Old 26th March 2008, 13:17   #161  |  Link
burfadel
Isn't SVN no longer used?
Old 26th March 2008, 13:59   #162  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Nope. VideoLAN, which is also hosting x264, switched to git recently...
Old 26th March 2008, 16:28   #163  |  Link
burfadel
Thats what I thought, and would explain the problem he's having!
Old 26th March 2008, 17:27   #164  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
Thought he is talking about compiler svn repo...
Originally Posted by bob0r
@MythCreator
Did you compile gcc 4.3.0 or did you use some pre packages version?
Originally Posted by MythCreator
pre package.I can't connect to SVN and I don't know why.
Wishbringer is offline   Reply With Quote
Old 27th March 2008, 03:14   #165  |  Link
akupenguin
x264 developer
akupenguin's Avatar
On my C2D, your 798.modified GCC 4.3.0 versions is fractionally slower than bob0r's 798.modified version. By fractionally I mean around .05 - 0.1 fps! (consistently)
I can think of 3 possible reasons:
* Bssd is slower than unpatched (applies only with direct=auto).
* Different video content for fprofile. Yes, I have said that the content doesn't matter much, but that doesn't mean I'd discount the possibility of .05 fps. (Well, maybe I would. .05 out of what, .2? Speed differences are meaningless. Please don't ever post one again. The meaningful measure is speed ratio, preferably accompanied by the standard deviation of N trials. The base fps that the ratio is relative to (or the amount of the difference, interderivable) is optional and is the least important datum.)
* Different compiler. No, I do not have faith in newer gcc being consistently faster than old versions. (Consider that in a program as small as x264, even a single pessimized instruction in the wrong place could have a significant effect on total speed.)
Old 27th March 2008, 03:35   #166  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
gcc 4.x was always slower than 3.4.x in my tests...
Old 27th March 2008, 04:03   #167  |  Link
bob0r
Pain and suffering
bob0r's Avatar
@MythCreator
Doom9 forum shortens URLs, so copying plain text isn't going to work.
Here to make it easy for you:
http://x264.nl/x264.modified.txt
Also note the updated x264_2pass_vbv.7.diff patch.
grab it from the collected patches dir, apply like this:
patch -p1 < x264_patches/x264_2pass_vbv.7.diff
bob0r is offline   Reply With Quote
Old 27th March 2008, 05:10   #168  |  Link
MythCreator
Originally Posted by bob0r View Post
@MythCreator
Thanks~~~~
MythCreator is offline   Reply With Quote
Old 27th March 2008, 11:31   #169  |  Link
MythCreator
x264.798.modified.beta2.exe
General thread:
http://forum.doom9.org/showthread.php?t=130364
x264_aq_var.48.786.fixed.diff
http://forum.doom9.org/showthread.php?t=132760
x264.gaussian.cplxblur.01.diff
Dark Shikari: - gaussian cplxblur: gives a tiny improvement in 2pass ratecontrol
x264_me-prepass_DeathTheSheep.01.diff
http://forum.doom9.org/showthread.php?p=1093523
http://thread.gmane.org/gmane.comp.v...093/focus=3748
x264_hrd_pulldown.04_interlace.diff
- HRD and pulldown for HD compatibility, updated patch for interlacing
http://forum.doom9.org/showthread.ph...19#post1047919
Link to x264 patches collected: http://files.x264.nl/x264_patches/
make fprofiled by GCC 4.3.0 , just for test
Old 27th March 2008, 15:55   #170  |  Link
Inventive Software
Turkey Machine
@clsid: If you still read this thread, can you provide an install of MinGW with GCC 3.4.6 please?
@everybody: What's the difference between fprofiled and "normal" builds?
On Discworld it is clearly recognized that million-to-one chances happen 9 times out of 10. If the hero did not overcome huge odds, what would be the point? Terry Pratchett - The Science Of Discworld
Inventive Software is offline   Reply With Quote
Old 27th March 2008, 15:57   #171  |  Link
survivant001
@MythCreator. I obtain unknown option -- nal-hrd with your latest build
survivant001 is offline   Reply With Quote
Old 27th March 2008, 16:00   #172  |  Link
Inventive Software
Turkey Machine
That patch adds the option. If you don't know what it is, don't use it.
Old 27th March 2008, 16:05   #173  |  Link
survivant001
I know that, and Yes I need it, but it's not include in the 798beta2
Old 27th March 2008, 16:14   #174  |  Link
MythCreator
It's just my fault...I forget to add it
Old 27th March 2008, 16:28   #175  |  Link
MythCreator
x264.798.modified.beta2.fixed.exe
General thread:
Old 28th March 2008, 11:51   #176  |  Link
MythCreator
x264.798.modified.final.exe
General thread:
x264_bssd.diff
BTW:Is thread pool still usefull?
Old 28th March 2008, 16:53   #177  |  Link
survivant001
for me it is. I don't where else to get the latest build patched.
Old 28th March 2008, 17:04   #178  |  Link
buzzqw
HDConvertToX author
i agree with survivant
BHH
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
Old 28th March 2008, 17:48   #179  |  Link
MythCreator
I mean, is the Thread Pool.diff still useful at this time?
Old 28th March 2008, 19:18   #180  |  Link
burfadel
Well, the modified.final build of Mythcreator's is a fraction fractionally (...?!) slower than that of Bobor's modified 798. On a test I just did its was 99.998 percent (rounded up!) the performance of Bobor's modified build.
I'm just curious, if Mythcreator is willing to give it a try, purely as an experimental build whether he could try making a build with GCC 4.4.0. It is very much in testing stage, but snapshots can be downloaded by mirror sites. They're updated weekly according to the gcc site. One such site is:
http://gcc-ca.internet.bs/snapshots/
(of course then select the latest 4.4 folder at the bottom of the list)
Course could always build your own latest 4.4.0 snapshot from the GCC SVN
svn://gcc.gnu.org/svn/gcc/trunk
http://gcc.gnu.org/svn/gcc/trunk
^^ view contents
I realise you probably know all this already, I listed it in case anyone was wondering
GCC 4.4.0 supposedly has many optimisations that may finally allow it to be faster than GCC 3.4.6. Would be interesting to see anyway!
h.264, x264, x264 builds, x264 patches, x264 unofficial builds
