9th March 2010, 06:40 | #81 | Link |
Fighting spam with a fish
Oh, and small bug report (100304).
I am unable to add an external audio source in the source tab. I press the "Audio" button, select my source mp4 file (which is pure aac audio, no video) and press Ok. The path does not change from the video input file. What I'm trying to do is a muxing job, with video in "passthrough" and audio in "custom add all". After trying to enqueue the file (to see if it was adding the file invisibly) I get an error about adding an empty audio track while "audio != ignore". |
9th March 2010, 07:04 | #82 | Link |
Damn, can't connect to my svn server atm, seems to be a problem with no-ip.
Will look into the audio problem once I can reconnect to my server. -> fixed locally Cu Selur Ps.: wrote an XMedia Recode profile importer, but since I never used the program and I'm not totally sure if I interpreted all the settings right some feedback would be nice (if anyone uses it): http://www.selur.info/test/import.zip (Misc->Misc settings->Import) Last edited by Selur; 9th March 2010 at 09:21. |
9th March 2010, 16:02 | #84 | Link |
My backgrounds normally are all bright so I never really noticed.
changed it a bit for the next release, it's still not popping into your eyes, but it should be noticeable. KDE: Gnome: Last edited by Selur; 9th March 2010 at 16:19. |
9th March 2010, 16:53 | #85 | Link |
Hybrid ver.100309
*added* - x264 command line import (x264->misc) - XMediaRecode profile importer (misc->misc settings->import), probably buggy since I had to guess a bunch of mappings (feedback is welcome ) - MeGui audio profile import (audio->misc->import) (added and removed a MeGui video import option, since as far as I can tell their profiles are inconsistent) *changed* - rearrange audio tab - prefer mencoder on ulaw audio input - system tray icon to be a bit better visible with dark backgrounds - show output framerate in filterTab (!not accounting for x264 pulldown parameter!) - show subtitle extraction progress *fixed* - forgot to do anything when 'telecine' was enabled (you need to enable Misc in the Main-Tab to enable the Misc-Tab) Reset Defaults in Misc-Tab on first start -> updated links in 1st post |
11th March 2010, 04:42 | #86 | Link | |
Okay, while attempting to create a smaller file to file a bug report with, I found another bug.
Description: When loading an audio only mp4, with audio set to passthrough all and file splitting set to 10 MB, mp4 box crashes. Debug log: Code:
2010.03.10 - 19:34:48_100309 - on_removeJobPushButton_clicked 2010.03.10 - 19:34:48_100309 - getSelectedParentIDs 2010.03.10 - 19:34:48_100309 - acceptableState CRASHED -> : true 2010.03.10 - 19:34:48_100309 - removeJobs called: 19_33_20_664 2010.03.10 - 19:34:48_100309 - removing: 19_33_20_664 2010.03.10 - 19:34:48_100309 - filtered count: 3 2010.03.10 - 19:34:48_100309 - remove: 19_33_20_664 2010.03.10 - 19:34:48_100309 - on_clearQueuePushButton_clicked 2010.03.10 - 19:34:48_100309 - removeJobs called: 2010.03.10 - 19:34:53_100309 - checkAndCreateJobs,... 2010.03.10 - 19:34:53_100309 - Checking audio for: /home/adub/audio+tests.mp4 2010.03.10 - 19:34:53_100309 - checking subtitle settings,... 