Old 4th January 2020, 14:47   #1841  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Originally Posted by deco20 View Post
Lord_Mulder, I have a problem with determining clip properties. It fails on "Get source info" step, but it seems that the command that is used is ok.
When I run it manually, I get following response:
K:\dg.avs: 1280x534, YV12, 8-bits, progressive, 24000/1001 fps, 154508 frames
From what I saw in the code, this step is about extracting some of these values using regex. Is my output somehow different from the one that is expected by the regex?
Your output from the manual invocation of Avs2YUV looks normal to me. Also, I tried with a similar setup and it seems to work fine for me:
https://i.imgur.com/7k1LJ48.png
I suspect something is going wrong with the Avs2YUV invocation that happens inside Simple x264 Launcher (maybe AVS script fails to load for some reason), so can you please post the complete log from Simple x264 Launcher?
Old 4th January 2020, 15:42   #1842  |  Link
deco20
The script itself looks like these:
DGSource("K:\ToEncode\00000.dgi")
Crop(0, 140, 0, -140)
Spline36Resize(1280, 534)
It is correctly interpreted by AvsPmod and I used to do similar things before.
As for the log, there it is:
[2020-01-04][15:39:30] --- SYSTEMINFO ---
[2020-01-04][15:39:30] Binary Path : C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2
[2020-01-04][15:39:30] Avisynth    : Yes
[2020-01-04][15:39:30] VapourSynth : No
[2020-01-04][15:39:30] --- SETTINGS ---
[2020-01-04][15:39:30] Encoder : x264 (AVC/H.264), 64-Bit (x64), 8-Bit
[2020-01-04][15:39:30] Source  : Avisynth (avs)
[2020-01-04][15:39:30] RC Mode : CRF
[2020-01-04][15:39:30] Preset  : veryslow
[2020-01-04][15:39:30] Tuning  : <None>
[2020-01-04][15:39:30] Profile : High
[2020-01-04][15:39:30] Custom  : --level 4.1 --sar 1:1 --no-fast-pskip --no-dct-decimate --no-mbtree --deblock -3:-3 --ipratio 1.2 --pbratio 1.1 --psy-rd 1.1 --aq-mode 3 --aq-strength 0.7 --aq2-strength 0 --aq2-sensitivity 0 --aq3-mode 0 --bframes 12
[2020-01-04][15:39:30] --- CHECK VERSION ---
[2020-01-04][15:39:30] Detect video encoder version:
[2020-01-04][15:39:30] Creating process:
[2020-01-04][15:39:30] "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x64\x264_x64.exe" --version
[2020-01-04][15:39:31] x264 0.159.2991+49 524a90c t_mod_New [0-bit@all X86_64]
[2020-01-04][15:39:31] (libswscale 5.5.100)
[2020-01-04][15:39:31] (libavformat 58.29.100)
[2020-01-04][15:39:31] (ffmpegsource 2.31.0.0)
[2020-01-04][15:39:31] built on Dec 21 2019, gcc: 9.2.1 20191212
[2020-01-04][15:39:31] x264 configuration: --chroma-format=all--disable-opencl
[2020-01-04][15:39:31] libx264 configuration: --chroma-format=all--disable-opencl
[2020-01-04][15:39:31] x264 license: Non-Free
[2020-01-04][15:39:31] libswscale/libavformat/ffmpegsource license: nonfree and unredistributable
[2020-01-04][15:39:31] WARNING: This binary is unredistributable!
[2020-01-04][15:39:31] Detect video source version:
[2020-01-04][15:39:31] Creating process:
[2020-01-04][15:39:31] "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x86\avs2yuv_x86.exe"
[2020-01-04][15:39:31] Avs2YUV 0.24bm6
[2020-01-04][15:39:31] > x264 revision: 2991 (core #159) - with custom patches!
[2020-01-04][15:39:31] > Avs2YUV version: 0.24.6
[2020-01-04][15:39:31] --- GET SOURCE INFO ---
[2020-01-04][15:39:31] "C:\Program Files (x86)\MuldeR\Simple x264 Launcher v2\toolset\x86\avs2yuv_x86.exe" -frames 1 K:\dg.avs NUL
[2020-01-04][15:39:34]
[2020-01-04][15:39:34] FAILED TO DETERMINE CLIP PROPERTIES !!!
deco20 is offline   Reply With Quote
Old 4th January 2020, 16:03   #1843  |  Link
LoRd_MuldeR
Software Developer
Well, according to your log, Avs2YUV did not produce any text output at all. This means it either ran into some kind of error (but in that case we'd expect to see at least some sort of error message) or it just crashed.
Does that exactly same .avs file open correctly (and seek properly) in the 32-Bit (x86) version of VirtualDub?
Also, please check the following: Does this problem only appear with Avs2YUV 0.24bm6, i.e. is this a new problem in the latest TEST build, or did the same thing already happen with Avs2YUV 0.24bm5?
Old 4th January 2020, 16:45   #1844  |  Link
deco20
Yes, no problems.
It didn't work in the earlier version neither. That's why I updated it to see if it works in the latest one.
Old 4th January 2020, 17:01   #1845  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
Maybe some coincidence under changed circumstances ? Win10, nVidia driver, that route ?
