16th February 2017, 11:07 | #1122 | Link |
Mathematics is the same, there will be a bug somewhere.
github.com |
16th February 2017, 11:38 | #1124 | Link | |
You can consider it a side effect of the new channels mode. The result is correct, I might add an internal multiplier to maintain compatibility with the older versions. PS. It is more correct the new version instead of the old.
github.com Last edited by Khanattila; 16th February 2017 at 11:42. |
16th February 2017, 12:36 | #1126 | Link | |
As a temporary fix using ~1,732 (square root of 3) as a multiplier for h.
github.com |
16th February 2017, 14:59 | #1127 | Link | |
Yes it's Wikipedia, but it's good enough: https://en.wikipedia.org/w/index.php?title=Decimal_mark Basically it's the exact opposite, where you use commas' as a decimal separator as in your usage, a decimal is used, and where we would use a comma, you use a decimal as a thousands separator. Makes it confusing when there are multiple different systems (more than just these) around the world. The correct form in Australia for 1,732 is 1 732, although a comma is typically used. Not to confuse things with the comma at the end there for a sentence break! Many people would also write 1 732 as 1,732, but if the number were much larger as in 92,345,764 they would use spaces. The spaces are used as part of the SI system I believe to avoid confusion between the various systems used around the world. Last edited by burfadel; 16th February 2017 at 15:09. |
16th February 2017, 16:32 | #1128 | Link | |
I live in the limbo in which I program using '.' and in the lives of everyday I use ','.
github.com Last edited by Khanattila; 16th February 2017 at 16:34. |
16th February 2017, 16:55 | #1129 | Link |
Soul Architect
Modern programming languages have no issue with that (as long as you set the right parameters for formatting) but this used to be a major source of frustration with old programming languages. A program would run 100% fine, then on another computer, it would totally crash on every comma.
21st February 2017, 10:52 | #1130 | Link |
I am getting the following error when running on macOS with latest versions (vapoursynth R36 and KNLMeansCL built from master - commit 08755c5). Anyone got an idea how to fix ?
Script evaluation failed: Python exception: knlm.KNLMeansCL: build programm error! Please report Log-KNLMeansCL.txt. Traceback (most recent call last): File "src/cython/vapoursynth.pyx", line 1712, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:34991) File "VIVTC_with_TComb_script.vpy", line 11, in <module> clip = core.knlm.KNLMeansCL(clip=clip) File "src/cython/vapoursynth.pyx", line 1604, in vapoursynth.Function.__call__ (src/cython/vapoursynth.c:33131) vapoursynth.Error: knlm.KNLMeansCL: build programm error! script: import vapoursynth as vs core = vs.get_core() core.max_cache_size = 12000 clip = core.ffms2.Source(source=filename) clip = core.knlm.KNLMeansCL(clip=clip) Last edited by KingLir; 26th February 2017 at 17:21. |
21st February 2017, 10:59 | #1131 | Link | |
github.com |
21st February 2017, 16:58 | #1133 | Link |
It is in the script folder.
github.com |
21st February 2017, 19:32 | #1134 | Link |
Thanks, sorry I missed it.
Here: OpenCL Platform ------------------------------------------------------------ CL_PLATFORM_VENDOR: Apple CL_PLATFORM_NAME: Apple CL_PLATFORM_VERSION: OpenCL 1.2 (Jan 4 2017 22:35:59) CL_PLATFORM_PROFILE: FULL_PROFILE OpenCL Device ------------------------------------------------------------ CL_DEVICE_VENDOR: AMD CL_DEVICE_NAME: AMD Radeon R9 M395X Compute Engine CL_DRIVER_VERSION: 1.2 (Jan 10 2017 22:25:08) CL_DEVICE_VERSION: OpenCL 1.2 CL_DEVICE_PROFILE: FULL_PROFILE CL_DEVICE_IMAGE_SUPPORT: 1 CL_DEVICE_IMAGE2D_MAX_WIDTH: 16384 CL_DEVICE_IMAGE2D_MAX_HEIGHT: 16384 CL_DEVICE_IMAGE_MAX_ARRAY_SIZE: 2048 Program Build ------------------------------------------------------------ CL_PROGRAM_BUILD_OPTIONS: CL_PROGRAM_BUILD_LOG: RETURN: 0 |
24th February 2017, 18:25 | #1136 | Link |
github.com |
24th February 2017, 19:01 | #1137 | Link |
@ KingLir
https://github.com/Khanattila/KNLMea...ive/master.zip Can you test this version and report log?
github.com Last edited by Khanattila; 28th February 2017 at 18:04. |
26th February 2017, 17:22 | #1138 | Link | |
Here is the new output: Script evaluation failed: Python exception: knlm.KNLMeansCL: build programm error! Please report Log-KNLMeansCL.txt. Traceback (most recent call last): File "src/cython/vapoursynth.pyx", line 1712, in vapoursynth.vpy_evaluateScript (src/cython/vapoursynth.c:34991) File "VIVTC_with_TComb_script.vpy", line 16, in <module> clip = core.knlm.KNLMeansCL(clip=clip) File "src/cython/vapoursynth.pyx", line 1604, in vapoursynth.Function.__call__ (src/cython/vapoursynth.c:33131) vapoursynth.Error: knlm.KNLMeansCL: build programm error! And the new log: OpenCL Platform ------------------------------------------------------------ CL_PLATFORM_VENDOR: Apple CL_PLATFORM_NAME: Apple CL_PLATFORM_VERSION: OpenCL 1.2 (Jan 4 2017 22:35:59) CL_PLATFORM_PROFILE: FULL_PROFILE OpenCL Device ------------------------------------------------------------ CL_DEVICE_VENDOR: AMD CL_DEVICE_NAME: AMD Radeon R9 M395X Compute Engine CL_DRIVER_VERSION: 1.2 (Jan 10 2017 22:25:08) CL_DEVICE_VERSION: OpenCL 1.2 CL_DEVICE_PROFILE: FULL_PROFILE CL_DEVICE_IMAGE_SUPPORT: 1 CL_DEVICE_IMAGE2D_MAX_WIDTH: 16384 CL_DEVICE_IMAGE2D_MAX_HEIGHT: 16384 CL_DEVICE_IMAGE_MAX_ARRAY_SIZE: 2048 Program Build ------------------------------------------------------------ CL_PROGRAM_BUILD_ERROR: CL_INVALID_BUILD_OPTIONS CL_PROGRAM_BUILD_OPTIONS: CL_PROGRAM_BUILD_LOG: RETURN: 0 |
28th February 2017, 17:07 | #1139 | Link | |
github.com |
28th February 2017, 18:04 | #1140 | Link |
github.com |
