12th September 2004, 16:39 | #2781 | Link |
I'm afraid we've to stop
1.57 is up
I was reading the code while implementing FDecimate() support and found several inconsistencies in handling of different FPS, so very probably I fixed quite a few bugs that nobody noticed recently Downside may be that I might have introduced new ones - so please stress test it!
Gordian Knot Family: Gordian Knot: website, download Auto Gordian Knot: Website and download, tutorial, FAQ |
12th September 2004, 16:52 | #2782 | Link | |
Re: problem with 720p transport streams
12th September 2004, 22:52 | #2783 | Link | |
Re: Re: problem with 720p transport streams
Once he's done testing it, He'll post it on the AutoGK download site (I'm assuming). Changelog follows: -------------------------- V-0.8 (September 12, 2004) -------------------------- - Added 'Force Deinterlacing' when source was detected as hybrid (merged this option with 'Force Normal IVTC', since you can only use one or the other, not both - Added Transport Stream Video and Audio PID specifiers. - Added Audio ID speficier for File Mode when stream info wasn't processed. - Added 'Force Sharp MPEG Matrix' override - Added 'HDTV Frame Rate Reduction' (Reduces FPS for 60/50fps HDTV progressive sources using FDecimate filter. Analysis step will not be run if this option is used). - Added tooltips for help on most options - hover over the option titles and input boxes or controls where appropriate. ***NOTE***: I did NOT add support for the following 3 options, because they need to reside in the AutoGK home directory, and since I can't be 100% sure that this wasn't modified by the user during install, you'll have to create them yourselves (they are probably not very frequently used anyway): -.kerneldeint - Tune KernelDeInt filter threshold. This file has to be in AutoGK home dir unlike all others! -.itu - for ITU resize method (same option as in full Gordian Knot). This file has to be in AutoGK home dir unlike all others! -.debug - display VCF scripts for VDubMod in the logs. This file has to be in AutoGK home dir unlike all others!
Cheers, The REAL Joe |
13th September 2004, 05:49 | #2784 | Link | |
lazyn00b |
13th September 2004, 10:54 | #2785 | Link | ||
Re: Re: Re: problem with 720p transport streams
14th September 2004, 01:38 | #2786 | Link | |
Re: Re: Re: Re: problem with 720p transport streams
14th September 2004, 10:07 | #2787 | Link | |
Mad Scientist
tsrename.bat and mp2 audio
Hello, Len0x.
I have a question/request: Is there any way of selecting the original mp2 audio (my .ts sources all come with MPEG-1 Layer 2 audio) instead of transcoding it to mp3? My choice would be to have the original mp2 audio if it's not more than 128 kbps and transcode it if its bitrate is higher (same choice for second audio). Does AutoGK do anything similar (maybe auto audio with >700MB AVIs)? Would it be possible to do it if not? Regards, |
14th September 2004, 10:32 | #2788 | Link | |
Re: tsrename.bat and mp2 audio
14th September 2004, 12:28 | #2789 | Link | |
Mad Scientist
Re: Re: tsrename.bat and mp2 audio
Hi, again.
About the standalone compatibility, I can try my next encode with mp2 and a Kiss DP-1000 if you want. Now that I think about it, a hidden option to choose the .mpa file instead of the .mp3 one if the .mpa is smaller in size would also serve my purpose. Regards, |
14th September 2004, 15:22 | #2790 | Link | |
Re: Re: Re: tsrename.bat and mp2 audio
14th September 2004, 19:00 | #2791 | Link | |
hidden options help
so in your VB application, instead of using app.path use some windows API to check the registry in the correct location (which btw u will have to ask len0x or find it yourself (shouldnt be hard) and create the file or files in that location or in a subfolder. im sure that will make it much less prone to problems rather than using app.path cause some people MAY not run it from the autoGK directory, i myself ran it from the rar file, and that just wont work very well.... tho if i wanted to use the shortcut cntr F9 or whatever it was, then indeed it would have to be in the autoGK folder if ya need help with the registry thing, im sure u can find an example somewhere on the net www.planetsourcecode.com is just one source if u must have an example. |
14th September 2004, 21:33 | #2792 | Link | |
Mad Scientist
Re: Re: Re: Re: tsrename.bat and mp2 audio
As I saw that the "Audio: Auto" option keeps the original AC3 when the AVI is >700MB, I though the "natural" behaviour would be to keep the original audio track of the .ts files when possible/reasonable. I've found some audio tracks with low bitrates that when transcoded to mp3 have a metallic sound that I don't really like. But as one of the byproducts of AutoGK are the .mpa tracks, I'll just check the audio and swap the tracks if necessary. It's just an aditional run through VDubMod (which I'm already doing to add the language tags). Regards, |
14th September 2004, 23:57 | #2793 | Link |
While googling I stumbled over this thread :
http://forums.divx.com/viewtopic.php...60462&forum=21 It points out that some hardware players do not support the .sub + .idx format of external subtitles - They need .srt subtitles instead. If this is true then I think AutoGK needs to be able to outout .srt subtitles. Do you agree ? |
15th September 2004, 08:17 | #2794 | Link | |
Mad Scientist
Hello there,
That doesn't mean that you can't have srt subtitles. When I want text subtitles I open the sub/idx with SubRip, and OCR the subtitles. A quick review with the dictionary of a word processor and voilá! Regards, |
15th September 2004, 17:46 | #2795 | Link |
Pain and suffering
I am trying to encode a DVDr with DTS audio only, autogk will not allow me to add a job, i could find nothing of DTS in the FAQ.
When i select no audio track it does allow me to encode ( ) Anything i can do about this? |
15th September 2004, 17:49 | #2796 | Link | |
15th September 2004, 18:03 | #2797 | Link | |
Pain and suffering
But i guess a DTS tool cant work with autogk. You got any tips for me? how i maybe can encode this dvdr afterall? This is a chinese movie with jet li, chinese DTS audio only. english subs and chinese subs (wide/letterbox). autogk says: Chinese DTS 6ch If i encode video with autogk, and make my own DTS > vbr mp3 audio file, you think it would be in sync when i use nandub? If not, time to buy a DTS player |
15th September 2004, 18:12 | #2798 | Link | ||
There are no free DTS decoders available. Quote:
16th September 2004, 19:17 | #2799 | Link | |
I can't figure out how to use SubRip with sub/idx though .. I found that SubResync that comes with AutoGK does a fine job .. I also wonder if SubMux that also comes with it is able to insert the subtitles into the avi-container as a textstream. BTW .. if you do sub/idx -> srt after AutoGK have made the sub/idx wont you loose a little moviequality because AutoGK will have reserved space on the CD for the subtitles .. space that is now wasted ? (because srt's are so tiny) It might be better to choose no subtitles in AutoGK and have another tool make the subtitles .. Maybe have Subrip make them from the decrypted vob's. |
16th September 2004, 20:21 | #2800 | Link | ||
Mad Scientist
Regards, Last edited by ydobon; 17th September 2004 at 11:45. |
