25th March 2008, 16:34 | #21 | Link | |
Edit: Works like a charm. Boots wirhout problems now, and a quick scan of the disc showed no problems on the rest of the playback. Thanx alot for the quick fix!!! Last edited by Mirx; 25th March 2008 at 17:03. |
25th March 2008, 18:03 | #23 | Link |
This is strange. I have this disc too (I used your logfile though when I was implementing it's support). I have just copied most of the files (excluding huge .m2ts streams) to the hard drive and set PowerDVD to Region C. When I opened the folder in PowerDVD (I use version 3319a), it showed a screen "Please use Region A player etc.". Then I ran "Blu-ray Region Code Remover", which removed the region code. Now PowerDVD starts playing the folder just fine. No errors whatsoever. So I think the error you are receiving is due to something else. Did you use UDF 2.5 while creating .iso?
26th March 2008, 07:51 | #25 | Link |
Just a observation.
The thread you reference http://forum.doom9.org/showthread.php?t=122283 is incorrect. The function shown there when removed will remove the region check, however this is not the root function of the region check. Its just code specific to that title. The root function which requests the region from the player (and this will always be a constant, no matter what movie) is RegisterAccess.getInstance().getPSR(20) which is an integer containing the region. Last edited by 3r1c; 26th March 2008 at 07:53. |
26th March 2008, 10:43 | #26 | Link | |
31st March 2008, 16:09 | #28 | Link |
Version 2.0 of this program is now available. Due to brand new java .class file parser it supports removing of region code from ALL Blu-ray titles.
Many thanks to 3r1c for very inspirational post: http://forum.doom9.org/showthread.ph...76#post1117476. |
2nd April 2008, 07:46 | #30 | Link | |
Thanks a lot for your post and the log file. They were very helpful indeed. EDIT: By the way, to fix this, just copy MovieObject.bdmv file from disc (with AnyDVD enabled) to movie's BDMV folder on a hard drive after you run "Blu-ray Region Code Remover". Last edited by SuperGoof; 2nd April 2008 at 08:19. |
2nd April 2008, 07:49 | #31 | Link | |
if so then this bug should be reported to slysoft. |
2nd April 2008, 07:55 | #32 | Link | |
AnyDVD sometimes guesses wrong about the region in 'Automatic' mode, and after region code modifications are made in movieobject.bdmv, it is not possible to apply them again using different region. That is why I was first copying this file from the BACKUP folder in the first place. Last edited by SuperGoof; 2nd April 2008 at 07:58. |
2nd April 2008, 07:58 | #33 | Link |
Because the backup file is a backup, not an alternate version.
Its so if the disc is damage and the player cant read the main file it will try to read the backup. The "backup" folder is not a anydvd invention to backup the original, the backup folder is part of the blu-ray specification, they are supposed to be the same. |
2nd April 2008, 08:06 | #34 | Link |
In my opinion, it is useless part of the specification. If main movieobject.bdmv is damaged, there is a big likelihood that large part of useful content on disc is damaged as well, even if movieobject.bdmv in the BACKUP folder is intact.
2nd April 2008, 19:48 | #35 | Link | |
Actually, now I'm not sure. I mean, the problem does exist and the fix is coming, but it should only affect movies which have both BD+ and region check by MovieObject.bdmv, like "Live Free Or Die Hard", for example. In case of your movie the region check is done by BD-Java script, and my program does not modify MovieObject.bdmv, unless you select "Restore the original region code" option. And since in your log MovieObject.bdmv is different in BDMV and BDMV\BACKUP folders, you didn't. What exaxtly is the problem with the playback? What message do you get? Last edited by SuperGoof; 2nd April 2008 at 19:50. |
2nd April 2008, 21:07 | #36 | Link |
I created an ISO with imgburn 2.4. I got 'no disc in drive' error in PDVD 3730. I went back and created a missing META folder in BDVM, then re; ISO'd it. Then I got 'region code' error. I ran region code remover, then it loaded (no errors) but froze at blank screen, no menu or anything. I then recreated the original, with folder fix, and changed PDVD to region 'B' and it worked ,so I'm assuming it's something wrong with the region code remover.
2nd April 2008, 21:57 | #37 | Link |
@3r1c
The "Independence Day" log you sent here is the same as |nitrogen|'s. Can you please tell whether region removing worked for ID after I made modifications for this particular movie? Also, can you please rip this disc with new version of AnyDVD with BD+ removing enabled, then run "Blu-ray Region Code Remover 2.0" (with Region B, I suppose), and then check whether it plays or not in PDVD set to region A or C. I don't know which version of PowerDVD you are using, but can you please also create an .iso with ImgBurn (with UDF 2.5) and try to play the mounted iso as well (with recent versions you will have to it anyway). Frankly, I don't know what could be the problem with this movie. Everything looks fine for me. Thanks in advance. Your help will be very much appreciated. And anyone who happened to have "Independence Day" (UK version), could you please do this experiment if you have time and wish. Or if you already did it, could you please tell the results. Thanks. Last edited by SuperGoof; 2nd April 2008 at 22:07. |
3rd April 2008, 03:25 | #38 | Link |
Version 2.1 is released. This fixes that issue with "Blu-ray Region Code Remover" overriding BD+ related modifications in MovieObject.bdmv file, made by AnyDVD.
@|nitrogen| Can you please try to re-do "Independence Day" from the beginning using the new version 2.1. |
