Old 14th February 2013, 02:09   #61  |  Link
SAPikachu
SAPikachu's Avatar
I can't really handle it in my code (except for forcibly terminating the slave process itself on exit, but I don't want to do that since some plugin can't properly clean up in that case). Maybe you can try another version of QuickTime, or just use ffms2?
f3kdb 1.5.1 / MP_Pipeline 0.18
ffms2 builds with 10bit output hack:
libav-9a60b1f / ffmpeg-1e4d049 / FFmbc-0.7.1
Built from ffms2 6e0d654 (hack a9fe004)
Mirrors: http://bit.ly/19TwDD3
SAPikachu is offline   Reply With Quote
Old 14th February 2013, 11:39   #62  |  Link
kolak
Already tried some other ProRes decoder, will try older QT, but for now ffvideo is the only one solution (I don't like it that much- bit unpredictable also)
Old 20th May 2013, 23:23   #63  |  Link
aldix
Hello,
latest adopter of MP_Pipeline here.
As I was suggested, I copied all the x86 files into avs plugins directory (using SET's 2.6 MT), then made the following script:
MP_Pipeline("""
f3kdb(sample_mode=2,dynamic_grain=false,keep_tv_range=false,dither_algo=3,y=48,cb=24,cr=24,grainY=48,grainC=24)
BlindDehalo3(rx=2.5, ry=2.5, strength=125)
### lock threads to cores
But for the life of me, I can't get it to work. All it gives me is this error msg:
MP_Pipeline: Unable to create slave process. Message: Script Error: Script Error: Invalid arguments to function 'f3kdb'
But everything works when I remove MP stuff. What am I doing wrong?
Thanks!
aldix is offline   Reply With Quote
Old 21st May 2013, 01:08   #64  |  Link
SAPikachu
SAPikachu's Avatar
Originally Posted by aldix View Post
Hello,
MP_Pipeline("""
Thanks!
Did you put your source filter before MP_Pipeline? MPP can't use video source from the outside, so you need to put all source filter inside it. Like this:
MP_Pipeline("""
FFVideoSource("abcde.mkv")
# By the way, you need to put another block splitter here,
# because all special statement won't be effective for code
# after the last splitter.
Old 21st May 2013, 01:58   #65  |  Link
aldix
Yup, figured out the source filter bit meanwhile.
But now it's saying that there's no function named BlindDehalo3 even if I'd call it explicitly via import after source filter.
Interestingly, f3kdb now works, though.
Thanks a lot for the reply btw, not only directly from the author him/herself, but so promptly indeed
Old 21st May 2013, 02:09   #66  |  Link
SAPikachu
SAPikachu's Avatar
Manually-loaded plugins and imported scripts need to be reloaded/re-imported before they can be used in new process. (Or use inherited script snippet, please see MP_Pipeline_readme.avs for details)
Actually, it will be much easier to put all plugins/imported scripts into your avisynth plugins folder, so that they will be loaded automatically.
Old 21st May 2013, 23:00   #67  |  Link
aldix
Well, they all are in the plugins folder, but I still have to load them manually...
I don't know what to say. Even if I wrap the MP_Pipeline around all the script, with breaks (### ###) between parts,
I still get the same msg about invalid arguments.
