31st March 2010, 02:59 | #12341 | Link |
It was always checked and still is.
I can't reproduce the issue now as I switched the monitors in the correct order (primary lcd in first dvi and so on) and I'm not keen on experimenting again (the ati driver still does blue screens when I mess with it and forget to uninstall the driver before changing slots) |
31st March 2010, 22:08 | #12342 | Link |
Guys... like I wrote ar-jar (wonderful guy) using PMs:
Nvidia Forceware 197.13 recently became WHQL drivers and are recommended by Nvidia to all its users. Both "Custom EVR" and "EVR Sync" have stuttering issues (reported here in this thread) w/ this version of the driver. I believe this should be fixed ASAP, as more and more users experience the issue in the tech support forum I'm helping at. |
31st March 2010, 23:21 | #12343 | Link |
MPC-HC Project Manager
Have these users also complained to nvidia?
They desperately need to fix this bug in their driver
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC |
31st March 2010, 23:28 | #12344 | Link |
Some did. The thing is... nobody's sure if it's a driver issue or a MPC-HC issue.
The fact remains, both these renderers did work w/ previous driver versions... but that still doesn't necessarily makes it a driver issue. Looking the the Stats graph, one can clearly see MPC-HC is having difficulty timing the frames (see here; look how the red lines are jumping above the green ones). Regular (system-provided) EVR works fine, of course. EDIT: btw, I'm pretty sure that ar-jar would find the cause pretty quickly (as this issue can easily be reproduced)... If anyone knows the EVR frame timing code- it's him. We can only hope he finds the free time to debug this issue. Last edited by Superb; 31st March 2010 at 23:34. |
1st April 2010, 00:18 | #12345 | Link |
None of these issues neither with my old ATI HD3650(Vista) or the even older Hd2600XT(XP) from my son's computer. So it's definitely not a MPC-HC problem. On Guru 3d some guys reported strange behaviour for NVIDIA cards ,with the latest drivers ,on other players too(ex KMPlayer)
1st April 2010, 01:45 | #12347 | Link | |
I think it's time I disable Windows Update on my HTPC again. !!! |
1st April 2010, 09:36 | #12348 | Link | |
It doesnt happen on: Intel, S3, broadcom, ATI and Nvidia cards with older drivers. Even so, i agree that its interesting too look at, as it might reveal an edge case in our or microsofts code.
MPC-HC, an open source project everyone can improve. Want to help? Test Nightly Builds, submit patches or bugs and chat on IRC Last edited by tetsuo55; 1st April 2010 at 09:39. |
1st April 2010, 21:01 | #12349 | Link |
Hi.
Looks like there is problem in MPC-HC avi splitter, this sample run in slow motion. Working fine when using system default AVI splitter or haali.
Working machine: Win10x64 + Intel Skull Canyon My HTPC. How to start with Bitcoin |
1st April 2010, 22:39 | #12350 | Link | |
2nd April 2010, 07:03 | #12351 | Link |
Of course i am using FFDshow. Simply system default/haali splitter + ffdshow - no problem, MPC-HC AVI splitter + ffdshow - slow motion.
2nd April 2010, 10:51 | #12352 | Link | |
I have no stuttering or whatsoever with the newest drivers playing x264 files in a nvidia gt240 with evr sync. |
2nd April 2010, 11:14 | #12354 | Link |
It only happened for me on files that were not using DXVA (so AVI files, MPG etc). I only noticed it recently as I only play HD files or movs via DXVA!
Dropping back to 196.21 has solved it though so that's a good thing I guess. |
2nd April 2010, 13:05 | #12355 | Link | |
Are you using the auto-resolution changer in MPC? |
2nd April 2010, 13:10 | #12356 | Link | |
http://www.ostrogothia.com/video |
2nd April 2010, 13:41 | #12357 | Link | |
Edit: I restarted the computer having installed the new driver and after that everything worked great again (fortunately or unfortunately). I have not used the W7 computer a lot so I just now realized how well the windowed mode full-screen actually works. I have no tearing even with 5 ms sync offset, bicubic interpolation and a couple of shaders active. This seems too good to be true so I need to run a few more tests but right now (by luck or by design) it looks quite promising. My hardware is a four-core Intel CPU with a GeForce 7600 board (I stick to it because it is compatible with PowerStrip). The TV uses a 720p/50Hz resolution. Anyway, this does not bode well for finding your problem unfortunately. I'll try to tweak resolutions, refresh rates etc to see if I can reproduce the failure.
http://www.ostrogothia.com/video Last edited by ar-jar; 2nd April 2010 at 21:08. |
3rd April 2010, 01:47 | #12358 | Link |
5.1 audio wont play on TV with stereo setup
I can't play all my movies that have 5.1 sound through my TV that is stereo sound. Why? The same movies play fine with my other setup that is connected through a surround sound receiver. The file types are all kinds (avi, mkv, mp4 etc.)
3rd April 2010, 02:57 | #12359 | Link |
My system:
Intel Core 2 Duo E6750. 2GB DDR2-800Mhz. Windows 7 Ultimate 32bits (all updates installed). Aero is on. GeForce 8800GT. Forceware 197.13 WHQL. 24" LCD screen working at 60Hz. Resolution is 1920x1080. Latest DirectX runtime installed. MPC-HC 1.3.1774.0 (from XvidVideo.ru). Settings changed in MPC-HC (all others are default): - Resizer being Bicubic A=-0.75 (PS 2.0). I'm using EVR CP. - All internal filters are off. I use Haali for MKVs, ffdshow for audio decoding, Win7's filters for H.264 (w/ DXVA), Xvid, and MPEG-2. - Audio switcher is off. - Subtitles max texture resolution is set to "Desktop". I'm not sure if the issue is reproducible on XP. Might be a Win7-only issue. I'm currently trying the identify any specific content (maybe fps?) that causes this issue to rise. Will post more info later. EDIT: Alright, I've sent ar-jar a small (8MB) xvid-avi-25fps that causes this issue to happen when seeking the file (using EVR Sync w/ default settings). Last edited by Superb; 3rd April 2010 at 03:16. |
3rd April 2010, 13:33 | #12360 | Link | |
A question in the mean time: do you get the same behavior when running in a window that is substantially smaller than the desktop (but large enough to see the graph)? -A
