16th September 2009, 15:03 | #5761 | Link |
Windows 7 Problem
Hey all,
I just recently installed 7 ultimate on my PC. I've used Ripbot a lot with Vista and it's worked great. I started up my first blu-ray encode on 7 and when it gets all the way complete it just starts over? This happens continuously. Anyone know why this is happening and how I can stop it? Thanks! |
16th September 2009, 15:07 | #5762 | Link | |
Can I send you a small sample? |
16th September 2009, 15:09 | #5763 | Link | |
16th September 2009, 15:57 | #5764 | Link | |
Why isn't there an option to simply extract the AC3 core from a TrueHD? I'm sure you would make many happy here. There is just something so comforting to know you are taking the original AC3 and NOT an encoded aften one. Many of us SPDIF to their sound system, and you cannot send FLAC over SPDIF - only AC3/DTS. |
16th September 2009, 16:15 | #5765 | Link |
http://www.mediafire.com/?tw1fjxwlniu
There's a bit of narative at the beginning of the clip but towards the end there is some dialog. Last edited by Jeff Flowerday; 16th September 2009 at 16:25. |
16th September 2009, 16:49 | #5766 | Link | ||
16th September 2009, 17:39 | #5768 | Link | |
video=DirectShowSource("C:\Users\Mama\Desktop\sample-remux.mkv",audio=false,fps=23.976).ConvertToYV12()
17th September 2009, 17:26 | #5770 | Link | ||
Changing the script for each job
Is there a way to semi-permanently change the script for iPhone video conversion? For example, the default:
Also, I am curious to know if there is a way to convert an entire directory (full of DivX DVRs ) with the same settings instead of a file at a time? |
18th September 2009, 03:52 | #5771 | Link | |
18th September 2009, 17:44 | #5772 | Link | |
So, the option is already there. |
18th September 2009, 20:55 | #5774 | Link | |
First, when you are extracting audio only through Clown_BD, what output format do you choose? I used TSmuxer's demux instead of Clown_BD to rip the audio off. And secondly, after I used Ripbot for video only and then tried to mux it with the HD audio in TSmuxer, it worked but in the result the program always seems to show "B-pyramid level detected, shift DST 2 frames" (or something like that). Does anybody know what this b-pyramid is and why it happens and if it is bad or not? |
18th September 2009, 21:44 | #5775 | Link |
I'm trying to convert a 1920x1080@29.97fps transport stream to 720p@23.976fps but can't seem to get the Ripbot settings down. Media Info reports the former scan type as progressive so no deinterlacing is needed. But if I set Ripbot to decimate > 23.976fps only, the resulting video judders badly and the A/V is out of sync.
However, I've found that encoding without decimating, then remuxing the resulting .mkv in MKVMerge and flagging the video as 23.976fps, it plays back smoothly. Is it possible the original .ts is actually 23.976fps but is flagged incorrectly as 29.97fps? It's a HDTV cap of a film. |
19th September 2009, 00:20 | #5776 | Link |
anyone have a guide for setting options in the ini file?
I've already adjusted most of them as desired but I'd like to add: LockSize=1 Size=7610 I already have DefaultProfile=[HIGH 4.0] HD . BluRay . Consoles DefaultEncodingMode=2-pass DefaultModeValue=15000 (random number, if the above can be completed it will auto adjust the bitrate) is there a way to add the locked file size? |
20th September 2009, 10:32 | #5777 | Link |
In the change log for 1.14.3 it was stated "Fixed: too big undersize for mkv", and I've had great success with 1.14.3 with almost exact or marginally under. There is no mention of any changes in 1.14.4 around this area, but 3 encodes out of 3 are larger than 1.14.3 using exact same settings (fixed size of x, 2-pass, same profile etc). The only difference would be the version of x264 (I was previously using x264 0.72.1240 35627b6 with 1.14.3) and 1.14.4 now uses x264 0.75.1251M e553a4c.
Would that explain it, or is there anything else people can think of ? (of course I will re-test with the same release of x264, I'm just asking in case there is a generic issue in 1.14.4). |
20th September 2009, 16:39 | #5778 | Link | |
Anyway, I went back to my source and demuxed the video from the .ts. TSMuxer tells me it's 29.97 with pulldown, so I set TSMuxer to remove the pulldown which then leaves me with a raw .mpv that Media Info states is 23.976fps. However, when I load this into Ripbot (after renaming to a .m2v) the running time is recognised as 1.25x longer than it really is. So, is there anything else I can try? Do I need to do some groundwork with DGIndex on my source and load into Ripbot via. an AVS script? Hopefully somebody can make sense of what I'm trying to say and cheers in advance for any help. |
20th September 2009, 18:29 | #5779 | Link |
send me 50 mb sample. Use DGSplit and www.mediafire.com