For instance, let's take this one:
import("c:\program files (x86)\avisynth 2.5\plugins\gradfun2dbmod.avs")
import("c:\program files (x86)\avisynth 2.5\plugins\ylevels.avs")
import("C:\Program Files (x86)\AviSynth 2.5\plugins\ContraSharpen.avs")
import("c:\program files (x86)\avisynth 2.5\plugins\lsfmod1.9.avs")
import("c:\program files (x86)\avisynth 2.5\plugins\sbr.avs")
import("c:\program files (x86)\avisynth 2.5\plugins\dfttestmc.avs")
import("c:\program files (x86)\avisynth 2.5\plugins\HQDering.avs")
import("c:\program files (x86)\avisynth 2.5\plugins\BlindDeHalo3_mt2.avs")
import("c:\program files (x86)\avisynth 2.5\plugins\Minblur.avs")
source = last
blksize = 16
overlap = blksize/2
hpad = blksize
vpad = blksize
thSAD = 300
halfblksize = blksize/2
halfoverlap = overlap/2
halfthSAD = thSAD/2
chroma = true
search = 5
preNR = source.degrainmedian(mode=3,limity=8,limituv=10).fft3dfilter(wintype=1,degrid=1,bw=32,bh=32,ow=16,oh=16,bt=3,sigma=2.5,sigma2=2.2,sigma3=1.8,sigma4=0.5,plane=4,ncpu=1).GradFun2DB(1.01)
preNR = source.degrainmedian(mode=3,limity=8,limituv=10).dfttest(sigma=6, ftype=1, tbsize=1, threads=1).GradFun2DB(1.01)
preNR_super = preNR.MSuper(hpad=hpad, vpad=vpad, pel=2, sharp=2, rfilter=2, chroma=chroma)
source_super = source.MSuper(hpad=hpad, vpad=vpad, pel=2, sharp=2, chroma=chroma, levels=1)
Recalculate = preNR.MSuper(hpad=hpad, vpad=vpad, pel=2, sharp=2, rfilter=2, chroma=chroma, levels=1)
vb2 = MAnalyse(preNR_super, isb=true, truemotion=false, delta=2, blksize=blksize, overlap=overlap, search=search, chroma=chroma)
vbr2 = MRecalculate(Recalculate, vb2, overlap=halfoverlap, blksize=halfblksize, thSAD=halfthSAD, search=search, chroma=chroma)
vb1 = MAnalyse(preNR_super, isb=true, truemotion=false, delta=1, blksize=blksize, overlap=overlap, search=search, chroma=chroma)
vbr1 = MRecalculate(Recalculate, vb1, overlap=halfoverlap, blksize=halfblksize, thSAD=halfthSAD, search=search, chroma=chroma)
vf1 = MAnalyse(preNR_super,isb=false, truemotion=false, delta=1, blksize=blksize, overlap=overlap, search=search, chroma=chroma)
vfr1 = MRecalculate(Recalculate, vf1, overlap=halfoverlap, blksize=halfblksize, thSAD=halfthSAD, search=search, chroma=chroma)
vf2 = MAnalyse(preNR_super,isb=false, truemotion=false, delta=1, blksize=blksize, overlap=overlap, search=search, chroma=chroma)
vfr2 = MRecalculate(Recalculate, vf2, overlap=halfoverlap, blksize=halfblksize, thSAD=halfthSAD, search=search, chroma=chroma)
maskp1 = MMask(vfr1, kind=1, ysc=255).UtoY()
maskp2 = MMask(vfr2, kind=1).UtoY()
maskp3 = MMask(vbr1, kind=1, ysc=255).UtoY()
maskp4 = MMask(vbr2, kind=1).UtoY()
tmask = average(maskp1, 0.25, maskp2, 0.25, maskp3, 0.25, maskp4, 0.25).spline36resize(source.width, source.height)
source2 = mt_merge(source,preNR,tmask,Y=3,U=3,V=3)
KEEP = "0.23"
den = source2.MDegrain2(source_super,vbr1,vfr1,vbr2,vfr2,thSAD=thSAD,thSCD1=256,thSCD2=92)
\.mt_adddiff(mt_makediff(source,preNR,U=3,V=3).mt_lut("x 128 - abs 1 < x x 128 - abs 1 - "+KEEP+" * x 128 - x 128 - abs 0.001 + / * 128 + ?",U=2,V=2),U=3,V=3)
# PROTECTING
threshold = 16
cutoff = 64
maxdiff = 4
rg17 = den.removegrain(17,-1)
iOB = source.mt_lut("x "+string(cutoff)+" >= x 0 ?",U=1,V=1)
mB = mt_makediff(iOB,rg17,U=1,V=1).mt_binarize(128+threshold,upper=false,U=1,V=1).removegrain(5,-1)
lB = mt_lutxy(den,source,"x y - abs "+string(maxdiff)+" <= x x y - 0 < y "+string(maxdiff)+" - x ? ?",U=1,V=1)
smB = mt_merge(den,lB,mB,U=2,V=2)
# EDGECLEANING
mP = mt_edge(smB,"prewitt",0,255,0,0,V=1,U=1)
mS = mP.mt_expand(mode=mt_square(radius=2),U=1,V=1).mt_inflate(U=1,V=1)
mD = mt_lutxy(mS,mP.mt_inflate(U=1,V=1),"x y - "+string(32)+" <= 0 x y - ?",U=1,V=1).mt_inflate(U=1,V=1).removegrain(20,-1)
smE = mt_merge(smB,Eval("smB." + "Removegrain(2,0)"),mD,luma=true,U=3,V=3)
# MASKING
mE = mt_edge(smE,"prewitt",0,255,0,0,V=1,U=1).mt_lut(expr="x 1.8 ^",U=1,V=1).removegrain(4,-1).mt_inflate(U=1,V=1)
mL = mt_logic(tmask.invert(),mE,"min",U=1,V=1).removegrain(20,-1)
mF = mt_logic(tmask,mE,"max",U=1,V=1).removegrain(20,-1)
# SHARPENING
b1c = source.MCompensate(source_super,vb1)
f1c = source.MCompensate(source_super,vf1)
#Sclp = smE.LSFmod(defaults="slow", preblur="ON", strength=100)
Sclp = ContraSharpen(smE,source)
Tmax = source.mt_logic(f1c,"max",U=1,V=1).mt_logic(b1c,"max",U=1,V=1)
Tmin = source.mt_logic(f1c,"min",U=1,V=1).mt_logic(b1c,"min",U=1,V=1)
shrp = Sclp.mt_clamp(Tmax, Tmin, 2, 2, U=1, V=1)
sL = mt_merge(smE,shrp,mL,U=2,V=2)
# ENHANCING
#GFc = sL.f3kdb(sample_mode=2,precision_mode=3)
GFc = sL.GradFun2DBmod(thr=1.4,thrC=1.8,mode=2,str=0.8,strC=0.0,temp=50,adapt=64)
Frs = mt_merge(GFc,sL,mF,luma=true,U=3,V=3).BlindDehalo3(rx=1.25, ry=1.25, strength=90, sharpness=1, ppmode=2)
Frs#.mergechroma(den)
YlevelsS(0,1.0,255,0,255,false)
In the above script, if I'd wrap MP_Pipeline around it (before imports and after ylevels), breaks on diff parts of the script,
it comes back with "invalid arguments" on degrainmedian.
I don't know what else to try. I'm sure it's something minor I'm missing as usual.
Old 21st May 2013, 23:20   #68  |  Link
real.finder
the .avs is not auto load, change it to .avsi for each Script
Old 22nd May 2013, 00:09   #69  |  Link
aldix
Excellent information, real.finder! Greatly obliged. Learn something new every day
But this still doesn't change my primary concern - invalid arguments.
Old 22nd May 2013, 00:47   #70  |  Link
real.finder
put the full script (with MP_Pipeline) to see what the problem
Old 22nd May 2013, 16:22   #71  |  Link
aldix
Apologies for late reply, too busy.
It's basically just the script above, with MP stuff inserted. Anyway, however I place the MP calls, it comes back with some filter having 'invalid arguments'.
MP_Pipeline("""
MPEG2Source("C:\Users\redacted\smileys people ep3\VTS_02_1.d2v", cpu=0)
Crop(2, 0, -2, -0)
source = last
blksize = 16
overlap = blksize/2
hpad = blksize
vpad = blksize
thSAD = 300
halfthSAD = thSAD/2
chroma = true
search = 5
KEEP = "0.23"
# PROTECTING
threshold = 16
cutoff = 64
maxdiff = 4
# EDGECLEANING
# MASKING
# SHARPENING
# ENHANCING
edit: Sorry, forgot to add source filter at first, fixed.
Old 22nd May 2013, 16:35   #72  |  Link
real.finder
what is the source and video source filter?
I don't see one in your script
Old 23rd May 2013, 07:21   #73  |  Link
SAPikachu
SAPikachu's Avatar
Variables won't be automatically transferred to next script block. For clip variables you need "### export clip" to use it in next block, for others you need "### inherit". Please see the example script in the package for details, because I am on vacation now, I can't provide another example for you.
