25th September 2009, 11:33 | #8104 | Link | |
for ex. I've also managed to register ArcSofts Video decoder. It behaves strangely though, cant set fps of get it to connect to VC-1 streams. I think all AS filters have a direct link to the renderer/software, and that all settings are controlled via that way. If the behaviour of the video-decoder is any indication on how the audio-filters behave .... But EAC3TO can conect to AS HD audio-filter and can get its bit-perfect decoded audio through it. But i think it is AS' software/renderer that is the only thing that can set HDMI-passtrough. Last edited by G_M_C; 25th September 2009 at 11:52. |
25th September 2009, 11:35 | #8105 | Link | |
MPC-BE DEV
NOTES You must have a valid license for the Intel® Compiler Professional Edition or Intel® C++ Compiler Suite Professional Edition to install and use this product. For mixed language applications built with the /Qipo option, we recommend using the Intel® Visual Fortran Compiler Professional Edition for Windows*, Version 11.1.046, package id w_cprof_p_11.1.046. Intel Integrated Performance Primitives (Intel IPP) in Intel C++ Compiler Professional Edition for Windows* offers extensive sample code for application usage in Multimedia (Image, Audio, Video and Speech), Image/Signal Processing, Data Communication , multi-programming language support and more. Sample code and download information can be found at the Intel IPP Sample page. For a list of defects fixed in this product version, please see http://software.intel.com/en-us/arti...11-fixes-list/. Important note: Title: Errata Reference Number DPD200139120 Problem: Applications built with the Intel® C++ and Visual Fortran Compilers Professional Edition, version 11.1 may hang or encounter a segmentation-fault when run on Microsoft* Windows 7* or Windows Server 2008* R2. Also, a similar issue may occur during installation of these compiler versions on these operating system versions. Version: Intel® C++ & Visual Fortran Compilers for Windows* 11.1 initial release and update 1 release: Intel® C++ & Visual Fortran Compiler for Windows* 11.1.035 Intel® C++ & Visual Fortran Compiler for Windows* 11.1.038 Previous versions of the Intel® Compilers (version 11.0 or earlier) do not have this issue. Please refer to the corresponding Release Notes for additional information on minimum system requirements for which operating systems are supported by that product version. For applications built with the Intel Compilers version 11.1, the problem is contained within the libirc.lib, libircmt.lib on Windows.
Win11 x64, i7 8700K 5Ghz, ASUS MAXIMUS X HERO, G.Skill (2x8GB) Trident Z F4-3600C16D-16GTZ, RX 5700,TV Philips 43PUS6703/12, Zappiti 4K HDR Media Player Classic - BE x86/x64. Team of developers. Last edited by alexins; 25th September 2009 at 11:42. |
25th September 2009, 16:02 | #8106 | Link | |
25th September 2009, 16:45 | #8107 | Link |
Thanks for letting me know. So maybe this will fix the problem Mercury_22 had since with ICL 11.0.072 everything was fine. Can you build an ICL version with 11.1.046? Because I'm on a slow connection and it will take me a while to download the new ICL.
25th September 2009, 18:14 | #8108 | Link | |
Media Control author
AFAIK Masdhi uses ffmpeg decoders and holds its own parsers but he won't use directshow for that Maybe arcsoft decoders have security checks : they may check the executable of the player, the input source filters... Or maybe they won't accept the media types that are pushed in I know that Arcsoft defined its own mediaguids for DTSHD and TrueHD, so this may be the cause (the source filter/splitter). Also are you able to use arcsoft source filters/splitters, connect it to arcsoft decoder and then to arcsoft renderer(s) ? @Nicholi or anyone Can someone post a link to a vorbis 6channels in order to fix this bug Extract from ffdshow sources : DEFINE_GUID(MEDIASUBTYPE_ARCSOFT_MLP ,0x4288b843, 0x610b, 0x4e15, 0xa5, 0x3b, 0x43, 0x00, 0x7f, 0xcf, 0xf6, 0x14); DEFINE_GUID(MEDIASUBTYPE_ARCSOFT_DDPLUS ,0x71cfa727, 0x37e4, 0x404a, 0xae, 0xc0, 0x34, 0x84, 0x25, 0x32, 0xef, 0xf7); DEFINE_GUID(MEDIASUBTYPE_ARCSOFT_DTSHD ,0xf6498f57, 0xb399, 0x4a43, 0xa6, 0xfa, 0xf6, 0x94, 0xad, 0x42, 0xb9, 0xbe); Last edited by albain; 25th September 2009 at 18:18. |
25th September 2009, 18:23 | #8109 | Link |
Here is a test file:
sample
MPC-HC 2.2.1 |
25th September 2009, 20:22 | #8110 | Link | |
4:2:0 hater
ICL 11.1.046 build: http://www.megaupload.com/?d=IEN5TTCS Last edited by STaRGaZeR; 25th September 2009 at 20:26. |
25th September 2009, 21:19 | #8111 | Link | |
I'll throw my Xonar back in and try again but G_A_W is using the new 5xxx GPU which bitstreams with PowerDVD 9, not TMT. It might also be easier to find out the media types being used by PowerDVD 9. Last edited by whurlston; 25th September 2009 at 21:22. |
25th September 2009, 22:27 | #8112 | Link | |
I'm talking about the problem Mercury_22 and BatKnight had with regsvr32 hanging while installing. ffdshow rev3088 |
25th September 2009, 22:44 | #8113 | Link |
Disabling an optimization should be safe.
MPC-HC 2.2.1 |
25th September 2009, 23:26 | #8115 | Link | |
Intel UHD Graphics 750; Win 10 22H2 |
26th September 2009, 00:26 | #8117 | Link | |
Bat
Win 11 x64, Geforce RTX 4060 Ti 16GB, TV Sony KD-55X8509C HDMI, Denon AVR-X2700H, Core i7-9700K, 32GB DDR4, Creative Labs Gigaworks S750 7.1 speakers MPC Home-Cinema madVR LAV Filters |
26th September 2009, 08:32 | #8118 | Link | |
You can extract the GUID mediatypes by disassembling with IDA pro but it is not trivial, I will try it About new radeons, things are different because we can ask AMD about the implementation, this is no more corporate agreements such as asus+arcsoft, or cyberlink+azuentech |
26th September 2009, 09:22 | #8119 | Link | ||
As of the P57 chipset and their next chips (Clarkdale/Arrandale) Intel will provide streaming HD audio too. See Anandtech's article on this; Direct link to page 8 of the article where this is confirmed. Quote:
