Old 11th March 2010, 03:22   #7101  |  Link
RunningSkittle
Skittle
RunningSkittle's Avatar
does ripbot use ffms2 yet?
RunningSkittle is offline   Reply With Quote
Old 11th March 2010, 07:37   #7102  |  Link
Abdur Rafi
tpsBB Senior Member
Abdur Rafi's Avatar
i cant use Latest - ffdshow_rev3305_20100304_clsid
when i install it & start riping got this image -
can any1 explain me please
Abdur Rafi is offline   Reply With Quote
Old 11th March 2010, 08:03   #7103  |  Link
nekrosoft13
that basically means that ripbot can't detect what type of video it is.
nekrosoft13 is offline   Reply With Quote
Old 11th March 2010, 08:20   #7104  |  Link
Balthazar2k4
Oh my, the first reviews of the new 6-core i7 980X are out and it looks to be an absolute monster with x264 (50% faster than an i7-975!). Imagine 720p BR rips in less than an hour. Excuse me while I clean myself up....
Balthazar2k4 is offline   Reply With Quote
Old 11th March 2010, 16:42   #7105  |  Link
brogan
Cannot Render File??
I recently upgraded from Windows 7 Ultimate x64 RC to the full version (7600, Ultimate x64) & am now having a couple issues. I've figured out all the other problems except for wmp classic not being able to render video files to see a preview of my jobs. I'm using RipBot v1.15.1 now. I downloaded the newest version of wmp classic I could find but that doesn't seem to work. I tried searching for the answer already but maybe I'm not using the correct string of words in my search. I believe I went through this when I 1st upgraded to Windows 7 but cannot for the life of me remember how to fix this. Does anyone know off hand? Thank you!
brogan is offline   Reply With Quote
Old 11th March 2010, 18:49   #7106  |  Link
Abdur Rafi
tpsBB Senior Member
Abdur Rafi's Avatar
thx buddy,what can i do in this problem
Old 11th March 2010, 20:45   #7107  |  Link
pacaveli211
k, buy me one of those and I'll pass along how superbly awesome it is
pacaveli211 is offline   Reply With Quote
Old 11th March 2010, 20:50   #7108  |  Link
radigast
I am looking to use an avisynth plugin called GradFun2DBmod. Can anyone give me pointers as to how to apply this filter to my encodes using RipBot264? I have already tried adding it to several places within the script editor windows, but to no avail.
radigast is offline   Reply With Quote
Old 11th March 2010, 22:09   #7109  |  Link
jibelin
Hi there, I too am receiving similar error. I have tried the common solution of uninstalling codecs, haali, and ffdshow and reinstalling specified versions but to no avail. Plus do not have this problem with previous version. Any help would be appreciated for this long time ripbot user...
Cheers,
--joe b.
jibelin is offline   Reply With Quote
Old 12th March 2010, 00:12   #7110  |  Link
fantasmanegro
Cheers,
--joe b.
Ii have the same problem too, but i was checking that it was only in one movie, but it works with others, anyone else?
fantasmanegro is offline   Reply With Quote
Old 12th March 2010, 05:13   #7111  |  Link
hoju3508
^Nothing has change on my system except for version 1.15.1 of RipBot264. I'm not seeing this problem when rolling back to 1.15.0.
hoju3508 is offline   Reply With Quote
Old 12th March 2010, 13:55   #7112  |  Link
soneca
I have a problem with 2 different tracks containing VC-1 streams.
DirectShowSource : Timeout waiting for graph to start.
(D:\Temp\RipBot264temp\job1\getinfo.avs, line 2)
Going back to version 1.15.0 everything works fine.
soneca is offline   Reply With Quote
Old 12th March 2010, 14:17   #7113  |  Link
Atak_Snajpera
Atak_Snajpera's Avatar
samples?
Old 12th March 2010, 14:24   #7114  |  Link
soneca
whole movies
Old 12th March 2010, 14:24   #7115  |  Link
Atak_Snajpera
50 mb - 100mb for god sake
Old 12th March 2010, 14:29   #7116  |  Link
soneca
take it easy, my English is bad ...
At this moment I can not send samples, only when I get home.
Old 12th March 2010, 17:22   #7117  |  Link
hoju3508
Here's my sample of Old Dogs -> Here.
General
Complete name                    : F:\old-dog_avc.m2ts
Format                           : BDAV
Format/Info                      : Blu-ray Video
File size                        : 100 MiB
Duration                         : 25s 696ms
Overall bit rate                 : 32.6 Mbps
Maximum Overall bit rate         : 35.5 Mbps
Video
Menu ID                          : 1 (0x1)
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 4 frames
Duration                         : 25s 817ms
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Display aspect ratio             : 16:9
Frame rate                       : 23.976 fps
Resolution                       : 8 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Audio
Menu ID                          : 1 (0x1)
Format                           : DTS
Format/Info                      : Digital Theater Systems
Format profile                   : MA
Muxing mode                      : Stream extension
Duration                         : 25s 802ms
Bit rate mode                    : Variable
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Surround: L R, LFE
Sampling rate                    : 48.0 KHz
Resolution                       : 24 bits
Video delay                      : 9ms
Language                         : English
Text #1
Menu ID                          : 1 (0x1)
Format                           : PGS
Duration                         : 25s 22ms
Video delay                      : 751ms
Language                         : English
Text #2
Menu ID                          : 1 (0x1)
Format                           : PGS
Duration                         : 24s 938ms
Video delay                      : 792ms
Language                         : English
Text #3
Menu ID                          : 1 (0x1)
Format                           : PGS
Duration                         : 23s 252ms
Video delay                      : 1s 460ms
Language                         : English
Old 12th March 2010, 18:22   #7118  |  Link
Atak_Snajpera
I remuxed your sample in tsmuxer and it works in 1.15.1 without problems!
Old 12th March 2010, 20:35   #7119  |  Link
laserfan
Aging Video Hobbyist
Atak your bitrate algo was "off" for me (video target was 100Kbps too high) and I can only think that your logic didn't like my unusual audio bitrate which was 320kbps.
Not a big deal for me cuz I only had to re-work the (stereo) audio to 256kbps to fit my DVD-5 without re-encoding, but I thought I'd tell you about it anyway.
laserfan is offline   Reply With Quote
Old 12th March 2010, 21:01   #7120  |  Link
Atak_Snajpera
AC3 320kbps is very very very rare. That's why I didn't include proper algo for that weird bitrate.
