm sure there must be something simple I am overlooking here... I've installed MadVR but MPC still shows it as a greyed-out option. How do I get it enabled?
my setup: Win 7 64bit madvr v0.27 installed via .bat with admin rights Media Player Classic HomeCinema (x86/x64), svn 2345 (i've tried the zip build and the installer both, x86 version only) ATI HD4890 w/ 10.7 drivers |
25th August 2010, 19:35 | #4297 | Link | |
Kid for Today
the first option means: untouched levels, and the second: TV>PC conversion. |
26th August 2010, 07:26 | #4300 | Link | |
