Old 3rd June 2008, 00:28   #1  |  Link
KornX
primus inter pares
KornX's Avatar
h264 LOSSLESS experiences
if you do a 1080p24 encode with the lossless mode, what bitrates are we talking about (yeah i know, content...)
But what are your experiences?
And how many of you use it (at least sometimes)
KornX
Field Application Engineer
Advanced Micro Devices
KornX is offline   Reply With Quote
Old 6th June 2008, 19:29   #2  |  Link
bond
depends on what video you try to encode losslessly of course
so try it yourself on the for you relevant content
Ogg Theora | Ogg Vorbis
Old 6th June 2008, 22:16   #3  |  Link
Dust Signs
are you talking about perceptually lossless or really lossless (QP = 0)? In the latter case it's possible that you get data rates exceeding those of raw uncompressed YUV files, in the former case - of course depending on the content - you can expect some 20 to 50 MBits/s
Dust Signs
The number you dialed is imaginary. Please turn your phone by 90° and try again
Dust Signs is offline   Reply With Quote
Old 6th June 2008, 22:18   #4  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
This is extremely doubtful. I've only ever seen a single macroblock ever exceed its uncompressed size with lossless x264 encoding, and technically the standard requires that any such block be coded as I_PCM anyways.
Old 6th June 2008, 22:27   #5  |  Link
Dust Signs
I wrote that it is possible and I experienced one such case myself when IPCM mode was accidently disabled. But anyways, using lossless mode makes no real sense to me because the bit rate required is extremely high and the difference to a file encoded with p.e. CRF 16 is perceptually zero.
Dust Signs
Old 6th June 2008, 22:30   #6  |  Link
Dark Shikari
x264 developer
x264 doesn't actually support I_PCM mode; its in the code right now but it isn't enabled.
Dust Signs
Its far better than most other lossless options in the case that inter prediction is very useful, such as for CGI or animated sources which were originally lossless.
Old 6th June 2008, 22:33   #7  |  Link
Dust Signs
I wasn't talking about x264 concerning that matter - this time I was using a different encoder. Concerning CGI I agree with you, but I think many people are using "normal" video material (movies etc.) much more often.
Dust Signs
Old 11th June 2008, 23:32   #8  |  Link
elguaxo
elguaxo's Avatar
I'm doing my first lossles try right now. The source is a 01:31:20 old anime movie on DVD. It needs a lot of denoising, which I'm not doing right now. The lossles pass is only for AnimeIVTC. After 75% the projected filesize is of 12.8GB.
I'm using MeGUI's CQ-Lossless profile:
 --qp 0 --nf --subme 1 --partitions p8x8,b8x8,i4x4 --merange 12 --threads auto --thread-input --progress --no-psnr --no-ssim --output
elguaxo is offline   Reply With Quote
Old 11th June 2008, 23:45   #9  |  Link
Dark Shikari
x264 developer
Subme 1? That's a waste; most time is spent in bitstream encoding, so a higher subme hardly takes any more time (until you get to 6 or above, at least). --nf does nothing there, and --no-psnr and --no-ssim do nothing too. The partitions is what is used as default, and the --merange is silly with --me hex.
Old 12th June 2008, 00:04   #10  |  Link
elguaxo
elguaxo's Avatar
This encode is almost done, but I will use subme 5 or 6 next time. What would be a good merange value if I keep --me hex? Thanks
Old 12th June 2008, 00:07   #11  |  Link
Dark Shikari
x264 developer
For hex, there's no reason to change it to anything but the default (16).
Old 12th June 2008, 00:07   #12  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
I think --merange does not apply to "hex" mode, only "umh" and higher...
Old 12th June 2008, 00:13   #13  |  Link
Dark Shikari
x264 developer
It does, its just that its clipped to 4<=X<=16.
Old 12th June 2008, 00:15   #14  |  Link
elguaxo
elguaxo's Avatar
Old 12th June 2008, 00:21   #15  |  Link
LoRd_MuldeR
Software Developer
Sorry, I was mistaken
Old 12th June 2008, 23:12   #16  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
If you want a lot more speed out of lossless, just turn cabac off. It'll be slightly larger but not as much as you'd expect. You lose a lot less efficiency than you do at low bitrates, since so many of the randomer high quantizers are present.
Old 12th June 2008, 23:16   #17  |  Link
Dark Shikari
x264 developer
The benefit of CABAC in lossless is actually higher than at low quantizers:
(thanks to akupenguin for this chart)
But yes, overall, its definitely worth turning off given the very large speed boost one gets; (de|en)coding lossless is nearly pure entropy (de|en)coding.
Old 13th June 2008, 01:58   #18  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
Oh wow, that's crazy, thanks for letting me know. I normally use might-as-well-be-lossless qp 1 or 2, so I assumed behavior would translate over, good to know the truth.
1080p24, avc, h264, lossless, x264
