Old 7th December 2010, 19:10   #361  |  Link
matiypau
Help
Hi, I have a bluray, and it hasn't any sub. How to add the new subtitle in to bluray?. Because in remuxed's folder works perfectly, when i try to play the original's folder, the subtitle does not appear
Thank you so much
matiypau is offline   Reply With Quote
Old 7th December 2010, 19:49   #362  |  Link
crl2007
Edit the mpls with bdedit and add a subtitle stream.
crl2007 is offline   Reply With Quote
Old 8th December 2010, 05:25   #363  |  Link
matiypau
I already did, and nothing
Old 8th December 2010, 09:21   #364  |  Link
crl2007
If you can't do it manually, use this guide: http://forum.doom9.org/showthread.php?t=151925
Old 9th December 2010, 00:18   #365  |  Link
MRSFILM
hi
how adding subtitle to blu-ray3D DISC with the keeping the original menu?help me
MRSFILM is offline   Reply With Quote
Old 9th December 2010, 00:29   #366  |  Link
crl2007
It can't be done yet. When SSIF files can be demuxed/remuxed, then it will be possible.
Old 10th December 2010, 04:12   #367  |  Link
matiypau
Thank you. I will try this
Old 12th December 2010, 23:37   #368  |  Link
416d697248
Hi,I want to insert new subtitle to movie the expendables,I used normal method with the theatrical version (00004.mpls) and after that delete all the split m2ts files + their clpi files and their mpls files...When it was done,Everything is working fine on my PC (PowerDVD 10 and TotalMedia Theatre 3),But,On Playstation 3 and Blu-Ray Player it has problem just same as Iron Man 2 (Iron Man 2 splits in several m2ts files too),The movie doesn't start,screen remains black..
What should I do to solve this problem on PS3 and BD Players?
Thanks dude (Crl2007).
416d697248 is offline   Reply With Quote
Old 13th December 2010, 00:09   #369  |  Link
crl2007
You have to replace all the original movie mpls files with the one edited.
Old 13th December 2010, 09:44   #370  |  Link
416d697248
Yes,I replaced 00004.mpls and 00006.mpls but the problem still remain..
Do youhave any idea?
Old 13th December 2010, 09:51   #371  |  Link
crl2007
On PS3 I know that you have to split your movie and make it AVCHD compliant, the same applies on certain BD players.
Old 13th December 2010, 11:28   #372  |  Link
416d697248
Thanks,But how can I make it AVCHD compliant?
Old 13th December 2010, 11:53   #373  |  Link
crl2007
You can use my guide here, which is an alternative to this: http://forum.doom9.org/showthread.ph...ght=multiavchd Just open the edited disc in multiavchd and choose an output format suitable for PS3. When you load the bluray disc you must answer with yes if it ask you if you want to use the output with PS3. This question pops up if the bluray disc has java.
Old 14th December 2010, 11:22   #374  |  Link
416d697248
Sorry,Another problem has occurred again,I read your multiAVCHD guide and do just what you said.. (But I did it with the version that was edited by tsMuxeR before),But,Every time I tried to use multiAVCHD Although I selected main mpls file (In my case 00004.mpls) but in output I receved the movie that consist of extras inted of the main movie and it size is about 13GB..
Why?
Old 14th December 2010, 12:20   #375  |  Link
crl2007
For multiAVCHD behaviour you must ask in the official multiavchd thread. http://forum.doom9.org/showthread.php?t=143744&page=344 You must add the whole BDMV folder and answer yes when it asks you if you want to open BluRay Re-Author Mode.
Old 7th January 2011, 05:36   #376  |  Link
neohope
hi, i 've follow every step, & have save chapter from BD Edit, and use it , but when i play, i press next button, it still back to chapter 1
any suggestion ?
neohope is offline   Reply With Quote
Old 7th January 2011, 09:25   #377  |  Link
crl2007
You have to replace or edit your original mpls.
Old 7th January 2011, 14:11   #378  |  Link
neohope
already done it, after replace , i edit it, but still the same
Old 9th January 2011, 13:24   #379  |  Link
crl2007
You're doing something wrong. Please read the guide again.
Old 29th January 2011, 18:02   #380  |  Link
jediknight
hi crl2007,
my friend can you make a new guide for especially multiple .m2ts files. Like Gladiator Extenteed REMASTERED. Have 150 .m2ts files. and 2 version. Theatrical & Extendeed. So i think its not possible to add subtitle for this am i right ? Because i tried to apply your guide didnt help me. and i know i did everything same as you show.
So we need a detailed tutorial for about adding subtitle for multiple .m2ts files. Can you do that brother ?
Thank you, and can you check your pm please ?
have a nice day.
jediknight is offline   Reply With Quote
