17th May 2007, 16:43 | #2861 | Link |
Junglist
Well,.. guys,.. i'm currently adding support for x264farm to MeGUI, as far as i'm not so good C# programmer.. i have few questions on using profiles,.. can anybody contact me via e-mail or iCQ ? ...
it seems like new encoder-Property works (i've been working for 3 days already..).. i'm not sure if Job addition does(didn't try that).. and i think i have settings properly made ... and commandline generation.. now i need(or want) to add "ProfileControl" to show up x264Configuration itself.. and then get some needed params.. BUT.. i'm currently lost in those lines(looked throug code): Code:
profileHandler = new ProfilesControlHandler<VideoCodecSettings, VideoInfo>("Video", mainForm, profileControl1, x264codecHandler.EditSettings, Empty.Getter, x264codecHandler.Getter, x264codecHandler.Setter); x264codecHandler = new SingleConfigurerHandler<VideoCodecSettings, VideoInfo, VideoCodec, VideoEncoderType>(profileHandler, CodecManager.X264); ProfilesControlHandler<VideoCodecSettings, VideoInfo> profileHandler = new ProfilesControlHandler<VideoCodecSettings, VideoInfo>( "Video", mainForm, profileControl1, CodecManager.X264, Empty.Getter, new SettingsGetter<AviSynthSettings>(settingsProvider.GetCurrentSettings), new SettingsSetter<AviSynthSettings>(settingsProvider.LoadSettings)); SingleConfigurerHandler<AviSynthSettings, Empty, int, int> configurerHandler = new SingleConfigurerHandler<AviSynthSettings, Empty, int, int>(profileHandler, settingsProvider); configurerHandler.ProfileChanged += new SelectedProfileChangedEvent(ProfileChanged); help.
Rule Number 6: Concentrate!!! (c)Hercules, Disney "I like to build planes.... in the air" (c) some ADV. tutorials How to Setup agent-based encoding with x264farm (the easy way) |
17th May 2007, 16:59 | #2862 | Link |
clueless n00b
@berrinam: could it be that you didn't close all bugs/feature requests that you recently implemented?
17th May 2007, 18:25 | #2864 | Link |
Instead of sitting around and waiting for autoupdate to work, you could just manually download it from x264.nl. It looks like it's broken; it's not going to fix itself if you wait long enough.
Also, I wish I could help you, SpAwN_gUy, but keep it up! |
17th May 2007, 19:28 | #2865 | Link | |
sidekick
greets, kurt. Pioneer PDP-427 XA | Popcorn Hour NMT C-200 | Sony STR-DB 840 QS | Canton Ergo 91 DC |
19th May 2007, 23:05 | #2868 | Link |
clueless n00b
I have a serious problem with all those people abusing this thread for all kinds of non development related stuff. Get back to topic or familiarize yourself with rule 16.
20th May 2007, 15:55 | #2869 | Link | |
Newest build will not load ANY video-related AVS files.. Tried numerous times... brings up a "protected memory" error
VirtualDub Mod loads the same AVS files just fine. http://forum.doom9.org/showthread.php?t=125971 This is pretty serious, as it means I can no longer use MeGUI to encode basically anything, and I don't completely know how to go back and fix this... HELP! --------------------------------------------------------------- EDIT: I don't know if this was entirely necessary... Quote:
24th May 2007, 08:23 | #2870 | Link |
clueless n00b
@Lolitka: this would be a topic for the development forum at the bottom.
29th May 2007, 16:31 | #2872 | Link | |
hope noone'll get mad when I post this in this thread (know this is the development-thread so, but since the problem was brought up here, hope it's ok guys)
Although, if i disabled "Open Preview after Avisynth script selection" the error won't happen, and I succesfully managed to encode several videoclips after that. So: Open MeGUI -> Tools -> Settings -> uncheck "Open Preview after Avisynth script selection" -> Save Hope it works for you too =) |
2nd June 2007, 00:01 | #2873 | Link |
Not so much a bug as a huge performance hit...
When encoding audio in MeGUI the GUI is updated several dozen (or more) times a second. This results in MeGUI taking a huge proportion of CPU time to keep the gui updated. The code should be altered so that the screen is only refreshed once a second (or thereabouts). For people on single cores (or people using multithreaded audio encoders), it'll vastly increase encoding speed for audio. At the moment MeGUI is taking up 60-70% of one of my cores due to the frequent GUI updates.
Nothing to see here... Last edited by Mutant_Fruit; 4th June 2007 at 14:53. Reason: Typo |
4th June 2007, 16:12 | #2876 | Link |
Ok, i've worked up a quick workaround. The way the code is structured doesn't lend itself well to doing delayed GUI updates, so this is more of a hack than a full solution. However, it may be the best solution as it involves the minimum amount of code change.
If one of the full-time dev's has a better solution, let me know.
Nothing to see here... |
5th June 2007, 23:42 | #2877 | Link |
Has anyone looked at compiling this with mono lately? It appears that mono supports .NET 2.0 and part of 3.0 now
6th June 2007, 01:42 | #2878 | Link |
It won't run on mono as it uses methods which aren't suppoted as of yet. Secondly, the necessary 3rd party libs don't exist on linux/macos x yet, so the advantage of being able to run MeGUI is nil as you won't be able to do anything useful with it Basically, you need Avisynth 3, which ain't out yet.
9th June 2007, 16:03 | #2879 | Link | |
9th June 2007, 17:53 | #2880 | Link |
phjbdpcrjlj2sb3h
There are sadly only three devs (berrinam - the main one, sharktooth, and doom9). All three have put up signs saying "no time sorry", so sadly you might be waiting a long while. On the other hand, I am interested in putting up an alternate update mirror again
development, megui, not a help thread |
