3rd April 2012, 13:08 | #10961 | Link |
My Q6600@3Ghz very often exceeds 80C during heavy encoding and nothing happens. Rock stable.
3rd April 2012, 14:16 | #10963 | Link |
don't forget that my CPU is in 65nm. Frankly I don't care about temp as long as CPU is rock stable in Lynx (linpack test)
3rd April 2012, 15:08 | #10964 | Link |
Hi atak,
My CPU is in 45nm and temperature more than 68 is not safe. Is it possible in your program that define how many core does encoding? I think if we can define two cores are used to encoding, its temp should be below 56. |
3rd April 2012, 15:31 | #10965 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 3rd April 2012 at 15:38. |
3rd April 2012, 17:44 | #10966 | Link |
Silent Reader
Intel Core2D/Q have integrated sensors which throttle down frequency when overheating.
I OC my Q9650 (45nm) to 4.5GHz and have 83C with IntelBurnTest over 24h and no errors. With RipBot I reach 72C coretemp in summertime (71.4C is still covered by Intel Specs).see here And I am running that CPU since releasedate 2008 OCed. Intel CPUs can handle much stresstesting. Last edited by Wishbringer; 3rd April 2012 at 17:49. |
3rd April 2012, 18:01 | #10967 | Link |
BD rebuilder allows a hidden option for decreasing the allowed threads/cores. E.g. THREADS=3, for throttling back to 3 cores. A nice feature when one needs a free core. On an 8 or more core processor, this could be a very nice feature.
Not really suggesting Ripbot needs such a feature though. Perhaps that's why the mbatiri asks. Most Jobs I run through ripbot take no more than 1hr or 2 at most. I can browse the internet seamlessly. And my temps never exceed 40 - 45C high load. Thanks to my Megakiller. If you're concerned about temps, you NEED better cooling. I don't get concerned about AMD temps until the 60C threshold is breached. Heat = degradation. I prefer keep the temps 55C and below. Especially my northbridge. edit - You could always underclock the processor.
Only one rooster, need be in the hen house... |
3rd April 2012, 19:54 | #10968 | Link |
Thanks atak and other friends for their reply
Nobody tell me nor any where I read that temp over than 68 may burn CPU.But I have never seen my CPU temp exceed over than 48 and so I'm worry. In most hard situation, my CPU temp never exceed 61 and if it is safe, so there is no problem. I am agree with atak who says I bought 4 core CPU and so I should use its best. Thanks again for all.
Best regards Mbatiri |
4th April 2012, 15:04 | #10970 | Link |
Silent Reader
Use Wine, maybe it works with Ripbot at Ubuntu.
Don't know how it handles Avisynth and GPU plugins. http://www.winehq.org/ |
4th April 2012, 17:48 | #10971 | Link | |
The Black Reaper
http://mewiki.project357.com/wiki/X264_Settings#threads |
6th April 2012, 01:00 | #10973 | Link | |
Using 3d blu rays will usually have a brighter picture also. There is no way to combine two video streams in ripbot..YET My sandy bridge 2600k CPU has TJ (Thermal Junction) max temp of 98 degrees C, anything under that is safe!!!!!!!!!! 68C is nothing!!!!! Last edited by Zorro70; 6th April 2012 at 01:03. |
6th April 2012, 14:46 | #10975 | Link |
Is there any way to disable the automatic conversion of TrueHD to FLAC? I re-add the TrueHD audio back in after Ripbot is finished anyway, so I choose No Audio when I get to the options screen. But I have to wait 10-15 minutes while the conversion happens which I don't end up using. Thanks.
6th April 2012, 17:39 | #10976 | Link |
Great program!
Hi!
First, thank you for your hard work on this application. It is one of my favorite tool for transcoding. I just want to know if you have ever considered supporting more than one audio and sub tracks? I believe this would be a nice addon, especially for foreign movies where one may want to keep the original audio and subs plus another language. Thanks. |
6th April 2012, 19:44 | #10977 | Link |
Hi guys, ( no gays )
When there'll be a new version of RB? ..and this when came along? some changes between the time of its release? 10x! Btw: If a source is fucked up, but someone still wanna save that movie, how can use SRestore with RB? Any ideea? Last edited by benjyv; 8th April 2012 at 17:17. |
11th April 2012, 05:40 | #10978 | Link |
A little help..
If I have an FLV file that has a LC AAC track but Ripbot won't see it, what would be the best way to extract it so later I can just add it to the video stream??????????? Last edited by rc71; 11th April 2012 at 05:48. |