2010.03.10 - 19:34:53_100309 - subtitles look okay. 2010.03.10 - 19:34:53_100309 - video settings look okay. 2010.03.10 - 19:34:53_100309 - generating VideoCalls... 2010.03.10 - 19:34:53_100309 - SourceCount: 1 2010.03.10 - 19:34:53_100309 - createJobs called... 2010.03.10 - 19:34:53_100309 - createJobs for: /home/adub/audio+tests.mp4 2010.03.10 - 19:34:53_100309 - no video calls detected 2010.03.10 - 19:34:53_100309 - called with empty tag list 2010.03.10 - 19:34:53_100309 - called with empty chapter queue 2010.03.10 - 19:34:53_100309 - createJob audio... 2010.03.10 - 19:34:53_100309 - createAudioJobs: /home/adub/dark audio.mp4;0;aac;2;passthrough;159;;;48000;;und;0;9133.38;aac;0;0;don't change 2010.03.10 - 19:34:53_100309 - jobCount: 1 2010.03.10 - 19:34:53_100309 - createAudio for job: 0 2010.03.10 - 19:34:53_100309 - createAudioJob, current: /home/adub/dark audio.mp4;0;aac;2;passthrough;159;;;48000;;und;0;9133.38;aac;0;0;don't change 2010.03.10 - 19:34:53_100309 - createAudioJob: /home/adub/dark audio.mp4 2010.03.10 - 19:34:53_100309 - createAudioJobForFile: /home/adub/dark audio.mp4 2010.03.10 - 19:34:53_100309 - extract4Nero: false 2010.03.10 - 19:34:53_100309 - generateAudioOutputName: Input: /home/adub/dark audio.mp4 -> isRaw: false Output: audio+tests_und_aid_0__19_34_53_061_01.aac -> isRaw: false 2010.03.10 - 19:34:53_100309 - generated output name: /tmp/audio+tests_und_aid_0__19_34_53_061_01.aac 2010.03.10 - 19:34:53_100309 - newAudioJob called: 19_34_53_061_01 2010.03.10 - 19:34:53_100309 - -> audioStreams to mux: /tmp/audio+tests_und_aid_0__19_34_53_061_01.aac 2010.03.10 - 19:34:53_100309 - createJob muxing... 2010.03.10 - 19:34:53_100309 - generateMuxingCall.. 2010.03.10 - 19:34:53_100309 - generate mp4 mux call called,... 2010.03.10 - 19:34:53_100309 - audioStreamsToMux: /tmp/audio+tests_und_aid_0__19_34_53_061_01.aac 2010.03.10 - 19:34:53_100309 - audioLangPassthrough: false 2010.03.10 - 19:34:53_100309 - output: /home/adub/audio+tests.mp4 2010.03.10 - 19:34:53_100309 - mp4 audio part ... 2010.03.10 - 19:34:53_100309 - parts: /tmp/audio+tests_und_aid_0__19_34_53_061_01.aac 2010.03.10 - 19:34:53_100309 - clear tagPart 2010.03.10 - 19:34:53_100309 - grabDelayFromFilename: /tmp/audio+tests_und_aid_0__19_34_53_061_01.aac 2010.03.10 - 19:34:53_100309 - ->DELAY 0 2010.03.10 - 19:34:53_100309 - createMuxerAndCleanUpJobs.... 2010.03.10 - 19:34:53_100309 - newMuxingJob called 2010.03.10 - 19:34:53_100309 - newCleanUpJob called 2010.03.10 - 19:34:53_100309 - creating new TopLevelItem,.. 2010.03.10 - 19:34:53_100309 - Added new sub-job with id: 19_34_53_061_01_audio 2010.03.10 - 19:34:53_100309 - Added new job with id: 19_34_53_061 2010.03.10 - 19:34:53_100309 - Added new sub-job with id: 19_34_53_061_02_muxing 2010.03.10 - 19:34:53_100309 - Added new sub-job with id: 19_34_53_061_03_cleanUp 2010.03.10 - 19:34:55_100309 - on_startJobPushButton_clicked 2010.03.10 - 19:34:55_100309 - getSelectedParentIDs 2010.03.10 - 19:34:55_100309 - getSelectedParentIDs 2010.03.10 - 19:34:55_100309 - startJobs,... 