Old 17th February 2010, 23:38   #1  |  Link
davidvsmp4
Generate MP4 header
Hello. I'm working on video converting script. What I'm trying to achieve is ability to start downloading converted MP4 video (x264+aac) before converting is complete.
However when I try to redirect output of ffmeg or mencoder to STDOUT I got "muxer doesn't support non seekable output".
So the question is: how to generate MP4 header knowing source video properties (duration, number of frames, dimensions, etc)? What tools can be used to create such a header and append converted streams to it?
davidvsmp4 is offline   Reply With Quote
Old 17th February 2010, 23:53   #2  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
You can't do that. The header includes an index, which cannot be written until the rest of the file is written.
Old 18th February 2010, 17:25   #3  |  Link
davidvsmp4
Thanks for the answer. Please excuse my lack of knowledge but is it possible to generate index in advance? I mean *if resulted video will have the same number of frames as source one, same frame rate, and I-frame will be every N-th frame (no B-frames)?
Old 18th February 2010, 17:47   #4  |  Link
Dark Shikari
x264 developer
No, because the purpose of the index is to list the size of every frame and its position in the file.
aac, mp4, x264