Old 23rd May 2013, 16:48   #74  |  Link
aldix
MP_Pipeline("""
MPEG2Source("C:\VTS_02_1.d2v", cpu=0)
Crop(2, 0, -2, -0)
### export clip: source,overlap,blksize,hpad,vpad,thSAD,halfblksize,halfoverlap,halfthSAD,chroma,search
source=last
blksize = 16
overlap = blksize/2
hpad = blksize
vpad = blksize
thSAD = 300
halfthSAD = thSAD/2
chroma = true
search = 5
Now I'm getting 'Unable to create slave process ... Invalid arguments to function 'MPP_PrepareDownStreamClip'.
I really, really appreciate all the help You've given so far SAPIkachu, I just can't seem to wrap my head around it,
scarce script example isn't much use to me, I'm afraid.
Thank You again.
Old 24th May 2013, 01:18   #75  |  Link
SAPikachu
SAPikachu's Avatar
Actually, you should use "export clip" like this:
source = ...
Edit: I was wrong about what error the script have. See my new post below. Sorry.
Old 24th May 2013, 15:11   #76  |  Link
aldix
source = ...
Well, for this I followed the example script/tutorial. There it was said to list 'em separated by commas.
And regardless, now it whines for other variables, like hpad.
I don't know. Perhaps I just shouldn't try to use it or something.
Old 24th May 2013, 18:18   #77  |  Link
real.finder
you can use the mp_pipleline without split by now, until you learn all its settings
like:
MP_Pipeline("""
### platform: win32
SetMemoryMax(1500)
Crop(2, 0, -2, -0)
source = last
blksize = 16
overlap = blksize/2
hpad = blksize
vpad = blksize
thSAD = 300
halfthSAD = thSAD/2
chroma = true
search = 5
KEEP = "0.23"
# PROTECTING
threshold = 16
cutoff = 64
maxdiff = 4
# EDGECLEANING
# MASKING
# SHARPENING
# ENHANCING
### prefetch: 16, 12
AssumeFrameBased
as I say here http://forum.doom9.org/showthread.php?p=1629295#post1629295
Old 25th May 2013, 01:03   #78  |  Link
aldix
Well, thanks for this. Now I got it to work and going through the frames in AvspMod is very fast. However, encoding in x264 (with Simple Launcher GUI) first
hangs with 'potential deadlock', then nonetheless starts but very slowly and without using 100% cpu. Just sits at 40-50%. Memory meanwhile is 70%+.
What's up with that?
I did some investigating on my own and discovered that by removing 'lock threads to cores' statement I can get some speed back - 0,5fps and about 10% cpu load,
but that's it.
At least I'm glad that there was some little thing I missed and everything works for me. It's just not what I expected...
Old 25th May 2013, 02:45   #79  |  Link
SAPikachu
SAPikachu's Avatar
Sorry I misread your script. Your syntax was right, but ### export clip only works for clip variables. For other variables, you need to use ### inherit start / ### inherit end. (Or just copy all the variables to all script blocks)
"lock threads to cores" is an advanced function, don't use it unless you really know how it works. Actually nearly no one told me that it is useful.
Old 25th May 2013, 04:49   #80  |  Link
aldix
Well, I don't know what to tell you guys. I've tried both with and without ### inherit start/end wrapping the variables, and with lowering/rising the setMemoryMax.
I'm only getting ~1 fps on a crf encode (once it finally starts to encode after the deadlock msg) on a script that used to give 1.6 fps with just a single
SetMTMode(2)/SetMemoryMax(640) pair inserted in the middle. Now that doesn't work (x264 deadlocks eventually and cpu load doesn't achieve 100%)
and this pipeline doesn't appear to increase any speed at all.
If such set-up is just to make big scripts run with less load on cpu (haven't yet seen cpu at 100% with this) while increasing the memory load, it's fine. Currently I just need to script to run, period, don't really
care how long it takes. But I was getting giddy under the (false?) impression that this set-up actually speeds things along? Was I wrong or still doing something incorrectly?
I really, really appreciate all the replies and help. It's just frustrating.
avisynth, multi-process, pipeline
