24th December 2014, 18:48 | #1 | Link |
VOB versus IFO Full Frame Display Aspect Ratio
DVD 'Hackers' is supposed to be 2.35:1 Display Aspect Ratio according to data on back of DVD (and IMDB), and
16:9 Full Frame Display Aspect Ratio (letter-boxed). Shows as 4:3 Full Frame Display Aspect Ratio via DGIndex whereas MediaInfo also shows 4:3 on VOB but on the IFO file shows as 16:9. Is there any reason why VOB data should be used rather than IFO where their two values disagree ? Thank you in advance. EDIT: PowerDVD plays ok at 2.35:1 in 16:9 frame (I think).
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 26th December 2014 at 09:45. Reason: Change Frame Aspect Ratio to Full Frame Display Aspect Ratio |
25th December 2014, 12:59 | #2 | Link | |
That's why the DAR flag alone reports 4:3. Have a look at the allowed display modes in the IFOs using PgcEdit or IFOedit. I bet it says Pan&Scan allowed. Last edited by TheSkiller; 25th December 2014 at 13:01. |
26th December 2014, 09:59 | #3 | Link |
Thank you O' Skillfull one.
In PowerDVD, Pan&Scan is Greyed Out, and so cannot be used. Here output of DGIndex log file: Code:
Stream Type: MPEG2 Program Profile: main@main Frame Size: 720x576 Display Size: 720x576 Aspect Ratio: 4:3 [2] Frame Rate: 25.000000 fps Video Type: PAL Frame Type: Interlaced Coding Type: B Colorimetry: BT.470-2 B,G Frame Structure: Frame Field Order: Top Coded Number: 1518 Playback Number: 1518 Frame Repeats: 0 Field Repeats: 0 VOB ID: 2 Cell ID: 1 Bitrate: 5.972 Mbps Bitrate (Avg): 5.138 Mbps Bitrate (Max): 6.388 Mbps Audio Stream: 80: AC3 3/2 384 Audio Stream: 81: AC3 3/2 384 Audio Stream: 82: AC3 3/2 384 Audio Stream: 83: AC3 3/2 384 Audio Stream: 84: AC3 3/2 384 Timestamp: 0:01:00 Elapsed: 0:00:10 Remain: 0:03:24 FPS: 127.66 Info: Code:
Byte LBA Contents Data Value Value [Pack Header] [0000] Pack identifier (start code) 442 [000001ba] [0004] SCR (System clock reference) 68 0 4 4 148 173 [44 00 04 04 94 ad ] SCR 00000146.086 [000a] Program Mux Rate: 25200 (1260000 BPS) (10080000 bps) 1 137 195 [01 89 c3 ] [000d] Pack stuffing length: 0 248 [f8] [Video Stream] [000e] Video Stream start code 480 [000001e0] [0012] Length 2028 [07ec] [0014] PES Header data content flags 33217 [81c1] PES scrambling control: 0 PES priority: 0 data alignment indicator: 0 copyright: 0 original or copy: 1 PTS exist?: 1 DTS exist?: 1 ESCR flag? 0 ES rate flag: 0 DSM trick mode flag: 0 additional copy info flag: 0 PES CRC flag: 0 PES extension flag: 1 [0016] PES HeaderData length 13 [0d] [0017] PES HeaderData 49 0 3 81 129 17 0 3 53 97 30 96 232 [31 00 03 51 81 11 00 03 35 61 1e 60 e8 ] header data details: PTS 00043200 DTS 00039600 PES private data flag: 0 pack header field flag: 0 program packet sequence counter flag: 0 P-STD buffer flag: 1 PES externsion flag 2: 0 [0022] P-STD buffer 24808 [60e8] P-STD buffer scale: 1024 bytes P-STD buffer size: 232 (=237568 bytes) [0000] MPEG Sequence Header start code 435 [000001b3] [0004] Video attributes 755122227 [2d024033] Video width: 720 Video height: 576 aspect ratio code: 3 16:9 frame rate code: 3 25 bit rate: 183488 VBV buffer size: 112 constrained parameters flag: 0 load intra quantiser matrix: 1 load non-intra quantiser matrix: 0 [0008] MPEG Frame 11 51 35 ... some frame content details: [004c] Extension start code 437 [000001b5] [0050] Sequence_Extension 20 130 0 1 0 0 [14 82 00 01 00 00 ] Extension ID-bits: 1 profile and level: Escape bit: 0 Profile identification: 4 Profile: Main Level identification: 8 Level: Main progressive_sequence: 0 PROGRESSIVE_SEQUENCE: 0 chroma_format: 1 chroma_format: 4:2:0 horizontal size extension: 0 vertical size extension: 0 bit rate extension: 0 vbv buffer size extension: 0 low delay: 0 frame rate extension n: 0 frame rate extension d: 0 [0056] Extension start code 437 [000001b5] [005a] Sequence_Display_Extension 35 5 5 5 11 66 [23 05 05 05 0b 42 ] Extension ID-bits: 2 video format: 1 video format: PAL color description flag: 1 [005b] color primaries 5 [05] [005c] transfer characteristics 5 [05] [005d] matrix coefficients 5 [05] display horizontal size: 720 display vertical size: 576 (Dont know if I looked at wrong place in PgcEdit, not used for about 5 years) Weird how DGIndex seems to think that it is 4:3 when clearly show 720x576 16:9 in VOB MPEG Sequence Header and display size: 720x576 in Sequence_Display_Extension. EDIT: Although MediaInfo thought it was 4:3 also. Anyway, no reply necessary, have decided to Throw an error alert to user that there is disagreement. Here is reason for Thread Question:- http://forum.doom9.org/showthread.ph...05#post1703705 Again Thanx TheSkiller for your reply
I sometimes post sober. StainlessS@MediaFire ::: AND/OR ::: StainlessS@SendSpace "Some infinities are bigger than other infinities", but how many of them are infinitely bigger ??? Last edited by StainlessS; 26th December 2014 at 12:26. |
dgindex, ifo, vob |