A lead, maybe...
https://forum.videohelp.com/threads/...ith-KNLMeansCL
http://rationalqm.us/board/viewtopic.php?f=8&t=436
Old 4th January 2020, 18:02   #1846  |  Link
LoRd_MuldeR
Software Developer
Yeah, the problems with bugs, especially memory corruptions, is that they often lead to undefined behavior – which means that things may seem to work 99% of the time, but then, all of a sudden, they stop working.
In this situation, every little (seemingly unrelated) change is like rolling the dice again...
What you can try: Strip down your Avisynth script to the bare minimum (e.g. source filter only) and try again. If the problem still appears with the minimal script, try another source filter.
Also: Which exact version of Avisynth are you using? In my experience, the official "v2.6.0 ST" (32-Bit) build is the most reliably. The "MT" builds may introduce all sorts of random hiccups, so try switching back to "ST" if you are using "MT".
(In addition to that, try removing every plug-in DLL from your Avisynth "plugins" directory that is not actually needed, just to be sure!)
Old 4th January 2020, 21:45   #1847  |  Link
deco20
Thanks for suggestions, but none of it worked unfortunately.
I have AviSynth 2.6.0 ST 32-Bit installed. I tried to run it with only source filter in the script, I tried to run with only necessary plugins in AviSynth.
I updated also DGDecNV and NVidia drivers, still the same.
If you work with m2ts files, what source filter do you use?
Old 4th January 2020, 22:10   #1848  |  Link
LoRd_MuldeR
Software Developer
I tend to re-mux M2TS files with MKVToolnix, and then just load the resulting MKV with FFMS2
Old 4th January 2020, 23:05   #1849  |  Link
deco20
Ok, will try that, thank you very much for your help and of course, for your app, it's great.
Old 5th January 2020, 16:31   #1850  |  Link
tormento
Acid fr0g
tormento's Avatar
Here is a new TEST build that has the latest x264 and Avs2YUV versions included
Working here.
@turment on Telegram
Old 5th January 2020, 18:40   #1851  |  Link
gonca
Is this correct?
gonca is offline   Reply With Quote
Old 5th January 2020, 21:44   #1852  |  Link
LoRd_MuldeR
Software Developer
Originally Posted by gonca View Post
Is this correct?
Where do you see this? Did you replace the x264 binaries that were included with the Simple x264/x265 Launcher?
With the x264 binaries that currently ship with Simple x264/x265 Launcher, I see:
x264_x64_launcher\res\toolset\x64\x264_x64.exe --version
x264 0.159.2991 1771b55
(libswscale 5.6.100)
(libavformat 58.35.101)
built on Jan 2 2020, gcc: 9.2.0
x264 license: GPL version 2 or later
libswscale/libavformat/ffmpegsource license: GPL version 2 or later
Old 5th January 2020, 22:01   #1853  |  Link
gonca
In deco20's log
I checked the log on a default download version to compare, because it didn't look right
Edit
I was commenting on deco20's problem
Old 5th January 2020, 22:10   #1854  |  Link
LoRd_MuldeR
Software Developer
In deco20's log
Edit
So, apparently, deco20 has replaced the x264 binaries that ship with Simple x264/x265 Launcher. It looks like he is using the "t_mod_New" build instead.
I just downloaded the latest "t_mod" build from here and checked. Indeed, this build prints the "This binary is unredistributable!" warning – which means that whoever is distributing those binaries is probably violating the license!
Just to make it clear again: Simple x264/x265 Launcher does not ship with "t_mod" build, and never has. Also, this is probably not related to deco20's original problem.
[UPDATE]
New version of x264 "t_mod" build has resolved this issue.
Old 19th January 2020, 11:21   #1855  |  Link
tormento
Acid fr0g
tormento's Avatar
Pssst.... I just noticed you forgot to update x264 & x265 download links
Old 21st January 2020, 08:17   #1856  |  Link
Forteen88
Herr
Here is a new TEST build that has the latest x264 and Avs2YUV versions included:
x264_launcher-TEST.2020-01-03.exe
Thanks! Now I've tried it, and it works great, although I mostly used standard settings when I made my encode. Could you please release a portable version though, if that's not too much trouble?
Forteen88 is offline   Reply With Quote
Old 22nd January 2020, 20:07   #1857  |  Link
tormento
Acid fr0g
tormento's Avatar
Just rename to x264_launcher_portable.exe
Old 23rd January 2020, 21:08   #1858  |  Link
Forteen88
Herr
OK, thanks, but there is still stuff in the installation-register with this new Test-version.
Old 26th January 2020, 12:18   #1859  |  Link
tormento
Acid fr0g
tormento's Avatar
I'd like to give a try to HDR encoding and I am kinda newbie in that sector. Using DGIndexNV to decode video, there is something I need specifically to set on x265 to add metainfo and, above all, how is x264 launcher support about hdr?
Old 26th January 2020, 17:09   #1860  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
example for HDR-PQ
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level              : 1529 cd/m2
Maximum Frame-Average Light Level        : 380 cd/m2
--colorprim bt2020 --transfer smpte2084 --colormatrix bt2020nc --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)" --max-cll "1529,380"
example for HDR-HLG
Transfer characteristics                 : HLG
--colorprim bt2020 --transfer arib-std-b67 --colormatrix bt2020nc --atc-sei 18 --pic-struct 0
