21st August 2017, 04:02 | #2461 | Link |
A lot of people still like to encode, I do. It's almost a hobby in a way . A good streaming player would be good though, especially if it can use madVR to maximise playback quality with maybe EVR as a fallback. For encoding you already need the source so you can watch it anyway, streaming is just convenience.
Ultimately a stream capture, temp storage as a largeish file and encode function would be handy, purely for personal use of course. Stream and save like an old analogue TV tuner card from the player, encode with Staxrip. |
26th August 2017, 12:44 | #2466 | Link |
30th August 2017, 22:54 | #2467 | Link | |
"MP_Pipeline" can help, i run a few things in x86-32bit mode inside staxrip x64, made a long explanation about it once, on this page here : https://github.com/stax76/staxrip/issues/170 Might serve for your problem too, still running fine for me. @Stax : Hi, i had to take a little break for various reasons, i come back and there was like 30 new releases done lmao, lot of new interesting things and fixes, you never stop man, thanks a lot for that hard work. Had to re-do most of my profiles and settings again, exporting the settings as before did not worked this time for many of them or some things were messed up like the event commands that were all inverted. Anyways i almost done all and i have a question for the AAC encoders : - I used to encode audio in 384k CBR for some of my stuff, this is still possible using ffmpeg for the encoding, however after getting the needed files for the qaac and fdkaac i can not achieve this with those. qaac is quite interesting with the piping from ffmpeg but apparently it is limited to 320k for stereo no matter if you set up a higher value ( goes higher with more channels than a simple stereo tho). According the the documentation and if i understood correctly something i saw on one of my google searches you can somehow trick it if you set a value under 8 bits like said here : https://github.com/nu774/qaac/wiki/E...-configuration Quote:
fdkaac seems to work but this one doesn't keep my settings, i am not sure if it's a bug yet so i ask here first and if needed i'll make a report on github. If i make a profile or set it to 384 like here : It works, but only once, using mediainfo the audio ouput when i use this is 384, same if i set 512 the ouput is 512, for some reasons after the profile is loaded again or for the next encoding it reverts to another value than the 384 in profile, again not sure if i am missing something and doing it wrong here or if it' a bug, or else. Anyways i would like to use either qaac with the piping option or fdkaac with CBR 384 bitrate, qaac i can't since i cannot trick it with a birate under 8bits as the minimum i can set is 16 bit and fdkaac is apparently not working as expected and reverting my settings and profiles... if you or someone else have any ideas please, if the fdkaac reverting is confirmed as bug i'll make a proper bug report for it. Thanks in advance and as always thanks a lot for this great tool ( and curious to see about the player you are working on too ) Last edited by Yanak; 23rd January 2018 at 00:05. |
31st August 2017, 00:40 | #2468 | Link | ||
My new player is included, it's mostly pure mpv with dotnet addon feature. Requirements .NET 4.7 is required on systems prior Windows 10 Version 1703 (Creators Update) https://www.microsoft.com/en-us/down....aspx?id=55170 Download https://drive.google.com/open?id=0B-...ld4dzhuTC1WWWM https://1drv.ms/f/s!ArwKS_ZUR01goCzIRemxotXY_zz- 1.6.1.1 unstable test build
31st August 2017, 08:44 | #2469 | Link |
awesome, downloading it now and gonna test all this, thanks a lot for the quick changes and fixes Stax, perfect as always. Seems like i also found an issue with some video files having long names leading to some errors and files not found, already used to happen before once in a while but saw there was a fix applied for long names in one of the releases in the meantime, something is not working as it should i think, need to test more all this and pinpoint the issue then I'll report it on the tracker later in the day. I will have to check a bit about mpv and his possibilities, and also how to store permanently some setting like borderless mode etc, using a cfg file is apparently possible so it should be fine, just need time to play a bit with this new toy. Not sure what dotnet adds as possibilities but i trust in you to bring some interesting features on this new project, will follow the dedicated thread for this Thanks again for all. PS: just saw there is a "x86" and "release" subfolder folder in last version, not sure if supposed to be there. |
31st August 2017, 10:41 | #2470 | Link |
mpv has a learning curve, mpv.net supports almost everything except window features because it uses window embedding in order to being able to add a classic GUI like menus and dialogs, I might be able to implement window features on request. I worked some minuted on a x86 build, it's something I don't like much to do but I know there are quite a few people who use it so I should try to get it working some day.
3rd September 2017, 04:31 | #2474 | Link | |
You are on Win 7, aren't you? On Win 10 the buttons in the title bar are bigger!
https://drive.google.com/open?id=0B-...ld4dzhuTC1WWWM https://1drv.ms/f/s!ArwKS_ZUR01goCzIRemxotXY_zz- 1.6.1.2 unstable test build
3rd September 2017, 05:33 | #2475 | Link |
Many custom scripts use filters included in Staxrip. If the filter isn't called in Staxrip the filter isn't loaded unless it is located in the Avisynth plugins64 folder or the person loads it manually.
Is it possible to add a loadplugin feature like currently when adding filled? All loaded plugins can be added to the same filter box segment at the top?... |
3rd September 2017, 06:06 | #2476 | Link |
I didn't understand the second part. When a avsi file is imported staxrip could scan it to find out which plugins it uses, that should be better then how it currently works.
4th September 2017, 05:44 | #2477 | Link |
Please test.
Requirements .NET 4.7 is required on systems prior Windows 10 Version 1703 (Creators Update) https://www.microsoft.com/en-us/down....aspx?id=55170 Download https://drive.google.com/open?id=0B-...ld4dzhuTC1WWWM https://1drv.ms/f/s!ArwKS_ZUR01goCzIRemxotXY_zz- 1.6.1.3 unstable test build
5th September 2017, 17:23 | #2478 | Link | |
https://drive.google.com/drive/folde...GZ5dE5lSE5mYVk
Win 10 x64 (19042.572) - Core i5-2400 - Radeon RX 470 (20.10.1) HEVC decoding benchmarks H.264 DXVA Benchmarks for all |
5th September 2017, 22:37 | #2479 | Link |
Thanks, I've updated it.
7th September 2017, 16:51 | #2480 | Link |
Noob
in smdegrain, set contrasharp=true and contrasharp=100 without using lsfmod (earlier without lsfmod it gave stupid errors) and didnt get errors in both the cases, currently doing a small encode with contrasharp=true.
lsb = true is giving error called "dither_lut8" though and where to find mclean option? Last edited by Natty; 7th September 2017 at 16:54. |