2010.03.10 - 19:34:55_100309 - acceptableState WAITING -> : true 2010.03.10 - 19:34:55_100309 - emit Start() 2010.03.10 - 19:34:55_100309 - starting job: 19_34_53_061 2010.03.10 - 19:34:55_100309 - 127.0.0.1 free count: 1 2010.03.10 - 19:34:55_100309 - 127.0.0.1 parallel count: 1 2010.03.10 - 19:34:55_100309 - Processing: 19_34_53_061_01_audio 2010.03.10 - 19:34:55_100309 - Processing 19_34_53_061_01_audio: MP4Box -raw 1 "/home/adub/dark audio.mp4" -out "/tmp/audio+tests_und_aid_0__19_34_53_061_01.aac" 2010.03.10 - 19:34:55_100309 - 19_34_53_061_01_audio: mp4Box started... 2010.03.10 - 19:34:55_100309 - Starting Main: "/usr/bin/MP4Box" -raw 1 "/home/adub/dark audio.mp4" -out "/tmp/audio+tests_und_aid_0__19_34_53_061_01.aac" 2010.03.10 - 19:34:55_100309 - processFinished: 1 2010.03.10 - 19:34:55_100309 - Processing: 19_34_53_061_02_muxing 2010.03.10 - 19:34:55_100309 - Processing 19_34_53_061_02_muxing: MP4Box -add "/tmp/audio+tests_und_aid_0__19_34_53_061_01.aac"#audio -splits 10240 -new "/home/adub/audio+tests.mp4" 2010.03.10 - 19:34:55_100309 - 19_34_53_061_02_muxing: mp4Box started... 2010.03.10 - 19:34:55_100309 - Starting Main: "/usr/bin/MP4Box" -add "/tmp/audio+tests_und_aid_0__19_34_53_061_01.aac"#audio -splits 10240 -new "/home/adub/audio+tests.mp4" 2010.03.10 - 19:34:55_100309 - processFinished: 1 2010.03.10 - 19:34:55_100309 - /home/adub/audio+tests.mp4 does not exist! 2010.03.10 - 19:34:55_100309 - 19_34_53_061_02_muxing: ERROR: /home/adub/audio+tests.mp4 was not created! 2010.03.10 - 19:34:55_100309 - finishedJob: 19_34_53_061 2010.03.10 - 19:34:55_100309 - Client 127.0.0.1 free job count: 1 2010.03.10 - 19:34:55_100309 - startJobs,... 2010.03.10 - 19:34:55_100309 - acceptableState CRASHED -> : false 2010.03.10 - 19:34:55_100309 - No parentjobs -> nothing to do edit: first audio sample, full audio file: http://mirror.adubvideo.net/dark audio.mp4 Error Message: Quote:
edit2: While trying to mux these two files together using passthrough and custom add, another crash occurs. It looks like the crash is rooted in an mp4box problem. audio : http://mirror.adubvideo.net/dark audio-001.mka video : http://mirror.adubvideo.net/video-001.mkv Last edited by Adub; 11th March 2010 at 05:43. |
11th March 2010, 08:46 | #87 | Link | ||
I'll look into it.
I now know where the problem is, just need to find a way to fix it. Hybrid is using the false track id, I now 'just' need to find a reliable way to get an MPlayer ID <-> mp4box id mapping. Would be simple for single audio input (simply map first found audioID mediainfo reports to first audio id mplayer reports), problem is I don't know a way to do a more reliable mapping to handle multi-audio input. (atm Hybrid always used mplayer-AudioID + 1 als mp4box ID which worked for the mp4 files I got here. ) Quote:
-> send you a link to an updated version, will wait for your feedback before releasing it. Last edited by Selur; 11th March 2010 at 10:42. |
11th March 2010, 14:01 | #88 | Link |
Since I got a call and I'll be off for the days here's a general update:
Hybrid ver.100310 *fixed* - mkvmerge ui-language (checking now if en or "en_US" should be used) - mka was handled as if it were raw audio *changed* - scanorder detection for dvds - match mp4 ids of streams to mplayer ids of streams (you need to enable Misc in the Main-Tab to enable the Misc-Tab) Reset Defaults in Misc-Tab on first start -> updated links in 1st post |
13th March 2010, 05:42 | #89 | Link |
Great, thanks Selur. I'll test it ASAP.
