8th March 2012, 00:12 | #12661 | Link | |
MPC-HC Developer
8th March 2012, 06:17 | #12662 | Link | ||
I can't be certain of the primaries, but I did an A <-> B comparison of SD and HD of the same programme sample and it looks like the SD was left in BT.709 (leaving MadVR to do the Gamut conversion made the color a bit different to the HD encode) Just a thought! Last edited by 703; 8th March 2012 at 09:09. |
8th March 2012, 08:18 | #12663 | Link | |
For the record however, the NFO clearly states that you shall specify the colormatrix in the x264 command line to match the source, which would cause it to write that information into the bitstream where a decoder or madVR can read it from.
8th March 2012, 09:36 | #12665 | Link | ||||||||||
Good to hear. So Pat357's freeze must have a somewhat different cause. Quote:
@Pat357, could you please reproduce the freeze with kasper93's debug MPC-HC build? (Make sure you don't delete the pdb file.) A freeze report with that MPC-HC build might help figuring out why exactly MPC-HC is trying to create a D3D device. Thx. |
8th March 2012, 10:03 | #12666 | Link | |
If someone can find a file that really contains such information, i can try to look into it, but otherwise, i have nothing to go on.
8th March 2012, 10:55 | #12670 | Link |
Broadband Junkie
Freeze displaying a vertically stretched video frame when entering Fullscreen from Desktop (windowed).
http://www.mediafire.com/?i2b9vffj15uop98 Note: Generating the freeze report with CTRL+SHIFT+ALT+BREAK kicked madVR back to Desktop (windowed) in a paused, unfrozen state. I don't believe Fullscreen (exclusive) ever had a chance to kick in before the freeze happened. |
8th March 2012, 11:01 | #12671 | Link | |
8th March 2012, 15:20 | #12673 | Link |
I'm sure 'some companies' would be interested madVR from a while back. There's not a renderer with this efficiency in the consumer market. I can't speak for the professional/enterprise video software market since I don't know but if I were to venture a guess then I'm sure they are as well.
8th March 2012, 20:31 | #12674 | Link | |
Broadband Junkie
I'm unable to reproduce the problem at will, it doesn't appear linked to any particular video, and I've not discovered any easy way to reproduce the issue. I've seen this happen before, but it's rare, maybe once a month or less... I'll try running madVR debug constantly for awhile, and hope I get lucky enough to catch it sometime soon. |
8th March 2012, 22:30 | #12675 | Link |
I noticed that there are some color problems with YCgCo matrix. The difference is not huge and often not noticeable if you donīt know how it should look like.
Could you please look into that? I can provide an YCgCo example if you tell me what source I should encode. |
8th March 2012, 22:54 | #12676 | Link |
Hi madshi, I got a freeze today in mpc-hc 4130 + madVR v0.82.4
Maybe its the same problem as you have mentioned to Aleksoid in the mpc thread, maybe not. Its attached below incase its useful. It seemed fairly random. I had mpc-hc in windowed mode and had seeked through a vob from a DVD about 30 seconds earlier to find a particular scene. The scene played for about 30 seconds as I say but then the video image froze on one frame, mpc-hc was responding to mouse clicks and audio was continuing to play fine so I seeked again and mpc-hc froze up completely then and blue Windows 7 icon started spinning so I took the report below. http://www.mediafire.com/?zwh6nwnawvqc1yh |
9th March 2012, 00:37 | #12677 | Link | |||||
Maybe you could, not sure if it's possible, run his in a complete separate process ? Of course this would require some data to be changed out between the processes, but at least the separate process could create the report with the latest data has it received from the now "frozen" process. Quote:
"unconditionally" deinterlace to whole stream without questions asked. (EVR will "obey" these flags) This doesn't seem to work that way ATM with MadVR. The other options in Lav-video like "agressive deinterlacing" and "thread as progressive" (never deinterlace) seem also not to work as intented with Madvr. Quote:
Like I said before, normally you can't switch MPC in full screen when playing audio... I think it has (maybe indirectly) to do with this. Something along : "if I (MPC-HC) am in full screen mode, I have to create a new D3Ddevice..." Following the MPC logic, "it must be a video file, because I can't be in "full screen" with audio files.... " Quote:
See http://www.mediafire.com/?v88ii8owp1oqppx Last edited by Pat357; 9th March 2012 at 00:41. |
9th March 2012, 03:21 | #12678 | Link |
I have on madVR on display properties "TV levels" (16-235) when conecting to my tv to avoid conversions and scaling and to match source native levels.
Now, Im looking to be safe avoiding any conversion. Should I select on AMD CCC on Pixel Format, output to Limited RGB or Full RGB? |
9th March 2012, 05:14 | #12679 | Link |
In windowed mode > toggle video/film mode > enter FSE > madVR will not change refresh rate.
In FSE > toggle video/film mode > madVR changes refresh rate > freeze Freeze report: http://www.mediafire.com/?r3pjxkdpmt6rfe4 One thing I noticed: When in FSE, after the freeze, CTRL+ALT+SHIFT+T still changes refresh rate, but nothing else seems to respond.
Windows 7 x64 i7 870 16GB RAM AMD 6870 Last edited by robpdotcom; 9th March 2012 at 05:18. |
9th March 2012, 06:02 | #12680 | Link | |
QB the Slayer
However, if your TV does not support 0-255 then you only need to change madVR's levels to 16-235, NOT your GPU's levels (these should always stay on "PC Levels"/"Full") QB
