24th December 2011, 22:48 | #11662 | Link | |
It's still juddering though slightly better than before. I am beginning to wonder if it's the Onkyo 609 amp or something else. |
24th December 2011, 23:23 | #11663 | Link |
Try the tips I mentioned in my previous post. Are you using reclock?
Motherboard: GIGABYTE GA-990FXA-D3 Processor: AMD FX 8150 Black Edition 8-core @3.6 Ghz. RAM: G-Skill Ares 16GB dual channel DDR3. GPU: 2X Crossfire AMD RADEON HD 6850. OS: Windows 7 Utlimate x64. |
25th December 2011, 09:55 | #11666 | Link | |
25th December 2011, 11:25 | #11667 | Link |
On that machine I'm stuck at 60Hz, which is more like 59Hz in practice. On my HTPC I can do both 50p and 24p, but I still need to turn the fields into frames. As I understand it the DVDs use a simple PAL 2:2 cadence where each progressive frame is split up into two fields, and to get the progressive stuff back you just need to stitch the fields back together again. madVR detects the cadence but is screwing up the sticking-back-up part.
25th December 2011, 18:07 | #11668 | Link |
I'm not sure what madVR should do, but even if your output wasn't screwed, slowing down with ReClock to 24p and then playing at 60p (pulldown) will avoid you the higher pitch, and might just fix your problem too.
MSI MAG X570 TOMAHAWK WIFI, Ryzen 5900x, RTX 3070, Win 10-64. Pioneer VSX-LX503, LG OLED65C9 |
25th December 2011, 18:23 | #11669 | Link |
Maybe that disc isn't actually TC'ed but truely interlaced, detection of a 2:2 cadence (without misdetection) is one of the harder things.
In any case, madshi could probably use a sample file to say anything about it.
25th December 2011, 19:14 | #11670 | Link | |
EDIT: Here is a sample. Last edited by Mr Alpha; 25th December 2011 at 19:32. |
26th December 2011, 00:33 | #11671 | Link | |
I was simply doing some testing because my system has a much faster CPU and FSB etc over my GPU. From my understanding, RGB outputs are (at the time of decoding prior to rendering) of higher quality. However, there is a performance hit (at the CPU level) ...while this is an issue for many people, it is not for me. In addition, in theory, making ffdshow do the RGB conversion leaves less work for the Renderer to do on the GPU (i.e. in madVR...) Finally, there is a greater level of control when doing this at the software level. (E.g. one can correct the colorspace in ffdshow.) A couple years ago I had the best results using these settings. However, madVR works so well and displays YV12 (or the now-preferred NV12) with negligible GPU difference, thus even though I have the processing power, it is not really needed anymore. Still, I like to play around, so I was testing this scenario. I hope that helps and I apologize if I confused anyone. MikeY |
26th December 2011, 02:04 | #11672 | Link |
A special thank you to madshi and Nev for their awesome work on both the renderer and the filters. All my systems are working perfectly in playing all my content even the lower end ones.
Merry christmas and happy new year! May god bless you.
26th December 2011, 19:49 | #11674 | Link | |
If everything is working fine, don't fiddle with the settings! The queue size can help to give you more stable playback, but if you have no issues, just leave it at that.
26th December 2011, 19:56 | #11675 | Link |
Is there any news on a feature with the same function as the Autochange Fullscreen Monitor Mode in mpc-hc being added to madVR?
Would kill for this function Often, i would be watching a movie in a window, and it's a pain trying to browse in 24hz mode. I would just ditch madVR's refresh changer and use the one in mpc-hc but with madVR this causes other problems when you try to fullscreen certain files. Thanks. Last edited by Xello; 26th December 2011 at 19:58. |
26th December 2011, 20:42 | #11676 | Link |
Previously, I would have said to make them as big as you have the memory for to ensure that playback is smooth without any dropped frames, but in recent versions (since the option to change the GPU queues was added) I'm not able to get 100% smooth playback no matter what the setting is, and playback is smoothest with the least number of queues I can select.
27th December 2011, 01:08 | #11678 | Link |
I can't set 48hz. Even in 24hz mode the tv is actually in 96hz, though that doesn't matter when it's being sent a 24hz signal. Though even a theoretical 48hz mode wouldn't be what i'm after, I want windowed mode to be in native hz, simple as that.
That was just one example to show where fullscreen-only refresh rate changer comes in handy, there are other reasons but there's no need to make a big deal out of the request, so I just offered one scenario. |
27th December 2011, 16:10 | #11680 | Link |
AMD CCC, under the video settings tab, should i use auto deinterlacing or should i use vector adaptive, which will give me the best quality
im using an ati 5670, mpc-hc, madvr, lav splitter, lav video and audio what other settings under the video settings should i enable or disable |