Edit: Well, the mkv merge seems to work. However, I'm still getting a problem when I try to merge an AAC MP4 and a video MP4 generated from a bluray into one output. Apart, the two files work just fine, but when I combine 'em, mplayer just plays the video and chokes on the audio. The whole process completes just fine, but the end ouput does not play any audio. There is an audio track, but it is silent, or can't be decoded. This is with Mplayer and VLC. Last edited by Adub; 13th March 2010 at 06:18. |
13th March 2010, 09:24 | #90 | Link | |
Would help if you could reproduce this with a small sample, write a small step-to-step guide how to reproduce it and send me both.
as a small reminder: Quote:
MP4Box -sbr "your mp4 file" "aac-sbr-fix.mp4" Also send you a testversion where: a. Hybrid does he-aac signaling when reencoding to he-aac b. got a new option in Audio->misc that let's you manually enabling he-aac signaling when using audio passthrough Cu Selur Last edited by Selur; 13th March 2010 at 10:50. |
13th March 2010, 22:04 | #91 | Link |
Hybrid ver.100313
*fixed* - 2pass bitrate adjustment when input and output fps differ (e.g. for ivtc) *added* - 'he-aac' signaling for mp4/mkv output will be done automatically one reencodes the audio to aac high efficency (v2) or neroAacEnc auto-mode and quality < 31, otherwise one has to enable it manually under Audio->Misc (you need to enable Misc in the Main-Tab to enable the Misc-Tab) Reset Defaults in Misc-Tab on first start -> updated links in 1st post |
15th March 2010, 21:25 | #92 | Link |
Hybrid ver.100315
*changed* - mkvmerge ui languge using 'en' on windows and 'en_US' on linux systems *fixed* - 5.1->stereo downmix *added* - testing xvid support (still not sure how to set vbv restrictions and haven't written code for zone support yet) (you need to enable Misc in the Main-Tab to enable the Misc-Tab) Reset Defaults in Misc-Tab on first start -> updated links in 1st post |
16th March 2010, 06:43 | #93 | Link |
Just out of curiosity, is there a way to force Hybrid to not save the resolution in the command line when saving an X264 profile? For example, when I created the profile, I was using a video with 624x356 resolution. Now, when I use the profile on a 720 vid, it tries to set the resolution in the x264 commandline to an incorrect resolution (624, instead of 720).
I would much prefer that it just saved the encoding settings and not the resolution. |
17th March 2010, 19:00 | #95 | Link |
Hybrid ver.100317
*fixed* - forgot to remove quotes around filename when converting subtitles - accidently added embedded subs also to container - output resolution != expand resolution, when changing output par + changing resolution + changing expand size manually (took me quite some time to find this one ) *changed* - converting srt -> ttxt now without mp4box (basic atm. additional options are planned) - Xvid: vbv can only be restricted through the profiles (see: http://www.mplayerhq.hu/DOCS/HTML/en...feat-xvid.html) adjusted Hybrid accordingly - removed some source specific settings from x264&xvid profiles (you need to enable Misc in the Main-Tab to enable the Misc-Tab) Reset Defaults in Misc-Tab on first start -> updated links in 1st post |
18th March 2010, 02:14 | #96 | Link |
@Selur
i cant set more then 50 Lookahead (frames) with x264 in 100317? eac3to in Hybrid? keep up the great work
StaxRip at Doom9's | StaxRip at Sourceforge [RSS] | StaxRip Donations | TheMTiNFo |
18th March 2010, 05:38 | #97 | Link |
Haven't changed this for quite some time:
syncLoolahead got a minimum of: threads+bramecount = cpuCoreCount*1.5 + bframes (cpuCount will be detected if threads = 0, otherwise thread value will be used) rc-lookahead is limited to: max = Max(gopMaximum, qMax(vbvMaxBitrate, Bitrate)/vbvMaxBuffer*Framerate) That's what I integrated after: http://forum.doom9.org/showthread.php?p=1321220 So depending on your other settings it might well be that hybrid wouldn't allow more than 50 frames lookahead. Cu Selur |
19th March 2010, 17:47 | #98 | Link |
Hybrid ver.100319
*fixed* - a bunch of bugs related to tagging - automatic qp file generation for chapters - some small cosmetic glitches (you need to enable Misc in the Main-Tab to enable the Misc-Tab) Reset Defaults in Misc-Tab on first start -> updated links in 1st post |
29th March 2010, 20:13 | #99 | Link |
I may have mentioned this before, but hybrid cuts off the last few seconds of the video sometimes and the only way I can fix it is to process the audio with another program and mux it to the mp4.
Is there anything I can try to prevent hybrid from cutting off the last few seconds of the audio? |
