Old 1st March 2012, 16:18   #1  |  Link
cb2000
directshow Bluray disc navigator filter base on libbluray
I have work on "dslibbluray", my directshow Bluray disc navigator filter for several monthes.
Although it is still in very early state, I still post a test build here for maybe someone would like to try it.
http://sourceforge.net/projects/dslibbluray/files/
cb2000 is offline   Reply With Quote
Old 1st March 2012, 16:49   #2  |  Link
dukey
Nice work cb2000. What interfaces are planned so we can use this filter ? And why have you made a custom EVR mixer ?
dukey is offline   Reply With Quote
Old 1st March 2012, 17:14   #3  |  Link
Mercury_22
With the last version (test0301) many BD are working but there are also a lot of crashing or simply not starting
The most frequent crashes are happening with this two messages
1.
Could not find helper library for argument -Xrunjdwp:transport=dt_socket,server=
n,address=8888
Cannot start VM (error handling -Xrun argument -Xrunjdwp:transport=dt_socket,ser
ver=n,address=8888)
java.lang.UnsatisfiedLinkError: no jdwp.dll in sun.boot.library.path
        at java.lang.ClassLoader.loadLibraryInternal(Compiled Method)(ClassLoade
r.java:1645)
f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\bdj\bdj.c:171: Failed t
o create new Java VM.
2.
f:\work\bluray\dslibbluray\trunk\libbluray\src\libbluray\decoders\graphics_contr
oller.c:818:    auto-activate #0 not triggered (!cmds)
oller.c:818:    auto-activate #4 not triggered (!cmds)
oller.c:818:    auto-activate #16 not triggered (!cmds)
oller.c:818:    auto-activate #17 not triggered (!cmds)
The first message it's followed by the previous reported error when trying to close Demo_Player
before crashing
Also the problem with the selection in some menus
Originally Posted by Mercury_22 View Post
4. In some menus I can't see where is the selection: e.g when changing from PLAY to Languages I can't see when Language is selected although pressing enter it's showing the available languages
P.S. a small suggestion, if I may, find a way (to get rid of the Win7DSFilterTweaker) so we don't need to "Tweaker" the decoders cause most of us don't want to mess up our systems and in VM things are very slow
But, again this is a great start
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 1st March 2012, 17:43   #4  |  Link
cb2000
the bdj graphic output is ARGB, the EVR can't mix it with video.
VMR9 support ARGB, but I have waste about one month to try to work with VMR9, but failed.
So I spend another one month to write a custom EVR mixer. It is working but also some feature not implement.
Old 1st March 2012, 17:47   #5  |  Link
cb2000
1.[CODE]Could not find helper library for argument -Xrunjdwp:transport=dt_socket,server=
n,address=8888
sorry for missing java debug dll, provided in test0302.zip, lazy to compiled a none debug version.
Old 1st March 2012, 17:52   #6  |  Link
dukey
Yeah I discovered this limitation myself with EVR. VRM9 can do it.
However AYUV should work when sending to EVR, I don't see why you need to make a custom mixer, it doesn't make a lot of sense. If I want to implement this in my own program I need to use your custom mixer?
Just do your ARGB->AYUV conversion in the filter itself, and send the substream to the 2nd EVR pin. I've been working on something similar myself for rendering subtitles on other pins.
Old 1st March 2012, 17:59   #7  |  Link
Mercury_22
Now I'm getting this
ERROR: transport error 202: connect failed: Connection refused
ERROR: JDWP Transport dt_socket failed to initialize, TRANSPORT_INIT(510)
800
200
205
207
1004
800
java.lang.Error: Not implemented
        at org.havi.ui.event.HRcCapabilities.getRepresentation(Compiled Method)(
HRcCapabilities.java:25)
        at a.a.g.b.c(Compiled Method)(Unknown Source)
        at a.a.g.b.<init>(Compiled Method)(Unknown Source)
        at a.a.b.at.<init>(Compiled Method)(Unknown Source)
        at a.a.b.v.a(Compiled Method)(Unknown Source)
        at a.a.c.a.c(Compiled Method)(Unknown Source)
        at netblender.DoXlet.startXlet(Compiled Method)(Unknown Source)
        at org.videolan.BDJAppProxy.doStart(Compiled Method)(BDJAppProxy.java:17
0)
        at org.videolan.BDJAppProxy.run(Compiled Method)(BDJAppProxy.java:279)
        at java.lang.Thread.run(Compiled Method)(Thread.java:714)
        at java.lang.Thread.startup(Compiled Method)(Thread.java:785)
Old 1st March 2012, 18:00   #8  |  Link
cb2000
Unfortunately, many video card don't support AYUV also including mine (onboad ati 4250). It only support IA44 and AI44.
also a custom EVR mixer may support PIP feature. both EVR and VMR9 can't do it well.
Old 1st March 2012, 18:03   #9  |  Link
cb2000
800
200
205
207
1004
800
0)
many BD-Java feature is not implement yet, sorry.
Old 1st March 2012, 18:08   #10  |  Link
dukey
Yeah that may well be true. My subtitle renderer only uses AI44, not even tried AYUV yet. Would be good to know what gfx cards support it, and what don't.
I suppose using a custom EVR mixer for this wouldn't be a deal breaker at all.
Old 1st March 2012, 18:09   #11  |  Link
Mercury_22
No problem I can wait
I don't know if it helps but I'm getting this when trying to debug one crash which happens after selecting start in the BD menu and pressing enter
Call Stac bluray.dll!6c20dc9b()
6C20DC9B  mov         eax,dword ptr [edx+3Ch]
Old 1st March 2012, 18:17   #12  |  Link
nevcairiel
If its limited to one special custom EVR, i might as well stick to a commercial player.
IMHO the right approach would be to define an interface which is used to communicate the overlays, and then let other renderers implement that if they want to.
If you already spend alot of time on this, might as well do it right, otherwise it'll still be as limited as the commercial players are.
Writing Blu-ray support is easy, doing it the full flexible DirectShow way we all like so much, is hard.
Old 1st March 2012, 18:37   #13  |  Link
dukey
I don't see it being such an issue. Would just be like using any other filter. If you had to use a custom presenter, that would be quite different. The alternative is, to just not bother with graphics cards that lack support for AYUV, which ever ones they are.
And if you want to spend 100 dollars on powerdvd Nothing stopping you lol.
Old 1st March 2012, 19:38   #14  |  Link
Asmodian
I like using MadVR as it has support for calibration (yCMS). I don't know if Madishi would be willing to impliment an interface used to communicate the overlays but that does sound cool!
Old 2nd March 2012, 03:24   #15  |  Link
cb2000
For any renderer that support mixing following streams can be used with dslibbluray, no limitted.
1. two yuv video stream, either maybe difference start time, duration, frame rate, fame size, interlaced or not;
2. ARGB/AYUV substream (current it only use ARGB, but it is easy to coverrt to AYUV by software), and each sample only has start time but no stop time;
3.eatch stream may occor or disappear at any time
Unfortunately, no one now. So I had write a custom EVR mixer because it is some easy than write a new renderer from scratch.
Old 2nd March 2012, 03:36   #16  |  Link
cb2000
Anyone will suggest an BD with HDMV animate button that I can download for debugging?
Maybe "Mercury_22: 4. In some menus I can't see where is the selection:" one of bug of animate button
Old 2nd March 2012, 04:29   #17  |  Link
Inspector.Gadget
I can't use this at the moment, but I wanted to thank you, cb2000, for your hard work and dedication to improving the state of BD playback outside of proprietary applications.
Inspector.Gadget is offline   Reply With Quote
Old 2nd March 2012, 08:01   #18  |  Link
Mercury_22
EDIT: Use this Test_Animated_Button and let me know if you need me to add to it
Old 2nd March 2012, 12:24   #19  |  Link
dukey
Substreams on EVR can be any frame rate you want. Even variable frame rate is fine. The catch is, the substream will only update if the picture on pin1 is updating, so the substream is locked to the references streams frame rate.
Start and stop times on substreams are not a problem. Just fake something. If the video is 25fps, just send the stop time to be +40ms of the start time.
The other catch is, the video one pin0 will stop if there is no substream picture. So either send an end of stream notification or just send blank frames to keep the renderer happy.
Old 4th March 2012, 13:18   #20  |  Link
cb2000
www.mediafire.com is blocked by country firewall...
